Drivetrain Ticking noise after cam install
Old Jun 24, 2010 | 11:16 PM
  #76
Professor's Avatar
Professor
Wait let me go back a few steps.
Did you remove the rockers from the rails? Or did you pick them up as one unit and leave them on the rail?
If you removed them from the rail and then put them back on with the rail flipped then maybe you blocked some oil ports?
Old Jun 25, 2010 | 02:11 AM
  #77
stevecars60's Avatar
stevecars60
Originally Posted by Barrettrw11
OK I did it again to try and listen real closely to where the noise was coming from and it is definitley coming from the middle where the oil is spraying from the bolt. I am 99% sure that's where it is.
My question is, is that normal for the oil to be spilling out of the bolt like that. If not what should I do to fix it?!?!?! The bolt is NOT loose at all!
I can't see well enough to tell - the rockers look dry, more dry than they should be. No oil should be spray from 1 bolt - oil pressure is lost to the rockers. There is a mismatch - either a bolt length, upside down rocker shaft, cam retainer cap, etc.... bottom line - the problem is in the assembly. The noise sounds like all the rockers.
I can see, from the vid, when the car was started, there appears to be an area of oil center IC that should not be there.
You can take everything appart without removing the cam gear
Old Jun 25, 2010 | 04:05 AM
  #78
Barrettrw11's Avatar
Barrettrw11
Ok well I am going to take it apart tonight and reasemble it. I took the entire rail off with the rockers on them. BTW Steve that oil you might be talking about center with the IC is probably the oil that is spraying from the bolt. If you are talking about whats on the IC its just the coil pack.
1. All the rocker rail bolts are the same right?
2. How do I tell if I put the rocker shaft upside down?
3. Which way are the cam retainer caps supposed to go. When I took them off I noticed there was a little cut out at the bottom of them but was only on one side. Does that cut out face the back or the front of the engine.
Old Jun 25, 2010 | 05:19 AM
  #79
onasled's Avatar
onasled
I believe all the rail bolts are the same size.
If you never removed the rockers from the rails then it's hard to mess this up. I don't even remove the bolts. If you removed the bolts then there is a chance you rotated the rail 180*. The rails have flat spots where the bolts go through and those should be facing upward so the bolt head sets in those flat spots. The intake side rail has notches that clear the spark plug tubes.
You can only put the cam bearing caps on one way and it looks like you have them in the right place, ..1-5 left to right.
Old Jun 25, 2010 | 05:53 AM
  #80
stevecars60
thanks onasled, can't remember anything any more.....
Barrett, I am talking about the oil not the coil pack
Old Jun 25, 2010 | 08:47 AM
  #81
Barrettrw11
@onasled- Thanks for the info!! I think I might have put the rails on upside down... Actually I am looking at the one picture and I can see that I have put the one rail on upside down! The rounded part is at the top. I am going to go out of the loop here and say that IS what is causing the noise.
Also Should the numbers on the cam bearing caps be upside down when I am looking at them from the front of the car?
Old Jun 25, 2010 | 08:51 AM
  #82
plasticknives's Avatar
plasticknives
I'm glad you're making headway!
The caps can only go on one way. One side is bigger than the other so if it's bolted up, you have it right.
I'm guessing since it was installed upside down and leaking, you weren't getting enough pressure to the lifters.
Now go fix it!
Old Jun 25, 2010 | 08:57 AM
  #83
onasled's Avatar
onasled
Yes, the numbers are upside down on the caps. As I say they only fit one way so it's impossible to mess that up if the cam is installed.
Hope Steve is the big winner here as that would be an easy fix.
Old Jun 25, 2010 | 09:09 AM
  #84
Barrettrw11
Yeah now I just have to get off work and fix the darn thing! I really hope that is what is causing it. I will let you guys know when I'm done. Thanks for all your help!!
Old Jun 25, 2010 | 09:15 AM
  #85
stevecars60
So far so good.
There is no doubt about the problem - you found it - you'll fix it ... have faith.....
Old Jun 25, 2010 | 09:19 AM
  #86
stevecars60
This was everyones effort - I just wanted the VC off = way too much clatter for a chain..... I hope this is easy...
Old Jun 25, 2010 | 02:02 PM
  #87
Barrettrw11
Good news and bad news!
The good news is that the noise has stopped and everything is running smoothly!!!!
The bad news is there is some smoke coming from the engine. I think it is because of the oil that had splashed ALL over the engine from when I ran it with the valve cover off. It looks like it is coming from the heat shield covering the 4 tubes (header) leading into the head.
BTW I did an oil change right after I changed the rail around because of the oil I had lost from running with the valve cover off.
Old Jun 25, 2010 | 02:04 PM
  #88
plasticknives
Glad you figured it out. I wouldn't worry about the burning oil, it's most likely what you said. Give it some time to burn off.
Old Jun 25, 2010 | 02:33 PM
  #89
Barrettrw11
I'd just like to thank everyone who has helped me out on this. Obviously I was the idiot and put the rail on upside down, but you guys helped me to figure it out. I wish I could buy everyone some wings and beer for helping me lol.
However let this be a lesson learned and I hope people who are thinking of doing a cam swap read this and don't do the same thing I did!
Thanks again guys!
Old Jun 25, 2010 | 03:35 PM
  #90
onasled's Avatar
onasled
OOoohhhh, ...wings and brew!!!
Haaa. Cool man, really glad your squared away.And yea, not to worry about the smoke .......I don't think.
Old Jun 25, 2010 | 03:42 PM
  #91
stevecars60
Ya done good
Thanks again guys!
If you get a chance, go to the car wash & wash the engine room - It takes a long time to rid the smell from the interior. Tape & bag the ecu 1st.....
In the mean time, make a couple of ICE COLD, big letters needed, Margaritas... sit on the veranda & enjoy - you earned it
Old Jun 25, 2010 | 04:01 PM
  #92
Barrettrw11
Oh don't worry I bought a 12 pack for tonight.
I actually don't have any smell in the interior and I believe it is done smoking now. I am very excited now! However I do have some major cleaning to do in the engine compartment. I did already spray under the engine with a hose.
Thanks again!
PS. Now its time for a RMW tune!!!
Old Jun 25, 2010 | 06:16 PM
  #93
CRoth's Avatar
CRoth
Glad you worked it out! This thread will help me remember not to make the same mistakes you did, lol. Time for me to call Jan and order my cam and injectors.
Wish me luck!
Chad
Old Jun 25, 2010 | 06:46 PM
  #94
CRoth's Avatar
CRoth
How noticeable was the power difference with the cam install?
Old Jun 25, 2010 | 09:24 PM
  #95
Barrettrw11
Omg the power is just amazing. I know you wont be disappointed! All I can say is I love 2nd and 3rd gear more than ever.
I think with doing all this work this week I could probably swap a cam in under an hour and a half.
Good luck and let us know how you like it!
Old Jun 26, 2010 | 07:31 PM
  #96
davisflyer's Avatar
davisflyer
Absolutely!! Just wait and see how much more fun than it is than now after the tune. I speak from experience! I gained 23 whp from the tune!!!
Old Jun 26, 2010 | 07:32 PM
  #97
davisflyer's Avatar
davisflyer
Old Jun 26, 2010 | 08:26 PM
  #98
Barrettrw11
Yeah I just have to wait for him to come around PA or the surrounding states.
adrchn
Aug 13, 2019 02:11 AM
emulajavi
Dec 24, 2018 09:15 AM
maestro39
Oct 27, 2015 02:38 PM
squawSkiBum
Oct 2, 2015 09:21 AM
