Drivetrain Riss Racing vs. Exhaust Depot ???
Old Mar 10, 2011 | 07:35 PM
dboard7's Avatar
dboard7
I have an Invidia q300 exhaust on the way. i have come across a good deal on both the Riss Racind cat less downpipe and the exhaust depot cat less down pipe but i don’t know which one i should go with Please help! I need to make my decision by tomorrow morning 11am.
Old Mar 10, 2011 | 08:02 PM
AkFarina's Avatar
AkFarina
Well you already have an exhaust so you don't need a Cat-less down-pipe with a resonator in it. The Ris Racing one is totally open so that will work out better for you.
Old Mar 10, 2011 | 08:19 PM
turtle343's Avatar
turtle343
ive got a catted Riss Racing onto a JCW system and its freaking awesome.
Old Mar 10, 2011 | 10:51 PM
sooper_cooper's Avatar
sooper_cooper
So you put a DP on your stock JCW exhaust? I'm thinking about doing the same thing on my 2009 JCW with an ED downpipe, since it's so hard to find a Riss these days.
Is the power gain really noticeable on your JCW? Do you get any CELs?
Old Mar 10, 2011 | 11:22 PM
AkFarina's Avatar
AkFarina
You will get a CEL, you will have to get a AP tune to take care of it. It will think that your cat is blown, and sometimes make you car think it is running lean
Old Mar 11, 2011 | 03:36 PM
countryboyshane's Avatar
countryboyshane
Beware of the Riss Racing pipe. I've had mine on a long time without issue, but there is one thing that really irritated me. The length of pipe at the last bend of the Riss Racing downpipe is a bit too short and you'll have a ***** of a time getting on a bolt-on cat back. Invidia might be different but don't expect any promises from any company especially Riss. I had mine cut and welded with 3-bolt flanges to connect my DDM Works exhaust. If you have a lot of tension in the downpipe to catback connection, you'll pop the cat-back off eventually during hard wide open throttle pulls in low gears due to the twisting of the engine. This is what happened to mine before I got everything welded and done right.
Old Mar 11, 2011 | 10:29 PM
turtle343's Avatar
turtle343
Power was very noticeable, especially above 3500rpm. i got a CEL after 400km. it says increased emissions on the gps and keeps the engine check light on. if you go behind the car you can smell the Burnt gas alot more. I plan on getting the access port as soon as its available for AUS spec cars. Also mine was a direct bolt on, very easy, no probs.
Old Mar 14, 2011 | 03:32 PM
dboard7's Avatar
dboard7
thanks everyone for your input. i decided to hold off and not rush into anything, whats the best over all downpipe to go with the q300 exhaust? i dont want to cut up anything i just want the best bankg for my buck
Old Mar 14, 2011 | 06:01 PM
countryboyshane
Exhaust Depot was supposedly one of the only true bolt-ons to be made to the correct dimensions as the OEM downpipe. I have a feeling you'll be headed to the weld-shop no matter what though.
Old Mar 14, 2011 | 06:46 PM
BadMINI S's Avatar
BadMINI S
Its not just an obsession
I have the Riss Racing DP and everything bolted up nicely. I have a magnaflow exhaust, and I did have to move it forward a little which was easy since it is a multipiece system. You shouldn't have any problem with the Q300 and a RR. I used a cat sim fouler and I tend to get a CEL every 500-700 miles, so it's not perfect but good enough for me.
Old Mar 14, 2011 | 09:36 PM
AkFarina's Avatar
AkFarina
I have one i ordered from france, it was lik 120, and it is a perfect fit.
Old Mar 14, 2011 | 11:36 PM
dboard7's Avatar
dboard7
120 is a really good deal what's the size and brand and power gained? I'm leaning tward the riss its only 200
Old Mar 15, 2011 | 02:06 AM
AkFarina's Avatar
AkFarina
Its 2.5, Its made by Ragazzon. And for power, more tork need a tune for any HP gain. I bought it from ultratuning.com
Old Mar 19, 2011 | 06:55 PM
Underoath's Avatar
Underoath
Why would you waste money a catback that cost 500$+ when you can do straight 3 inch pipe for 100-150$ that does the same thing? And the sound isn't bad at all? If I had a good recorder I could let everyone hear how it sounds. Also a 2.5 inch downpipe is a waste of money and labor for maybe 5 hP gain, the 3inch only gains 10hp but it also not worth it for CELS and most good downpipes cost 500+. Best bang for buck is 3inch straight pipe cat back, boost tubes, intake and AP tune.
Old Mar 19, 2011 | 10:38 PM
AkFarina's Avatar
AkFarina
Nice first post. 11er's guna 11. 3 inch is to big for our motor unless you are pushing 300+ and your not.
Old Mar 20, 2011 | 11:50 AM
dboard7's Avatar
dboard7
I agree with AkFarina, I’ve been trying to decide for a long time but 3" seams too much. i went with Riss Racing cat less and ceramic coated got it new for $180 couldn’t pass it up and the Invidia was $500 in my mind a good price because iv gone down the custom rout before and it was more like $300 and it wasn’t the prettiest. Buying a brand name one will insure the sound i want as well as better quality. Theyre both in the mail now and for the codes it won’t really matter i have the access port
Old Mar 21, 2011 | 01:01 AM
Underoath's Avatar
Underoath
Thx :-)
3inch is not too big and it's been proven that 3 in will make power power with room to grow, idk how new you are or some other people on this forum are with cars but turbo cars need ZERO back pressure, in no way can running a larger exhaust on a turbo car hurt you. Alta and a few other "mini" performance companies have already proved it.
Old Mar 21, 2011 | 01:16 AM
BMC_Kid's Avatar
BMC_Kid
Originally Posted by Underoath
Thx :-)
Old Mar 21, 2011 | 02:49 AM
Davidoyo's Avatar
Davidoyo
Thx :-)
This should be good
Old Mar 21, 2011 | 02:54 AM
AkFarina's Avatar
AkFarina
I don't think he realized I was being sarcastic.
Old Apr 2, 2011 | 05:55 PM
dboard7's Avatar
dboard7
i just installed the Riss racing dp with an Invidia q300 exhaust it fits great and sounds amazing!
Old Apr 2, 2011 | 06:07 PM
Stryker305's Avatar
Stryker305
Congrats, but how much drone do you get with that set up?
Old Apr 3, 2011 | 06:18 AM
kraptor's Avatar
kraptor
hello
where you bought it?
Old Apr 4, 2011 | 12:14 AM
dboard7's Avatar
dboard7
Theirs not much drive but on the highway when I hit the gass it screams! I love.It but Its still not fast enough for me lol..
I got bothe the dp and exhaust off ebay. The exhaust from streetrays and the do was a private seller 4x4angelo I think was his sn
jetmechinnc
Nov 16, 2020 06:38 AM
Bennyboy
Aug 18, 2015 07:28 AM
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
