Drivetrain WL: R53 RMW transplant
Old Oct 5, 2010 | 06:33 AM
  #26
JPMM's Avatar
JPMM
Originally Posted by CrazyIvan
That would be a very wise idea. it's much simpler to do it now than to tear it all back apart in a month or so.
Hi, I located a complete low mileage (20,000 miles)MCS drivetrain, I'm thinking about doing some light head work, Jesus? , a pulley and then doing a swap.
Old Oct 7, 2010 | 11:50 PM
  #27
R35P3CT DA M1N1's Avatar
R35P3CT DA M1N1
well received my new tuner bolts today for the wheels, so after work i did a quick test fit. sorry for the phone pic
as soon as i find where i misplaced my camera i will have lots of pics to update the thread with.
in other news, Jan said that my motor should be ready to ship out around monday. I also received some goodies from alta today. Hopefully this weekend i will get a spring compressor rented from an auto parts store and finish my suspension work. Well as much as i can since my lower control arms were out of stock when i ordered them.
Old Oct 7, 2010 | 11:53 PM
  #28
R35P3CT DA M1N1
Give jan a call, he will be able to give some great insight to what you will want. He sure knows his stuff.
Old Oct 8, 2010 | 01:07 PM
  #29
R35P3CT DA M1N1
My core shipped off to jan today.
Old Oct 12, 2010 | 12:25 AM
  #30
R35P3CT DA M1N1
well after searching for a couple of hours in my house, completely cleaning my whole room, and then finally finding my camera in between the cushions on my couch I can upload some more pictures.
just about ready to ship to Jan
received some new gauges from Summit Racing as well.
Old Oct 12, 2010 | 12:27 AM
  #31
R35P3CT DA M1N1
and to Minimarks:
It has taken a lot longer that i promised but here is why the work is being done in the driveway...
Old Oct 12, 2010 | 12:50 AM
  #32
R35P3CT DA M1N1
Craven tapless adapter for the oil pressure
also received some goodies from Alta Performance
front and rear endlinks
oil catch can
I also ordered some rear control arms, but they were out of stock at the time.
Old Oct 25, 2010 | 07:59 PM
  #33
R35P3CT DA M1N1
did my rear sway bar tonight before it started raining
it just kills me the difference, but then i did buy the 22mm one...
all installed
Old Oct 26, 2010 | 01:56 PM
  #34
nabeshin's Avatar
nabeshin
Functioning Lunatic
Seems like a bunch of great stuff. I wish someone sold a tap-less oil pressure thingy back when I did my gauges.
For the roads around Lincoln, full stiff on the 22mm is best. Just be sure not to lift off the throttle on the highway ramps north of town. If you are going with camber plates, in addition to your control arms, I can recommend some alignment settings.
Old Oct 26, 2010 | 06:21 PM
  #35
R35P3CT DA M1N1
Do you drive your MINI in the winter? That is my only concern with leaving the RSB on full stiff.
And Im assuming that you are talking about the i180-i80 interchange? I bet that can make for some fun driving
And I havent looked at any camber plates for the front yet. Which ones do you have?
Old Oct 26, 2010 | 07:05 PM
  #36
newbs49's Avatar
newbs49
Ditch that catch can and get a metal one. How long before the engine is back in the car.
Old Oct 26, 2010 | 07:16 PM
  #37
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
This is really fun to follow, you are doing this right. Keep up the good work!
I find, lowered minis with low profile tires are ridiculously TERRIBLE in the snow. You will want the sway bar on the stiffest setting because it is more fun. See what your camber is after the lowering springs. You may find that the camber is just fine for all around driving.
Also consider the high compresh pistons and meth! your car will be a monster-
Old Oct 26, 2010 | 07:22 PM
  #38
Black 'n Blue's Avatar
Black 'n Blue
Way to go Anthony!! Looks real good so far. Suppose you can get it done for the Fall run?
Old Oct 26, 2010 | 07:49 PM
  #39
R35P3CT DA M1N1
I have a set of 15" wheels that i will be buying blizzaks for the winter. After watching my buddies high powered cars make it through the winter with winter tires, I will never go a without them again.
Old Oct 26, 2010 | 07:51 PM
  #40
R35P3CT DA M1N1
I am going to try. I still have a lot to get done. And I am not sure how long it will take to get my exhaust redone. Has the date been decided yet?
and has your clubman been delivered yet?
Old Oct 26, 2010 | 07:59 PM
  #41
Black 'n Blue
Nov. 7, meet in Council Bluffs 8AM to motor over to the covered Bridges of Madison County (near Des Moines).
I picked up my Clubman 9/22, and I'm lovin' it! Should I stop up at Silverhawk after work (3:30) one of the days this week?
Old Oct 26, 2010 | 08:23 PM
  #42
R35P3CT DA M1N1
todays work:
I got the rear shocks off, have had the front struts off for awhile. I plan on getting the spring compressor from O'Reilly's on Thursday. Then I have 48 hours to get the springs changed out.
got my exhaust removed as well.
stock control arms off, top and bottom of course are the Alta arms. the top middle is a factory control arm and the bottom middle is the dealership's replacement arm. I bent both the drivers rear control arms in an accident so thats why they are different.
drivers side
pass side
it got dark on me then, so i moved into the garage and took a look at my transmission
got her cracked open, looks like fun in there
stock diff that NEEDS to get lost
and get replaced with this lsd
cam focused on the trans and not the magnet, but the shavings were not as bad as i would have thought
also, how many people have looked at the bottom of their gas tank? Because I would like to know who the unlucky souls where that received the last option there:
Old Oct 26, 2010 | 08:26 PM
  #43
R35P3CT DA M1N1
hmm, I will try and hurry. and I havent been working during the week lately with school going on, maybe I will have to come out to take a look at it one of these days tho
Old Oct 27, 2010 | 02:04 AM
  #44
R35P3CT DA M1N1
Does one that is soley made out of metal really have significant benefits? They alta has aluminum caps and a metal core inside the silicone tube.
Old Oct 27, 2010 | 02:35 PM
  #45
soccerbummer1104's Avatar
soccerbummer1104
haha, your metal sleeve actually fit.. mine ws way too long, and the sleeve will help at idle, but when you go n boost the can will still baloon out slightly...
plus it doesnt do anything on my car. I empty it once every year and get maybe a few ml each time.
Old Oct 29, 2010 | 10:30 AM
  #46
R35P3CT DA M1N1
Ya. Its more for just looks for me.
Old Oct 29, 2010 | 10:31 AM
  #47
R35P3CT DA M1N1
That's the main reason for me buying everything else from Alta. I want things to match. And I really like the red accent.
Old Oct 29, 2010 | 01:10 PM
  #48
R35P3CT DA M1N1
Update : motor shipped out on Wednesday. Header and other goodies yesterday. IM sO EXcIted!
Old Oct 29, 2010 | 05:54 PM
  #49
davisflyer's Avatar
davisflyer
AWESOME!!!!!
Old Oct 30, 2010 | 10:25 PM
  #50
R35P3CT DA M1N1
got some parts from Way today!
now just so everyone knows, I didnt order the cabrio braces for functionality. I just like the way they look in the engine bay and will help break up some of the red when i am done. And tensioner stop just in case. Bought an expensive damper, dont want it to get fudged up.
