Drivetrain Here is why you should clean your MINI with Seafoam.
Old May 28, 2010 | 03:51 PM
  #26
lilbit0920's Avatar
lilbit0920
Cool man I jus bought an 2006 Im gonna give this a try. thanks for th info. Im new to this site but have found a lot of great information. Thanks to all of you'
Old May 28, 2010 | 09:51 PM
  #27
soccerbummer1104's Avatar
soccerbummer1104
worked for me. i had a super rough idle. if i stepped on my gas after cold crank it would actually go down in rpm's and then go up
did this today, didnt get huge clouds, but i got some black smoke definitely and its running a lot smoother now.
oh, and yes advance has it (or at least the store i work at has it)
Old Jun 7, 2010 | 11:49 PM
  #28
mikemc's Avatar
mikemc
kragen/ o'reily had them buy 2 get 1 free...3 for about 20 bucks...
Old Jun 8, 2010 | 09:36 AM
  #29
Professor's Avatar
Professor
Originally Posted by stevecars60
[FONT=Georgia, sans-serif]Right from the horse http://www.seafoamsales.com/gasoline-engine-faqs.html of ......
The most frequently asked question about using Sea Foam is as follows: “After using Sea Foam in my oil, fuel, or through the vacuum line (to clean carbon from the combustion chamber) do I need to change my oil?” The short answer is: No you don’t have to change your oil after using Sea Foam in any application.
When using Sea Foam in your fuel or through the vacuum line for carbon cleaning your oil does not need to be changed. Using Sea Foam in your oil, at 1 ½ ounces per quart, is a safe way to clean a crankcase, free up rings or free up sticky lifters as you drive. Sea Foam is not a chemical engine flush and therefore, it will not damage internal engine components or plug the oil pick up screen. Sea Foam is a pure petroleum blend with no chemical additives and is safe for long term cleaning or short term pre-service cleaning.
Sea Foam is a blend of highly refined additive oils and is compatible with all motor oils including synthetics. It is safe for all internal engine components and will not affect any seals, gaskets or o-rings. Sea Foam cleans oil deposits and varnish in your crankcase by safely/slowly re liquefying the old oil residue so contaminants may flow and be filtered. The longer Sea Foam is in your oil the cleaner your crankcase will become. When adding Sea Foam to clean oil, for long term maintenance cleaning, you must check your oil periodically for color and clarity, when your oil looks dirty change it. Because you added cleaning oil (Sea Foam) to your oil you may have to change oil before the expected service interval.
When adding Sea Foam to dirty oil before an oil change, for best results use 1 ½ ounces per quart of oil at least 100 miles before oil is changed.
[/FONT]
LOL spot on! Glad the BS change your oil crap is not spreading around this site like wild fire because one Moderator says so. . What person with any common knowledge of how an engine works would make such a silly assumption?!
Old Jun 8, 2010 | 10:04 AM
  #30
ZippyNH's Avatar
ZippyNH
I think it comes from the liquid can of seafoam and the instructions on it...the split the can 3 ways, with 1/3 in the gas, 1/3 in the oil, and 1/3 in the intake, then change the oil...I am in agreement though, if you put it in your gas or intake, then no oil change is needed. But it us printed on the can of liquid seafoam...so it is easy to combine them accidently, especially when typing in a hurry!!
Old Jun 8, 2010 | 10:17 AM
  #31
Motor On's Avatar
Motor On
The seafoam instructions also say....
http://www.seafoamsales.com/how-to-u...treatment.html
To clean oil rings and lifters, add 1½ oz. Sea Foam to each quart of oil. Sea Foam will slowly re-liquefy the old oil varnish residue that builds up on lifters and rings and prevents them from functioning normally. This process can be done as part of a pre service cleaning by adding the Sea Foam to the oil at least 30 miles before the next oil change interval. OR it can be done as a preventative maintenance process without changing the oil. You can leave Sea Foam in the oil indefinitely as long as the oil is clean. The addition of a high-detergent oil like Sea Foam may cause the oil to become dirty faster than normal as buildup oil residue and contamination are cleaned. Check the oil at regular intervals and when it gets dirty, change it.
It's not that people are lakcing common knowledge, it's that people are doing the process that's appropriate for their desired result, BS.
And adding Seafoam to the oil will make the oil get dirty faster, requiring an oil change sooner that the original planned interval.
Old Jun 8, 2010 | 01:14 PM
  #32
chisss's Avatar
chisss
If you put it in the gas tank you will not get any smoke, it's cleaning the injectors and that's all. you are pretty much diluting the seafoam.
you will get nasty smoke when doing the PCV method tho.
Old Jun 9, 2010 | 07:51 PM
  #33
jonasandezekiel's Avatar
jonasandezekiel
Originally Posted by MrCooperS
Cleaned out my MINI today for the first time with Seafoam at 77K miles. Dirty smoke was expected but there was no smoke. We thought the engine was clean. Then...
Off topic question, but what is your exhaust? Love the sound.
Old Jun 9, 2010 | 08:06 PM
  #34
MrCooperS's Avatar
MrCooperS
Moderator
It's a Supersprint. It's not the full catback (stock downpipe).
Old Jun 10, 2010 | 05:48 AM
  #35
ZippyNH's Avatar
ZippyNH
You mean stock header....downpipes are on Turbo cars!
Does sound good! Good to hear the "treatment" worked well...
Good luck on scoring rear tail lights to replace the broken ones....
I'd check WayMotorWorks by phone...he parts out wrecks, and has some parts pretty cheap not on his website that might be what you need.
Old Jun 29, 2010 | 10:25 PM
  #36
TBangin23's Avatar
TBangin23
okay... so if i wanna run this through the PCV hose. do i keep the car running? i'm confused, and i really need this done. (isn't ideling very well at stop signs, especially with the A/C on. lol.) anyone have DETAILED, step by step directions i could follow? :[
Old Jun 29, 2010 | 10:31 PM
  #37
MrCooperS's Avatar
MrCooperS
Moderator
If you read the posts, you'll find that this is a 2 man job and the engine is running while you do this.
Old Jun 29, 2010 | 10:36 PM
  #38
TBangin23's Avatar
TBangin23
alright, so then when your pouring, or spaying this in.. do you keep the tube pinched at the lower end of it to let the fluid just sit in the tube? or do you just release pinching once the fluid is starting to get poured or sprayed? and while you doing whatever, is the other person in the car reving or anything, or just in there incase it stalls?
Old Jun 30, 2010 | 05:27 PM
  #39
Mr Silverblood's Avatar
Mr Silverblood
Next time I see you, I'd like to do this to the Monstah.
Care to help a friend? :D
Old Jun 30, 2010 | 07:10 PM
  #40
ZippyNH's Avatar
ZippyNH
Just pour it in slow....or spray it as it comes out....It CAN be done alone, but a helper...er...helps!
If you pinch off the hose a bit, you will be less likely to get a code....the computer will read a HUGE vac leak with the PCV hose off.....
Old Jun 30, 2010 | 11:14 PM
  #41
CMD141's Avatar
CMD141
I've done it by myself, propped a 5 lb. weight against the gas pedal to keep the RPMs @ 2k. Works like a charm if no one is around to lend a foot.
Old Jun 30, 2010 | 11:30 PM
  #42
TBangin23's Avatar
TBangin23
So I did this yesterday, and now my service engine soon lights on... :(
Old Jun 30, 2010 | 11:36 PM
  #43
MrCooperS's Avatar
MrCooperS
Moderator
Disconnect the battery and reconnect it and see if that resets the code. It's probably for a vacuum leak and if your PCV hose is connected back to the engine the code should go away (?)
  #44
MrCooperS's Avatar
MrCooperS
Moderator
For sure.
Old Jul 1, 2010 | 07:28 PM
  #45
jonasandezekiel
So are you saying that you SHOULD change the oil after using it, Zip?
Old Jul 1, 2010 | 07:47 PM
  #46
Agarwaen's Avatar
Agarwaen
Old Jul 2, 2010 | 08:32 AM
  #47
Motor On's Avatar
Motor On
This process (adding Seafoam to oil) can be done as part of a pre service cleaning by adding the Sea Foam to the oil at least 30 miles before the next oil change interval.
As linked to from the Seafoam website in post #31; and I find it to be generally good advice with these cars as I never seen one that's gone the full service interval before the oil was so dirty that it needed changing.
Old Jul 2, 2010 | 10:10 AM
  #48
Sidmind's Avatar
Sidmind
I purchased the spray can yesterday.
removed the hose from the PCV valve while it was at idle.
no problem with trying to die.
I sprayed almost a half a can into the rubber hose, without pinching it.
it never once even bogged down,
I let it sit about 30 minutes with the engine off, and then did the high RPM + drive around thing. (no smoke ever)
did I do something wrong? or was that 2000 miles I drove last week using 91 to 93 octane gas enough to clean it out?
Old Jul 2, 2010 | 12:21 PM
  #49
TBangin23's Avatar
TBangin23
So used mine about 400 miles ago. And the jitters are back when I use my A/C and I'm stopped at a stop sign or red light. Was it not cleaned out enough? Should I try again or is this just normal?
Old Jul 2, 2010 | 12:25 PM
  #50
MrCooperS's Avatar
MrCooperS
Moderator
This is pretty normal to hear from the MINI community.
