Drivetrain what do i do? unichip
Old Jan 24, 2011 | 02:24 PM
gjn25's Avatar
gjn25
I m looking at getting a Unichip in my 07 S. I know how most of you feel about them but i know this one works got it off a car that was (on a DYNO) make 207hp at the wheels i m getting it for $400 installed and DYNO testing to make sure it works on my too. but still want to know what you all think.
Old Jan 24, 2011 | 02:59 PM
iwashmycar's Avatar
iwashmycar
Probably 95% of us will say stay away.
They are notoriously unrealiable... If its working on another car, kudos to them.
Id hate to see it all installed for you, then you lose all engine power in the middle of the freeway (ask me how I know lol). Its no fun trying to coast to the median in rush hour.
You can probably do a lot better with the new tunes out.
UniChips are fun, but any boost in power is.
Old Jan 24, 2011 | 03:17 PM
gjn25's Avatar
gjn25
Well thanks for heads up. Now I have a new Q lol! Who can tune what do I need and how much would it be I m broke!!! Lol!!! and trying to do this that's y I thought 400 was not bad for 50hp but I don't want to be dead in the water after it. Thanks
Old Jan 24, 2011 | 03:19 PM
iwashmycar's Avatar
iwashmycar
Im pretty sure if its the Plug-and-play version you just plug it in and go. Depends what mods the other car had. If they are the same or close it should be just fine. For example the one I had was tuned with an intercooler supposedly.. I didnt have one, and it didnt matter.
all you can do is give it a shot
Old Jan 24, 2011 | 05:58 PM
com3tojo3's Avatar
com3tojo3
If you MUST use the Unichip ask the tuner to hardwire it for you. All the problems I experienced with it had to do with the plug n play harness. Went trouble free for 20k miles once it was hardwired.
Honestly though, there are MUCH BETTER choices out there now. Put that $400 towards the Accessport. I only used the Unichip because it was the only "tuning" choice available at the time
Old Jan 24, 2011 | 07:08 PM
Achilless's Avatar
Achilless
I know how u feel being broke, if you think the $400.00 is a good deal then definatley get it. However, like suggested, there are a lot better more reliable tunes out there. If you are close to one of the shops, most of the time it is 350-450 $
So think about it first, call some of the tuners, RMW, ALTA.
Old Jan 25, 2011 | 05:02 AM
iwashmycar's Avatar
iwashmycar
I have also heard the hardwired way works, and it should. The problem is (at least on mine) the small plug closest the firewall... With the connectors inserted between the ECU and existing plugs, it stretches the existing harness so that it is a very tight fit. I think this breaks connection on some apparently very important wires... I could kill my engine by simply pushing the connector a certain way (pretty lightly too).
My advice would be ,if you install it the plug and play way, make sure to get all the slack possible to the existing harness (cut clips, connectors, ect)
Old Jan 25, 2011 | 05:08 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
The ByteTronik / Full Access software from MYNES is going to be avalible for R56's soon.
Old Jan 25, 2011 | 05:11 AM
iwashmycar's Avatar
iwashmycar
Originally Posted by gjn25
...Now I have a new Q lol! ...
Hey fellas, he already appears to have it
Old Jan 25, 2011 | 01:40 PM
com3tojo3's Avatar
com3tojo3
lol If you already have it, HARDWIRE IT! I would personally not drive my car with it using the plug n play harness. I cant count how many times the car would randomly shut off or lose power.
Old Jan 25, 2011 | 01:46 PM
ronnie948's Avatar
ronnie948
Did I hear "50"" (FIFTY) Horsepower??????
If it sounds to good to be true it usually is. 50 Horsepower with a $400.00 chip.
Old Jan 25, 2011 | 01:57 PM
iwashmycar's Avatar
iwashmycar
Well it definately isnt 50, BUT the 5lbs of boost does make a very big difference. Not sure what that sort of gain is.
Old Jan 25, 2011 | 02:04 PM
gjn25's Avatar
gjn25
Well I have the dyno runs to prove it 157 stock 207 chipped I will scan them in and show you all in the morning and yes it will be hardwired that's the only reason I would do it
Old Jan 25, 2011 | 02:09 PM
iwashmycar's Avatar
iwashmycar
good to hear. post pics of the chip installed if you can too. Ive never seen one hardwired in
Old Jan 25, 2011 | 02:15 PM
gjn25's Avatar
gjn25
I will do the sec I get the car back, mass air went out and car is now not doing so hot lol!
Old Jan 25, 2011 | 05:16 PM
gjn25's Avatar
gjn25
I did some research I want this so bad!!!!!! But I will most likely kill my car playing with it
Old Jan 26, 2011 | 08:56 AM
BostonR56S's Avatar
BostonR56S
Are you sure the MAF is dead? Because when I had the UniChip I know I once threw a code for the MAF sensor but after cleaning the sensor with MAF cleaner the code went away. Maybe it was the intake I had on it with oil getting on the MAF or it was the chip's connection.
Also, the 50hp gain can be possible if its crank, but 207 crank hp wouldn't be much of a gain with increased boost. Most of us see ~30whp gain which equates to about 50 crank hp with the RMW/Cobb tunes
Old Jan 26, 2011 | 09:27 AM
gjn25's Avatar
gjn25
No we cleaned it and ran the comp on it again it's doing the samething the comp is reading 0 at no load also my HPFP is out I think lol
Old Jan 26, 2011 | 11:10 AM
chakraj's Avatar
chakraj
Welcome to the world of Unichip. My old P115D, was a to much air for my MAS code.
Ahh coasting to a stop in 5 lanes of LA traffic, Good Times
Old Jan 26, 2011 | 11:24 AM
gjn25's Avatar
gjn25
No lol sorry guys I did not make thus all 100% clear the problem I m having was pre chip I just blow it off till now to get it fixed lol I love how fast every one hose strat at the chip the sec I have a prob do to the chip I will pull it out! Sorry I forgot to add that part first.
Old Jan 26, 2011 | 12:59 PM
gjn25's Avatar
gjn25
the dyno runs
there are the dyno runs Stock, Switch on B, Then on A, its written on top of each page (sorry my scanner is not working)
Attached Thumbnails what do i do? unichip-photo-1.jpg   what do i do? unichip-photo-2.jpg   what do i do? unichip-photo-3.jpg
Old Jan 27, 2011 | 04:14 AM
yetti96's Avatar
yetti96
What's with the odd scaling of the graph, the actual data only occupies 25-40% of the graph. Looks odd to me. And the huge spike at 5k is that overboost, the pressure dump, and rebulind psi or a shift or something? No data below 4k rpms either? I am no dyno expert at all but this just doesn't look like most graphs I have seen.
Old Jan 27, 2011 | 07:39 AM
gjn25's Avatar
gjn25
Yeah same thing I said when the going was doing the rune but it's an old dyno set up he has a new one coming in about 2 month and I will then have new runs to post. It is accurate crazy as it may sound and yes the spike of power need to be re mapped and worked out but the car is making power lol. Next week I m taking it to a buddy of mine to rerun the dyno on a brand new dynojet dyno I will post those numbers up too and vid of those runs. The shop I go to is very good but the guy deals with high end car and airplane manly he's one of the only guys around palm beach that I know of that work on minis and know that they are doing.
Old Jan 27, 2011 | 07:50 AM
com3tojo3's Avatar
com3tojo3
Yes, I remember those days too lol
Old Jan 27, 2011 | 06:28 PM
ThumperMCS's Avatar
ThumperMCS
For your sake, I hope that it ISN'T accurate....lol
That has got to drive horrible....
