Drivetrain Injector upgrades
Old Feb 1, 2011 | 06:18 PM
gschiel's Avatar
gschiel
Injector upgrades
So once I get around to installing my 15% pulley, I'd like to upgrade the injectors as well. I was thinking about the JCW injectors, but the prices seems quite high. I have a site which I have used in the past to buy go fast parts for my old VW and was wondering if these are the same design as the JCW's? Here is the link http://www.ctsturbo.com/products/Bos...ector-4-4.html I see that the JCW's are Siemens injectors, but can't find a side angle picture to compare the design of the 2.
Old Feb 1, 2011 | 06:36 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
It has more to do with length and spray pattern of the injector.
JCW uses a dual cone spray pattern. If the inector is too long, or too short some modding to the fuel rail and bracket may be in order....then you also run into clearance issues to the bottom of the intercooler.
You can run into some issues when " winging it" with respect to injectors so read up the many threads here in NAM before pulling the trigger on a set.
My two farthings....
Old Feb 1, 2011 | 06:45 PM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Just get the 550's from Mynes, and a tune to scale them. Or better yet the Byte Tronik S/W so you or somebody you trust can do the tuning.
Best part about the 550's from Mynes is, they are the exact same ones as the compitition sells, but for cheaper and they still have their part numbers intact.
Old Feb 1, 2011 | 07:11 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
gRay is right. You need to be very careful with your injector choice. The wrong spray pattern will be a mess. Also fitment and size needs to be correct for your use. If you go bigger than 380cc you'll have to have a tune to make it run right.
Old Feb 14, 2011 | 07:42 PM
CZ Mate's Avatar
CZ Mate
I was also thinking about upgrading my injectors to the JCW injectors. I am going to install my %15 super charger pulley & +2 lighten crank pulley, in the next 2month.
Do you guys think I should save up and buy the bigger injectors before I start my install??
Old Feb 15, 2011 | 09:51 AM
mgrant's Avatar
mgrant
Im in the same situation. Is 550cc necessarily better than 380cc ???
Old Feb 15, 2011 | 10:05 AM
CZ Mate's Avatar
CZ Mate
550cc seems way to big, 67% more fuel than stock injectors.
Old Feb 15, 2011 | 10:15 AM
JumpingJackFlash's Avatar
JumpingJackFlash
+1 to Gray Raven.
Going to larger 440cc or 550cc injectors gives you growing room should you decide to make bigger mods down the road (head, cam, etc.). I would suggest getting your MINI tuned before going out and buying them. You may not even need the 380cc JCWs.
Old Feb 15, 2011 | 10:30 AM
CZ Mate's Avatar
CZ Mate
Thanks for the input jumping jack.
Old Feb 15, 2011 | 11:10 AM
Checkmate_2006's Avatar
Checkmate_2006
I am on the fence about which new larger injectors to get. I am getting a pulley and tune next month among other things (see sig) and it was suggested I go with 550cc injectors for the same reason JumpingJackFlash mentioned, room to grow in the future. As long as the car is tuned for the 550cc injectors they should be okay correct? I am not sure whether to get JCW 380cc or the Bosch 550cc.
Old Feb 15, 2011 | 12:24 PM
JumpingJackFlash
Checkmate, if you plan on adding a head and cam down the road, go with the 550s. Otherwise, if you only opt for the JCWs now, you will end up buying another set down the road.
Old Feb 15, 2011 | 12:29 PM
Checkmate_2006
I don't plan on adding a header or cam. Should I just get the JCW injectors then? Mike said the 380cc injectors would be pushing their limits with my current and and planned performance mods. I just want to get something that won't damage my engine really.
Old Feb 15, 2011 | 11:09 PM
4wheels's Avatar
4wheels
If you wind up deciding to go for the JCW's I have a brand new set still in the box (never used or installed). I wound up going with a bigger 1.8L stroker motor that was much wilder than my original plans so I never used the JCW's I bought. PM me if you decide to go that way. Just been too busy to list the extra parts I have for sale. Also have a new Schrick cam...
Old Feb 17, 2011 | 07:41 AM
mgrant's Avatar
mgrant
do you absolutly need to tune the car after putting in bigger injectors ?
Old Feb 17, 2011 | 08:06 AM
Achilless's Avatar
Achilless
380cc injectors, no it will run OK without a tune, i am running JCW 380cc without a tune (for another month till jan comes to the east).
But without a tune its just a waste of gas. I didnt see any difference when i swapped the injectors. Maybe 1 hp lol
However if you go bigger than 380cc, like the 440 or 550, you will need a tune
Old Feb 17, 2011 | 10:39 AM
unxpectederror's Avatar
unxpectederror
i believe the highest you can go without tune is 400cc.. i forget who sells them though..m7 maybe?
if your not going to do anything more then 15%-17% pulley, CAI and exhaust then the 380cc with a tune will be fine.
Old Feb 17, 2011 | 04:40 PM
DICKS GARAGE R53
As said above the 380's (JCW) are the biggest you can safely do without a tune to scale them. Running the 550's isn't overkill if they are scaled, they will run just like the stock ones but with a lower duty cycle, and a lot quicker than the stock or JCW's.
With the MYNES S/W all you need to do to scale for the 550's is reset your global fuel scale from a 508 (STOCK scale) to a 350-353 (CORRECT scaling for pump gas and 550's) The car will run as if it still had the stock injectors but a LOT smoother, it wont use any more fuel than stock, and it leaves lots of room for future improvements. Your tuner will thank you in the future if you go big on injectors now, and go big on motor later.
Old Feb 17, 2011 | 05:42 PM
mgrant's Avatar
mgrant
if i plan on doing only a 16% pulley and a custom exhaust this summer, do i need bigger injectors or would the stock (R53) work ok. I plan on doing lots of work to the car but i may take some time.
Old Feb 17, 2011 | 08:51 PM
DICKS GARAGE R53
It would lean out a little but not horribly bad, might be enough to trigger a CEL especialy on hot days. I wouldnt recomend changing the header without doing the injectors, it will lean the car right into limp mode at anything above 70 degrees.
Old Feb 18, 2011 | 08:30 PM
mgrant's Avatar
mgrant
so as long as no header goes in the car im clear ?
good to know thx a lot
Old Feb 18, 2011 | 08:46 PM
ACallahan's Avatar
ACallahan
I am running a mynes header, larger intercooler, 15% pulley, CAI. Still on my stock S injectors and I live in Florida with temps well above 70, definately seems to run lean when I get on it, never went into limp mode though lol. Dropping some 380's in and having Way do a quick tune at the Dragon.
Old Feb 18, 2011 | 09:05 PM
ggcadc's Avatar
ggcadc
if you want to take a GUESS, just buy one of the sizes mentioned here, if you want to do it right, get a target for HP (this will require an initial dyno run) and do some maths and planning, rceng.com has a calculator to help figure the right size injector for your application, that's how I arrived at getting 450cc's and they work like a charm with a little help from Jan.
BTW: just cause you can scale 550's to work on the street doesnt make them useful, do some reading and learn what is actually going on with injectors of different sizes and then make your decision. maybe start here: http://www.rceng.com/technical.aspx
Old Feb 20, 2011 | 11:58 PM
mgrant's Avatar
mgrant
Thx ggcadc
I will definitly read this
molala
Oct 2, 2015 01:53 PM
Sep 3, 2015 10:29 AM
Manny_cooper
Sep 3, 2015 05:48 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Sep 1, 2015 04:39 PM
