Drivetrain Plug wires
Old Jan 6, 2011 | 05:23 PM
stevendoll's Avatar
stevendoll
Plug wires
My 03 MCS (93K miles) is suffering from some hesitation issues and since it has original plug wires, I am going to replace. OEM ones from dealer or aftermarket? Is there any reason to use one vs other?
Old Jan 6, 2011 | 06:05 PM
Martin Brenneke's Avatar
Martin Brenneke
Think about changing plugs first ,at your mileage then if still not performing then wires. Also check coil to see if you have problems with the posts. clean if necessary.
Old Jan 6, 2011 | 06:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
The good aftermarket plug wires we have are pretty cheap. But you need to check your coil pack for terminals 3 and 4 are probably rusty. So you might want to replace the coil pack if it is. And the high output Screamin Demon is good replacement if you need it. For spark plugs stick with the NGK plugs, they are suppose to be replaced at a 100k, so your not too far off. We also have an ignition package with it all included.
Old Jan 6, 2011 | 07:44 PM
Vollgas's Avatar
Vollgas
Running with Brisk plugs, Magnacor wires and MSD Coil pack.
Great package.
patsum
26
May 29, 2021 06:29 PM
rob76turbo
Sep 15, 2015 10:11 AM
Filmy
Sep 7, 2015 08:27 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
