Drivetrain maybe a different exhaust question
Old Dec 10, 2010 | 06:51 AM
CaMiniMe's Avatar
CaMiniMe
i am thinking about going the custom magnaflow route but i have a question and hope someone here might be able to help. i was going to go ahead and weld this exhaust up myself. i know that in the exhaust tubing under the car there are to bends. are these bends necessary? it looks like as long as i can clear that little bracket underneath the car that i can rung straight tubing from the catback to my muffler. is this correct or am i missing something?
thanks
Old Dec 10, 2010 | 07:10 AM
Maugre's Avatar
Maugre
I would say do it, less bends = better flow. Will you be emissions legal? Don't know how they check things in Cali. Good luck.
Old Dec 10, 2010 | 07:49 AM
CaMiniMe's Avatar
CaMiniMe
yes emissions should be fine. i will be keeping the CAT. i will basically just replace some tubing and put a magnaflow on it. i was thnking the same thing you were, straight pipe = better flow. but for some reason every exhaust i see has the bends. i will try to get under there again this weekend and take a better look. i guess if its possible i will just use straight pipe.
Old Dec 10, 2010 | 10:15 AM
sunman's Avatar
sunman
Agreed... less bends better flow.
It's my understanding that running one cat would be sufficient to pass emissions. I'll find out in a few more years
Old Dec 11, 2010 | 05:03 PM
CaMiniMe's Avatar
CaMiniMe
I'm guessing you don't have the second cat? Did it throw a code when it was removed? Also even if it passed emissions doesn't it have to pass a visible inspection
WestfaliaR
Aug 19, 2015 08:01 AM
elightbo
Aug 17, 2015 01:50 PM
Aug 12, 2015 01:24 PM
massmini03
Aug 12, 2015 11:19 AM
papawhiskey
Aug 10, 2015 09:31 PM
