Drivetrain installed Alta CAI, service engine soon light
Old Nov 6, 2010 | 12:25 PM
804 mini's Avatar
804 mini
I installed the alta CAI and upon startup i got a service engine soon light. I have not yet got the code yet, but i was wondering if there was anything that i might have messed up in the install that i should check.
**Forgot to mention that i tried to start the car with one of the ECU plugs not seated. I but this is the cause, but i'd like to have a list of backup plans just in case.
Thanks,
Michael
Old Nov 6, 2010 | 02:04 PM
ggcadc's Avatar
ggcadc
needs more info, what year, what other mods, whats the mileage, what condition was the stock filter in?
depending on the adaptations your ecu has made, also depending on how badly your old filter was clogged, may be a lean code.... check the code and then post. modern ECUs make it pretty easy to tell whats wrong.
Old Nov 6, 2010 | 03:11 PM
804 mini's Avatar
804 mini
2004 MCS
No other mods
78k miles
old filter was due for a change but not terrible. I'm getting the code Monday.
Thanks,
Michael
Old Nov 6, 2010 | 06:56 PM
Uzzaw's Avatar
Uzzaw
I had the same error when I installed a new CAI on my 2002 MCS. Because the newer intake allows for better airflow you will get a lean or rich air/fuel mixture error code. As long as you don't hear any knocking or pinging it is an easy error code to re-set. If you have a Bentley Service Manual it will detail how to clear out the error code.
Old Nov 6, 2010 | 08:14 PM
804 mini's Avatar
804 mini
It cleared itself after 3 starts Hope it doesn't come back!
Old Nov 7, 2010 | 04:47 AM
AXO's Avatar
AXO
Its the Oxygen sensor. You should be fine.
Old Nov 9, 2010 | 12:57 PM
JumpingJackFlash's Avatar
JumpingJackFlash
+1 O2 sensor. I never had a code on my old '02 MCS, but I've had one on my '06 MCS. That was back in April 2010.
09R56
Nov 16, 2022 10:49 AM
Teh
Aug 22, 2022 04:37 AM
AWOL
Mar 28, 2016 10:51 AM
tr3y003
Oct 22, 2015 10:48 AM
M7Speed
Aug 6, 2015 01:48 PM
