Drivetrain '03 MCS Howling clutch
Old Nov 23, 2010 | 02:08 PM
TerryW's Avatar
TerryW
I am getting the howling clutch noise when it's cold outside. It goes away when it is warm and I can avoid it by riding the clutch a little more than normal in 1st gear. I read that I should replace my clutch and flywheel. So, that is on the docket for sometime in the future.
So, my questions are:
How long can I drive it this way?
How hard it this to DIY (never done one on any car)? And, given that I might not have all of the tools and skill, what should I expect to pay to have it done (in NorCal)?
Any good suggestions in a replacement clutch kit for a daily driver (good performance with reliability)?
Old Nov 23, 2010 | 04:31 PM
04Mini-S's Avatar
04Mini-S
I have the same issue. If I remember correctly, I read on here that the flywheel or something is warping (please correct me if I'm wrong)? I also read that it isn't anything crucial. Like you, I just take it easy.
Old Nov 24, 2010 | 09:30 AM
rbb's Avatar
rbb
glazed flywheel i think...I dont think you should be worried unless the noise bothers you apparently this doesnt taint driving.
Old Nov 24, 2010 | 09:44 AM
TerryW's Avatar
TerryW
Thanks @04-Mini-S and @rbb
Glad to hear it isn't crucial. Just annoying. I can deal with that.
Old Nov 24, 2010 | 11:22 PM
luseboy's Avatar
luseboy
Its a common problem. Mine started making the noise about 3 weeks after i got the car. I get it all the time. I found it to go away most of the time after i got a CAI, my theory on this is that basically i don't need to give her as much gas when coming from a stop. Anyways, its not a hiuge deal... that said my clutch is starting to slip a little bit, and has lost the stiffness. But, thats unrelated i believe, as it is probably time for a new clutch. Ps- the job is very expensive. I was quoted 13 hours by BrRacing in los gatos @ $115 an hour (before parts). Im personally gonna go the aftermarket route, and im thinking I'll go for the clutchmasters fx200. But i have read some bad reviews, so im also lookin at the spec stage 2. anyways, good luck!
-Austin
eliseo1981
Jan 28, 2021 02:45 PM
Sep 17, 2015 09:27 AM
Camaro108
Aug 25, 2015 02:44 PM
DiGiPiMP
Aug 24, 2015 11:04 AM
PrimePower
Aug 16, 2015 06:29 PM
