Drivetrain Retrofit liquid filled motormount
Old Feb 20, 2011 | 07:58 AM
stevendoll's Avatar
stevendoll
So, I am assuming that MINI changed from a solid block of rubber for a mount to a liquid filled one for a reason (assuming it is not because they wanted to replace them all when they leaked). Is there ant reason to retrofit one to a earlier car?
Old Feb 20, 2011 | 10:30 AM
Da_Ghost's Avatar
Da_Ghost
I may be wrong but isn't even the 02-04 models to be liquid filled? And if the it was a rubber one then there's NO reasons to retrofit the new one since it leaks!!!
Old Feb 20, 2011 | 11:53 AM
rkw's Avatar
rkw
The newer version is much more problematic and MORE prone to leakage! It is such a common problem that dealers keep the part in stock.
But it's all a moot point. The mount attachments changed and the two versions are not compatible.
Old Feb 20, 2011 | 12:40 PM
MINI33342's Avatar
MINI33342
[quote=rkw;3218579 The mount attachments changed and the two versions are not compatible.[/quote]
Old Feb 20, 2011 | 07:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Actually most people don't know it, but the old style rubber mount is also filled with hydraulic oil. When the early mounts fail the oil evaporates and the mount gets shorter.
Check out the TSW mounts as replacements. We have them for both the early and the late mounts.
scfiveo
Sep 27, 2019 02:27 PM
OutMotoring
Nov 16, 2015 07:04 AM
martinb
Oct 7, 2015 05:00 PM
ahorvath
Oct 3, 2015 01:13 AM
bbak11010
Sep 7, 2015 08:08 PM
