Drivetrain Revolution Mini Works Race Cams
Old Feb 10, 2011 | 06:22 AM
  #26
Revolution Mini Works's Avatar
Originally Posted by The_R1_Kid
Very interested in the plug and play ECU.
I've been testing a version now for over a year
It won't be the final one as it will be smaller to fit in stock location
Originally Posted by Mr Silverblood
Good....fargon.....lord!
Originally Posted by Agarwaen
880!
bet that spray pattern looks something like this.
ONLY when I turn on the dual METH sprayers
Originally Posted by robinj
My eclipse loped at idle with 246 cams, sounded like a diesel with the headlights and front+rear defrosters on in the winter... that engine would scream to 7200 before the stupid fuel shut off. The next tier up on the cranes would not idle on the stock ECU so I couldn't go bigger at the time.
Besides, I'm sure if Jan wanted to he could twist the cam gear and get some lovely overlap... or make an idle burble tune.
with the stand alone much more power and craziness will ensue
we are taking the R53 where people only dreamed of
you have built in logging, and FULL control of an ecu that will enable traction control, on the fly map switching etc.......why would you spend $1200 to tune the stock ecu when you can spend another $4-500 and do what a MOTEC will do?
Old Feb 10, 2011 | 07:21 AM
  #27
Luys's Avatar
Luys
When do you think the ecu will be ready??
Old Feb 11, 2011 | 05:42 AM
  #28
longer than expected I was supposed to have another one in my hands by end of January
Old Feb 11, 2011 | 09:00 AM
  #29
Luys's Avatar
Luys
Old Feb 13, 2011 | 05:11 PM
  #30
alexmini08's Avatar
alexmini08
running the stock valve springs to 7700 is just asking for trouble. I know it's been done but it's just a matter of time before it floats a valve
Maybe you missed the point that both dyno's are running the race cams with my big valve head?
The "jesus head" is capable of running 7,700rpm??? What a about the flow in 7,xxx rpm??
Old Feb 14, 2011 | 05:54 AM
  #31
I'm not quite understanding what you are asking
Old Feb 14, 2011 | 02:44 PM
  #32
alexmini08's Avatar
alexmini08
Can the RMW run @ 7,xxx rpm without trouble (valve float)? in post #13 (i think) you said that the stock head stops flowing, the rmw head stops flowing after 7,000 rpm (i know you said that the one that stops flowing is the stock)?? its just that i would like to rev 7,200 ~ 7,600 (safely)....
Old Feb 14, 2011 | 03:08 PM
  #33
the RMW head will easily flow to 8000 rpms
the stock is not good much more than 7000-7300
Old Feb 15, 2011 | 08:09 AM
  #34
JumpingJackFlash's Avatar
JumpingJackFlash
We stock our 450cc and 550cc. But we have access to ANY size injector you want or need. I have 880cc injectors in mine at the moment.
That's pretty sick! That equates to 83+lb/hr.
Old Feb 18, 2011 | 05:50 AM
  #35
coopselt's Avatar
coopselt
From: Camano Island, WA, but wish was still Oahu, Hawaii
Being onboard Ship right now over seas makes me LOVE that firefighting picture!!
bigramdizzle
Aug 6, 2019 09:19 PM
emulajavi
Dec 24, 2018 09:15 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
