Drivetrain R56S Custom Exhaust question
Old Feb 18, 2011 | 01:39 PM
AXO's Avatar
AXO
I went to a custom exhaust shop yesterday to get an estimate for a custom exhaust system for my 08 MCS. The guy quoted me $325.00 from the second cat bck. He would not remove the second cat. This included a Magnaflow muffler with aftermarket tips.
The installer advised the exhaust pipe will be aluminized steel. Not stainless. My question is Aluminized Steel OK for the price? ($325) He said He doesnt stock stainless pipe because it is too expensive and most customers dont want to pay for it. I have not comitted to the job yet. He also said he would bump up the pipe size to 2.5". He said 3" is way to big and I would loose alot of bottom end torque.
Thanks AXO
Old Feb 18, 2011 | 04:58 PM
MINI33342's Avatar
MINI33342
SS exhaust is way overkill for the vast majority of customers. An aluminized system will still probably outlast the car unless you have a real issue with rust and salt. Never had a system rust out on me. And I would agree, 2.5" is plenty big.
Old Feb 18, 2011 | 09:05 PM
AXO's Avatar
AXO
Thanks!
Old Feb 18, 2011 | 09:42 PM
blkkouki's Avatar
blkkouki
and by the way he can make it straight pipe with no bends its what i have i did a custom job, and the price isnt to bad. ooh and if you find someone that will remove the second cat it will take out some of the interior noise believe it or not
Old Feb 19, 2011 | 06:22 AM
countryboyshane's Avatar
countryboyshane
What's the point if you have to keep the 2nd cat? If your vehicle inspection only checks for a check engine light and doesn't do a tailpipe test than you can get rid of the 2nd cat.
I agree with the steel chosen for you. You don't have to deal with the road salt that us Northerners get to experience that eats everything alive. It should last you awhile.
Old Feb 19, 2011 | 07:06 AM
AXO's Avatar
AXO
I told the guy the JCW does not come with second cat. He still wouldn't remove it. He must have been hasseled by the muffler police for removing cats. I plan on having one made somewhere else. 2.5" straight pipe with a Magnaflow Muffler.
Thanks for the replies.
Old Feb 19, 2011 | 07:32 AM
blkkouki's Avatar
blkkouki
i tried that same argument didnt work for me either
Old Feb 19, 2011 | 07:49 AM
iwashmycar's Avatar
iwashmycar
so the second cat adds noise??
I have both a JCW and stock exhaust, and was wondering what it would be like to pair the stock catted front with the JCW rear portion lol
Old Feb 22, 2011 | 07:20 AM
phillipcoopersgates's Avatar
phillipcoopersgates
Hey man I have an 09' MCS and Im trying to do a straight pipe from the turbo all the way back which obviously is incredibly illegal but it needs to be done. Do you have a video of how loud yours is? just trying to get an idea.
Old Feb 22, 2011 | 07:55 AM
Raymazing's Avatar
Raymazing
I would post a video but launch control prevents me from revving over 4K when clutch is in or car is in neutral :( My exhaust is 3in. turbo back no cats
Old Feb 22, 2011 | 08:11 AM
Laardilla21's Avatar
Laardilla21
Hey Guys,
This is the thread to the exhaust I am going to go with. BostonR56 has this system and several videos on Youtube. Search for akakong88 on youtube and you will find his videos.
https://www.northamericanmotoring.co...-exhausts.html
Old Feb 22, 2011 | 11:58 AM
phillipcoopersgates
I would love to see that how does it sound?
Old Feb 22, 2011 | 12:16 PM
Raymazing's Avatar
Raymazing
Its a soft touch limit at 4K. Its not anything cool like a 2-step. I just routed the wastegate back into the downpipe to quiet it down.
Old Feb 26, 2011 | 06:39 PM
AXO's Avatar
AXO
This past Friday I had My Second Cat and Resonator removed ($60 welded). I immediately notice that the Turbo spools up much quicker! There was a seat of the pants improvement! The sound also improved! No Drone at all! Highway speeds with the windows up were slightly noticable. With the Stereo on, not noticable at all. Unfortunately the Kid in Me wants louder. So I order a Polished Stainless Magnaflow with a 3" inlet and two 3.5" tips. I will be running 2.5" pipe straight (No bends) back from the first exhaust hanger to the Magnaflow muffler. It should sound pretty good when I'm done. I will keep you posted!
AXO
This mod can be reversed back to Stock for under a $100 bucks.
Old Feb 28, 2011 | 05:33 AM
BostonR56S's Avatar
BostonR56S
AXO
Sorry for raining on your parade after ordering the part, but why did you choose to get a 3" inlet exhaust if you're planning on a 2.5" pipe? Not sure how it'll change the sound, but it'll change the flow characteristics a bit (maybe for the better!)
Mines 2.5 pipe to 2.5 inlet and dual 2.25 outlet to 4" angled tips. Fills the rear diffuser void perfect. I got lucky with my welder/installer, I told him how OCD and **** I am about even gaps all the way around (aka perfectly center), and he got them to within 2mm of center
Old Feb 28, 2011 | 07:18 AM
AXO's Avatar
AXO
The reason I ended up ordering a Muffler with a 3" inlet was due to the Tips. I wanted a dual walled tip, So I opted for an universal Muffler with the tips already installed from Magnaflow. I think it looks better that way. (Cleaner)
My mechanic got me a deal on a Magnaflow Polished Stainless Steel muffler with the tips I wanted for $185.00. So I said go for it. Hence the 3" inlet. I am hoping I don't have an issue with the 3.5" tips fitting in the gap. I am not opposed to a little trimming if needed.
Old Feb 28, 2011 | 08:52 AM
AkFarina's Avatar
AkFarina
I had a 2.5 straight pipe from the turbo back, Youtube search "AKfarina907" im at work so i cant post it, its one of the ones that is just the camera on the ground i think, you can tell by the sound. its really loud if you were going to do it use the exhaust depots downpipe with the baffles in it. Kepp the cops away
Old Feb 28, 2011 | 09:13 AM
BostonR56S's Avatar
BostonR56S
You'll have no problem with 3.5" tips. Like I said, I have 4" tips. They are at a 20 degree angle and are double walled stainless steel (as well as the exhaust they're welded to). Same setup as this basically, same tips at least for reference in photos
https://www.northamericanmotoring.co...w-catback.html
Old Mar 1, 2011 | 05:13 PM
Powashiftin's Avatar
Powashiftin
I'm looking at this setup
resonator: Magnaflow 10416
Muffler: Magnaflow 12258
Tips: Magnaflow 35121
How's this setup sound?
Old Mar 2, 2011 | 05:24 AM
BostonR56S's Avatar
BostonR56S
Considering thats my exact setup, lol I'd say it sounds good.
If anything, try looking for a longer resonator, or 6" instead of 4" round. Get rid of a little more drone that you'll learn to hate. Sound under load won't change much and will be just as good.
Did you pull the pn's off my youtube vid?
Old Mar 2, 2011 | 05:37 AM
BostonR56S's Avatar
BostonR56S
Try 12646 if the 6" will fit. There should be enough room, right above the brace. It might be a tight squeeze.
Or 10426 would fit I'd believe. 18" body vs the 14" will be better to break up resonance a bit better.
10436 is 22" body. This would be best, and I believe matches the JCW resonator length? Though I could be wrong and the JCW could be 22" overall, but I THINK its body length.
I'd go my last suggestion out of those if it'll fit. If you get your car up in the air just measure how much straight pipe length there is above the center brace. It should fit. I actually may swap this myself if it helps the drone.
Old Mar 2, 2011 | 06:20 AM
clnconcpts's Avatar
clnconcpts
What about just using a round muffler instead of the oval ones?Like the exhaust depot or Stratmosphere
Old Mar 2, 2011 | 06:31 AM
AXO's Avatar
AXO
A good exhaust shop can mate any muffler to your system. I saw a Yoshimira Motorcycle can used as a Mini Muffler and beleive it or not it sounded Great!
Old Mar 2, 2011 | 06:55 AM
clnconcpts's Avatar
clnconcpts
I know anything can be done.I just want to avoid any drone.Not sure if a round muffler will have any
Old Mar 2, 2011 | 09:03 AM
BostonR56S's Avatar
BostonR56S
Changing between muffler setups within magnaflow usually will not change drone characteristics by much. This is because magnaflow mufflers are VERY straight through design. When u look in one end you'll see straight through to the exit (granted if its not an offset inlet/outlet design).
The most effective factor for drone will be pipe diameter. If you want to keep drone to a minimum go with a 2.25" diameter. Still larger than the JCW and will be enough for flow characteristics. It just might be not as deep as a 2.5" pipe.
