Drivetrain Here is why you should clean your MINI with Seafoam.
I'll look in to it. Send a PM
That would work, if Minis weren't direct-injected. Fuel never touches the intake valves. Oooops, that's just 2nd gens. So yeah, let her rip.
Last edited by Project Mangler; Aug 21, 2010 at 12:41 AM. Reason: correct a mistake
No EGR
What confuses me about this phenomenon is that the MINI does not use an EGR (exhaust gas recirculation) system at least not on the R53. This is typically the source of all the carbon that ends up in the intake system mixed with the oil from the PCV system. The carbon that goes into the crankcase from blowby is absorbed by the oil so little to no carbon should be acquired from the PCV system.
Just a realization I came to. Thought I would share this and see what people have to say.
I have used Seafoam and it makes a hellofa difference, but this didn't dawn on me till now.
People with oil catch cans, please provide feedback as to if the Seafoam treatment does much to your engines. Thank you.
Car was taking twice as long to start..
I finally did the seafoam!!
Here is a video :]
I wasnt going to rev it much, but then I watched your videos.... hahaha....
Poured into PCV hose, oil cap, and gas tank while engine was off.
Waited one hour.. Car finally started with the help of my foot on the gas pedal full throttle.
Started right up the second time..
Plenty of smoke filled around my car as well as my yard , ha ha ...
http://www.facebook.com/video/video....31446755&saved
Here is a video :]
No smoke at all while pouring the seafoam directly into the throttle for 2 or 3 minutes. The car was hot so if it was seafoam burning, I don't see why it wouldn't start from the minute I started pouring. After waiting 20 minutes, it was a cloud factory.
Here is a video :]
Here is a video :]
be sure to change your oil soon, seafoam in the crankcase for too long = bad day
I know there's a difference of opinion with regard to getting an oil change after just using it through the PCV, but surely you need to get an oil change after putting it directly in the oil? I think the instructions even state this (it's been a while).
- drew
- drew
Using Seafoam
Cleaning Engine Sludge From the Crank Case
To clean built-up oil residues and contamination from the crank case, add 1½ oz. Sea Foam to each quart of engine oil.
Sea Foam will slowly re-liquefy residues and suspend contaminants for easy removal.
Change oil and replace filter when dirty.
Cleaning Lifters and Oil Rings
To clean oil rings and lifters, add 1½ oz. Sea Foam to each quart of oil. Sea Foam will slowly re-liquefy the old oil varnish residue that builds up
on lifters and rings and prevents them from functioning normally. This process can be done as part of a pre service cleaning by adding the Sea Foam to the oil at least 30 miles before the next oil change interval.
OR it can be done as a preventative maintenance process without changing the oil. You can leave Sea Foam in the oil indefinitely
as long as the oil is clean. The addition of a high-detergent oil like Sea Foam may cause the oil to become dirty faster than normal
as buildup oil residue and contamination are cleaned.
Check the oil at regular intervals and when it gets dirty, change it.
Hope this helps...
So I ran half a bottle of Seafoam through the PCV valve and waited an hour before I started the mini back up. When I went to rev the engine, not a puff of smoke came out! It can't be that clean because it's an '03 with 80,000+ miles on it.. is there something wrong?
If you are using a top tier gasoline you will not gain much of anything with a seafoam treatment as the R53 is not a direct-injection engine. The intake valves do not get carboned up like the R56 does.
Since ive had the car (Febuary 2010) ive been using mid to high grade fuel, but im pretty sure the owner before me didnt. Sometimes it dips below 700 RPM when idling and it also kinda sputters at times like when im stopped at a light. Im hoping this corrects the problem cause ive also ran fuel injector cleaners in the gas too.
theateist
Jul 2, 2017 02:21 PM
phrza81
Oct 10, 2015 11:37 PM
