Drivetrain The Official ALTA AccessPORT Thread
Old 08-12-2012, 04:46 PM
MotorMouth's Avatar
MotorMouth
MotorMouth is offline
Surely there are anough 2011+ models out there now to make it worth getting the AP to work with them =(
  #2677
Old 08-13-2012, 08:32 AM
ALTA_Chris's Avatar
ALTA_Chris
ALTA_Chris is offline
The modifications you mentioned would be fine to run a stage 3 map!
The list of parts needed for different stage maps can also be found on the AccessPORT page under the stages tab.
http://www.altaperformance.com/hardt...port-ecu-tuner
Originally Posted by amgcoupe
OMG this thread is HUGE!
Ok so let me get this straight from the searching I have done.
In order to run stage 2, I need:
FMIC
Catless DP
2.5" exhaust
What do I need for stage 3?
Also we only have 91 octane in this state.
  #2678
Old 08-13-2012, 02:18 PM
amgcoupe's Avatar
amgcoupe
amgcoupe is offline
Yeah I was looking at that but it isn't very clear. Plus stage 3 on the JCW says you did it with a 3" turbo back. So 2.5" is ok?
  #2679
Old 08-13-2012, 02:48 PM
ALTA_Chris's Avatar
ALTA_Chris
2.5 is OK if it's catless.
  #2680
Old 08-13-2012, 03:48 PM
amgcoupe's Avatar
amgcoupe
amgcoupe is offline
Awesome. Thanks!
  #2681
Old 08-13-2012, 03:52 PM
amgcoupe's Avatar
amgcoupe
amgcoupe is offline
BTW, why would you run stage 2 if you can run stage 3 with the same mods?
  #2682
Old 08-13-2012, 03:56 PM
GTECKO's Avatar
GTECKO
GTECKO is offline
I dont know if I ll be able to get my FMIC therefore Iam going to try stage too, wasnt sure if 2.5 was gunna be enough. RR downpipe+Q300 is good enough right ?
  #2683
Old 08-13-2012, 04:01 PM
ALTA_Chris's Avatar
ALTA_Chris
Yep those exhaust components will be fine to run stage 2 on until you get the FMIC.
  #2684
Old 08-13-2012, 04:03 PM
GTECKO's Avatar
GTECKO
GTECKO is offline
Stage 2 : turbo back exhaust, OR DP catless and 2.5 exhaust (in your case and mine) or full on 3" Alta exhaust.
Stage 3: same as above + FMIC
  #2685
Old 08-14-2012, 11:21 AM
KJs Toy's Avatar
KJs Toy
KJs Toy is offline
Update: April 2012
The ALTA AccessPORT does NOT work with 2011+ Cooper S Models.
The ALTA AccessPORT does work with 2007-2010 Copper S Models (Hardtop, Convertible, Clubman)
The ALTA AccessPORT does work with 2009-2012 JCW Models (Hardtop, Convertible,
Clubman, Coupe, Roadster)
????? Chris, can you tell me why can it work on a 2011 JCW, and not on a 2011"S" ? Also whats required for stage 2 on a JCW? I have a Alta CAI, hot tubes, Intercooler, blow off spring upgrade, but stock JCW exhaust. Thank You
  #2686
Old 08-14-2012, 11:24 AM
TerminalVelocity's Avatar
TerminalVelocity
TerminalVelocity is offline
2011 JCW models still use the N14 engine. 2011+ Cooper S models use the newer N18 engine.
  #2687
Old 08-14-2012, 12:00 PM
ALTA_Chris's Avatar
ALTA_Chris
Terminal is right. The JCW is using the same engine and ECU dating back to 2008. The MCS engine and ECU was changed in 2011, making the tuning totally different.
  #2688
Old 08-14-2012, 12:09 PM
akent's Avatar
akent
akent is offline
How does the tune affect the codes thrown for the O2 sensors with a catless system? Here in Texas, any OBD (Not ready) or code for emissions causes the annual inspection to fail.
  #2689
Old 08-14-2012, 12:31 PM
MiniCoopOH's Avatar
MiniCoopOH
MiniCoopOH is offline
AccessPORT 2012
Will Alta be coming out with an AccessPORT compatible with 2012 Mini Cooper S?
  #2690
Old 08-14-2012, 01:38 PM
ALTA_Chris's Avatar
ALTA_Chris
The AccessPORT does turn the CELs into the "not ready" mode. Normally you are allowed at least 1 or 2 "not ready" CELs. We haven't had any issues with this yet, if you want, we can make a map that turns them back on.
We don't have an ETA for that, sorry!
  #2691
Old 08-14-2012, 06:23 PM
KJs Toy's Avatar
KJs Toy
KJs Toy is offline
stage 2
Thanks Chris and Terminal. So whats needed for stage two? Is the stock JCW exhaust enough? ( along w/ Cai, IC, hot tube?) Have store credit and about to order my access port, but not sure which tune to get.. Thanks Again
  #2692
Old 08-14-2012, 06:54 PM
BlueToy's Avatar
BlueToy
BlueToy is offline
KJ-
Read back a few posts, Chris covers what's needed for Stage 2. As far as the maps go, the AP comes pre loaded with various Stage 1,2 and 3 maps. You select/run which ones are applicable to your mods/Mini. Also, the Alta site covers the AP very well...everything from the Stages/maps, dynos, etc., as well as a video on how to install. Hope this helps.
-Steven
  #2693
Old 08-14-2012, 07:08 PM
akent's Avatar
akent
akent is offline
When I ordered my AP from the website, I ordered from the JCW Coupe page, but the order showed the AP setup for an MCS on the checkout page.
I emailed them to say that I did in fact have a JCW. Chris called to confirm.
Apparently, the AP comes with maps for the MCS or the JCW, but not both.
Chris made sure that I had the proper maps.
Just an FYI.
Kent
  #2694
Old 08-14-2012, 07:15 PM
akent's Avatar
akent
akent is offline
After playing with the Stage 1 JCW maps, I think I have figured out what I would love to see.
I LOVE the linear map. I tried both the stock and the linear throttle Stage 1 92 octane maps.
What I find is that the stock throttle is far too touchy, just like the stock JCW is, to me. You touch the throttle and it has too much power too early on. It's hard to take off on an incline, for instance.
The linear throttle makes take off a breeze! It's very easy to take off smoothly. It's also nice that you get power as you push the throttle down, as it should be, again, to me.
What I would love to see is a close to stock power with the linear throttle in non-sport mode, then when you push the sport button, all heck breaks loose! Like the current linear throttle is all the time.
Just my wishes!
Kent
  #2695
Old 08-14-2012, 08:01 PM
Spice Orange JCW's Avatar
Spice Orange JCW
Spice Orange JCW is offline
Just an FYI.
Kent
I bought mine used from a guy with a MCS. As soon as I hooked it up it started to show the JCW maps. Maybe he just wanted to confirm it was a JCW since the Accessport does not work with the 2012 MCS.
  #2696
Old 08-14-2012, 08:08 PM
akent's Avatar
akent
akent is offline
In 2008, Texas changed the rules to where there is only one 'not ready' CEL allowed. The old rules allowed up to two 'not ready' CELs.
http://www.txdps.state.tx.us/rsd/vi/...tice092008.pdf
It is awesome to think we can go catless, "Legally"!
Kent
  #2697
Old 08-14-2012, 08:10 PM
akent's Avatar
akent
akent is offline
That makes sense!
Awesome!
Kent
  #2698
Old 08-14-2012, 08:11 PM
GTECKO's Avatar
GTECKO
GTECKO is offline
Mine is the opposite,the first map is a JCW and its not available,all the maps below show MCS lol I think it recognize what car you have before offering you the maps. Right?
  #2699
Old 08-15-2012, 08:17 AM
ALTA_Chris's Avatar
ALTA_Chris
The JCW exhaust will not be enough, you need an upgraded turbo back exhaust that replaces the cats in the factory downpipe. A 2.5" catless system or 3" with high flow cats will be good for stage 2.
With your setup, you would run stage 1 FMIC.
Just an FYI.
Kent
The AP comes preloaded with maps for the JCW and MCS. I just call to make sure you have a car that the AP is compatible with and let you know all the details of the maps.
You would see that if we made a custom map for a customer and he loaded it using the AP Manager. It's greyed out because it's not compatible with your MCS, but it shows up because the AP knows it's not a standard preloaded map.
  #2700
Old 08-15-2012, 11:08 AM
SooperCuperErik's Avatar
SooperCuperErik
SooperCuperErik is offline
This doesn't make much sense...
Running stage 3 at 100*F Ambient temperature would be the same as running Stage 2 in 60*F Ambient temperature...
All FMIC does is keep your intake temps down. Your ECU will adjust for IAT's...
Quick Reply: Drivetrain The Official ALTA AccessPORT Thread
