Drivetrain Crank Pulley Help!:confused:
Old Jun 6, 2010 | 05:17 PM
minikr56's Avatar
minikr56
Well I bought a Crank pulley from Alta a couple of months ago and when I went to install it the instructions had a different size wrench than the actual and i cant get to the belt tensioner with a normal wrench. Is there some kind of special tool to remove the belt?
If anyone has done this mod, can you tell me how to do it?
BTW my r56 is a 2009
Carlos
Old Jun 6, 2010 | 05:53 PM
ZippyNH's Avatar
ZippyNH
Are you sure the crank pulley is for a gen2 car (turbo)?
When I have heard about crank pulley "upgraded" they are mostly for gen1 (supercharged) cars.
Old Jun 6, 2010 | 05:56 PM
minikr56's Avatar
minikr56
yeah the crank pulley is for the turbo version and it comes with instructions for the 07 R56. I dont know if they are different tho.
Old Jun 6, 2010 | 06:20 PM
drewstermalloy's Avatar
drewstermalloy
It's the same pulley for the turbo and non-turbo 2nd gen MINIs..
Old Jun 6, 2010 | 06:41 PM
Porthos's Avatar
Porthos
Yes there are crank pulleys for the 2nd gen and the part you are thinking about is the supercharger pulley which is normally smaller. Is the pulley the same size as the stock one? And if I am not mistaken there is a tool for the tensioner.
Old Jun 7, 2010 | 06:32 AM
ZippyNH's Avatar
ZippyNH
Sorry for my lack of knowledge with gen2 cars...I know with the gen1 cabrio's having been in production till '08, sometimes buying parts can get confusing.
Safe to say it is a lightweight pully then (since there would zero advantages to oversizing it, but perhaps a slight advantage to undersizing it from running the accesasorys slightly slower (alternator+ac compressor)). I know on a gen1 a special pulley puller is used (modified from a standard), for the crank pulley (different from the SC pulley).
Old Jun 7, 2010 | 07:53 AM
countryboyshane's Avatar
countryboyshane
The whole point of the lightweight crank pulley is to amount of inertia driven off the front of the engine. It might not be a noticeable difference, but every bit helps. Next, remove that AC compressor!
Old Jun 7, 2010 | 04:38 PM
minikr56's Avatar
minikr56
yeah but the things is that i cant get the belt tensioner off!!! I cant do it with a normal wrench...... has anyone done this before??
Old Jun 7, 2010 | 04:44 PM
chakraj's Avatar
chakraj
You need a special tensioner tool.
Old Jun 7, 2010 | 05:08 PM
minikr56's Avatar
minikr56
do you know where to get it?
elverado
Jan 18, 2022 02:51 AM
BernieCoop
Sep 10, 2021 03:15 AM
daviday
Sep 25, 2015 01:31 AM
Nicefeet
Sep 24, 2015 06:53 PM
larryd96
11
Sep 8, 2015 05:01 AM
