Drivetrain Need Help!!
Old Jan 24, 2011 | 01:03 PM
ice91's Avatar
ice91
Need Help!!
Hi,
I have a 2006 JCW and currently ran into an issue.
When I put down 2nd gear and floor my mini doesnt seem to accelerate and the traction control light (believe it is the abs? the triangle with the question mark) starts flashing. I put in 3rd gear and it is gone. The thing is that i feel again the lag (2-4 rpm lag) that i used to feel before modding it.
Any similar situation? Solution? Do you know what it is?
Old Jan 24, 2011 | 04:35 PM
SteveS's Avatar
SteveS
Are you serious or joking?
Some people choose to turn off the DSC. Press that toggle on your control panel for a couple of seconds and the lighted triangle comes on. This way, when your tires lose traction the computer does not cut the power.
However, for hazardous conditions or wet weather, or for bad drivers, don't do this.
Old Jan 24, 2011 | 09:01 PM
ice91's Avatar
ice91
im seriousssss the thing is I could turn it off, but this is happening while it is on!
Old Jan 24, 2011 | 09:06 PM
COR BLMY's Avatar
COR BLMY
it is doing what it should.
look into one of the program solutions out there that will default it to the off position .
Got to remember to turn it on in poor traction . maybe everyday use .
Old Jan 24, 2011 | 09:22 PM
dragonwang's Avatar
dragonwang
Get better or new tires?
Old Jan 25, 2011 | 06:05 AM
ice91's Avatar
ice91
it is doing it more than once... and the tires are new... im thinking more like it is the traction control sensor going coocoo... but im not sure wanted to know if this happened to anyone before
Old Jan 30, 2012 | 07:22 PM
bigdaddyslip's Avatar
bigdaddyslip
I am having this same issue with an added twist. I am getting the Flashing traction control light in second and I am NOT punching it to the floor. I am also getting erratic hopping in the upper range of second and the lower range of third. this issue only started after i replaced my front wheel bearings any ideas. I have also changed my abs sensor with no luck of fixing the problem.
Old Feb 13, 2012 | 08:03 PM
BrungMini's Avatar
BrungMini
I am also experiencing issues with power lag. When I shift from second to third my car has a hick up / lag in the rpm range between 2-4 thousand rpm. I can feel the car struggling in the power delivery. I however am not getting my DSC / Traction light coming on at all during this lag issue.
Old Feb 16, 2012 | 02:36 AM
Raze's Avatar
Raze
I had the same problem before i replaced my stock head with a Thumper TPR1, adj. cam gear and a mynes tune. now my mini screams though that rpm range all the way up to redline.
It might be something that a tuner can tune out?
