Drivetrain will this set up take to 200 hp to the ground??
Old Jul 14, 2010 | 07:50 AM
dutch2081's Avatar
dutch2081
I have a 2005 MCS it is stock other then a header and a high flow cat..
i would like to add a cold air intake a 15% pulley and the Snow meth cooling kit..
will this set up take me close or over 200 hp to the ground? If not then what would it take to get over 200 WHP?
thanx in advanced..
Old Jul 14, 2010 | 08:23 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Adding the pulley alone with those mods will get you right about 200hp. The Meth injection will def get the temps down to make more power and should get you over the 200hp, but I would personally think about simplier mods to get there, like tuning and cams. That way you don't always have to worry about having meth in the car.
Old Jul 14, 2010 | 03:52 PM
dutch2081's Avatar
dutch2081
true but the stage one kit from Snow performance is 340 bucks....comes with everything, and i will be using my rear windshield fluid tank to hold the meth...its also a good idea to run some sort of cooling system even with all the mods you can get...i am all about freeing up existing hp...
Old Jul 14, 2010 | 05:04 PM
MINI33342's Avatar
MINI33342
After the basic mods you list you will REALLY need a custom dyno tune to get the most out of the mods.
You will want to get some bigger injectors to get the most out of the pulley and tune also.
Old Jul 14, 2010 | 07:01 PM
dutch2081's Avatar
dutch2081
so how do i go about getting a custom tune?
Old Jul 14, 2010 | 08:11 PM
FlipSmini's Avatar
FlipSmini
There are a couple of vendors that offer remote tuning if you don't have a shops close by. I believe RMW (revolution mini works) and WMW both offer remote tunes.
tlr1000's Avatar
tlr1000
I have an 06 with a 15% pulley, Dinan CAI, & tune. I'm getting 193.7hp.
Old Jul 14, 2010 | 08:31 PM
JIMINNI's Avatar
JIMINNI
Well me being a realist or if you prefer a pessimist, those mods will not get you to 200whp. Now if you go to a forgiving dyno with a operator that wants you to have 200whp, then yes you will have it. But real world......think you will be short.
Old Jul 14, 2010 | 08:39 PM
Oxybluecoop's Avatar
Oxybluecoop
thanks in advance..
Mynes or RMW. Look no further!
Of course a 17% or 19% pulley would be a good starting point.
Old Jul 14, 2010 | 08:41 PM
WayMotorWorks
Vendor
Actually we've tuned several cars with just 15% pulley, intake, header and exhaust and got an average of 197-205 whp, on a dyna pak dyno. And those aren't forgiving dynos. I've had several people on the same dyno get their heart broken cause with a pulley they may have only been in the 155whp range. So it is very possible, just have to have the right combination.
Old Jul 15, 2010 | 05:24 AM
dutch2081's Avatar
dutch2081
i have a shop stones throw away that has the brand "Mustang Dyno" and it will read everything and it also can apply a load and take in fact the weather conditions....i am thinkin i have a pulley already beacause it measures from outside shoulder to shoulder 2 3/8 inch or 60 mm diameter....with the header and high flow cat and i just found out it has a mini mania foam panal filter and also has the M7 strut tower plates, which is a bonus....so this friday mornin its getting strapped down and i will post the numbers (boost,A/F, HP and Torque) before i touch the car it will be nice to know where i am at...
cheers
Old Jul 15, 2010 | 06:29 AM
AllBlack05S's Avatar
AllBlack05S
A simple look at the face of the pulley will tell you if its stock or not, none of the aftermarket pulleys look like they belong there. I posted the pulley measurements of the stock pulley on here somewhere. I'll try to find it for you.
Old Jul 15, 2010 | 06:38 AM
AllBlack05S
Here you may find this post useful in determining what you have pulley wise.
https://www.northamericanmotoring.co...23-post73.html
Old Jul 15, 2010 | 06:49 AM
dutch2081's Avatar
dutch2081
thanx alot thats great info...
so where is the measurement taken from?
is it from the outside edges like the lip that keeps the belt on or is it from the outside diameter of where the belt actually sits ( the groved part)?
thanx
Old Jul 15, 2010 | 07:40 AM
dutch2081's Avatar
dutch2081
ok i just found out it has a alta 17 % pulley installed on it (cool)
so with that and header high flow cat and a aftermarket filter (and who knows what else) i should have some decent power....what is the lbs of boost with a 17% pulley??
Old Jul 15, 2010 | 07:48 PM
AllBlack05S
measurement from the grooved surface on both high point I believe but its been a while. as to boost not sure I don't have a boost gauge beyond the meth controller which activates at boost levels.
Old Jul 16, 2010 | 05:28 PM
dutch2081's Avatar
dutch2081
ok so i got back from the dyno and the numbers are a little disapointing...
these are the mods i have...
17% pulley
cooler plugs
mini mania foam filter
the number read (weather corrected and with the weight of the car with my weight and full tank of gas inputted...
144 hp
127 lbs of torque
12 lbs of boost
a/f 12.00
somethings not right...i dunno
Old Jul 16, 2010 | 06:49 PM
Oxybluecoop
Dynapack? Dynojet? Mustang Dyno? 12psi at what RPM? If it's at redline then I agree somethings wrong.
Old Jul 16, 2010 | 06:52 PM
dutch2081's Avatar
dutch2081
mustang dyno...
i think th hp started to drop out at 6200 rpm then they let off...
i will have to check my sheet
Old Jul 16, 2010 | 07:51 PM
Rabidfox's Avatar
Rabidfox
Hmmm sounds very odd...we're very close in mods but I doubt very seriously a catback and a cai would net 3more psi and 60 more hp:
On that run:
17% pulley
Header
High flow possibly non-existent cat
Catback
CAI
Stock ignition
Old Jul 16, 2010 | 08:23 PM
dutch2081's Avatar
dutch2081
they tied into the vacume line that sits on top of the valve cover passenger side that has a tee with a cap on it...dunno if thats a good source
Old Jul 17, 2010 | 02:31 AM
FlipSmini's Avatar
FlipSmini
17% pulley
cooler plugs
144 hp
127 lbs of torque
12 lbs of boost
a/f 12.00
Is your belt slipping? Are you running cheep gas?
Old Jul 17, 2010 | 06:59 AM
dutch2081's Avatar
dutch2081
dunno if the belt is slipping...and i am running sunoco 94 octane
Old Jul 17, 2010 | 10:40 AM
MINI33342's Avatar
MINI33342
Sounds like a slipping/old belt and a possible boost leak.
Do you have the stock ic black connectors? These have been known to develop cracks and loose boost.
Old Jul 17, 2010 | 10:53 AM
dutch2081's Avatar
dutch2081
yes i do...new belt goin in on monday...if thats the problem i should feel the difference
