Drivetrain Problems after Supercharger/pulley replacement
Old Jun 27, 2010 | 06:04 PM
burberryed's Avatar
burberryed
I replaced the supercharger and added a 15% pulley on my 2004 Mini S this weekend. The idle is now going up to 1500 rpm and then drops to normal idle and repeats. I am getting codes P1109 and P1242 which Bentley says is: manifold pressure too high in deceleration and secondary upstream manifold air pressure sensor too high in deceleration. I have reset the ECU and the codes keep returning. What should I look for? Thanks for any help!!
Ed Burberry
Old Jun 27, 2010 | 06:46 PM
KC Jr 54's Avatar
KC Jr 54
By-pass valve may be sticking or is stuck. Dont know if you messed with anything on that end, but might be worth the gander. Do you hear any vacuum leaks maybe ?
jec1980's Avatar
jec1980
Ed Burberry
Sound to me like there is a leak somewhere or a sensor wasn't reconnected.
Old Sep 3, 2010 | 09:13 AM
slapshot591's Avatar
slapshot591
sounds like a sensor to me. Did the car ever throw you into limp mode?
Old Sep 3, 2010 | 09:23 AM
burberryed's Avatar
burberryed
No limp mode, it was one of the intercooler boots.
Old Mar 12, 2013 | 04:00 PM
RA082324's Avatar
RA082324
i just started my car with the intercooler removed. it made awful sounds so i turned it off right away. i replaced everything the way it should be and now its not idling properly. its very sputtery and low toned and bouncing up and down around 1k rpms. any ideas?
Old Mar 12, 2013 | 05:34 PM
burberryed's Avatar
burberryed
Check the rubber boots on the intercooler, they may have slipped when you tighten them causing an air leak. Hope this helps
Ed
Old Mar 12, 2013 | 05:41 PM
Da_Ghost's Avatar
Da_Ghost
Ed
Yep and you'll see soon enough if one of the intercooler boot isn't properly seated, the manifold will turn bright red
Old Mar 12, 2013 | 06:04 PM
RA082324's Avatar
RA082324
just took down and rebuilt everything, double checking as i went. everything is def sealed now and having the same problem. the engine light came on, blinked a few times, then stayed on. i dont have a scanner so i dont know the codes.
Old Mar 13, 2013 | 04:54 PM
RA082324's Avatar
RA082324
yes! just cleared the codes and its back to normal. dont know how or why that fixed it, but it did. what a relief!
Old Mar 14, 2013 | 01:13 AM
BlwnAway's Avatar
BlwnAway
Yup, either you corrected a problem that wasn't obvious or the ECU tried some radical compensation for the "start w/o I/C" & just took a little to go back to normal.
Old Mar 23, 2013 | 10:57 AM
usvibud's Avatar
usvibud
Did you undo the battery during install?
Old Mar 23, 2013 | 02:45 PM
RA082324's Avatar
RA082324
no i did not.
Old Mar 26, 2013 | 11:46 AM
usvibud's Avatar
usvibud
Try that. Undo battery and wait 30 minutes. Also I found that if I mix fuel grade I.e. 91 and 93 I get idle bounce. Try sticking to one or the other should smooth it out a bit more of the batter unplug doesn't work
Edit: guess you fixed it
danielbrookes_9
Oct 3, 2015 12:51 PM
Zettinger
Aug 25, 2015 04:04 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
