Drivetrain my oil catch can recommendation
Old May 25, 2010 | 09:25 PM
hoonpv's Avatar
hoonpv
I ran my car with homedepot-built ($20) occ for a while, and i got tired of draining the oil so often due to small housing.
so I looked around for oil catch cans, specifically with metal housing and internal filter, but most importantly the quality had to be good and also affordable
I first looked at M7's and although they look great, the price is very steep ($129 listed) and even at that price, they lack internal filtering device, so you have to somehow figure out a way to collect the oil vapor when it goes into the can.
So after days of searching online, I stumbled into Simota OCC.
http://simotausa.com/simotaoilcatchcans.aspx
First off, it's very affordable for what it is. Aluminum ones sell for $65 bucks. and it has internal filter (mesh) to properly collect oil vapors. And judging by my shipment today, the quality is very very good and sturdy. Even the nipples are aluminum.
All you need to buy is some fuel lines (5-10 bucks at the most) and you have a proper catchcan for $50+ less than M7's.
And I have to say their customer service is top notch too. when requested extra nipple for the can, they responded immediately and shipped it the very next day.
Hope this saves some time for people looking what to get.
Drew-
Old May 26, 2010 | 12:18 AM
FlzRider's Avatar
FlzRider
Looks good. Mount it up and post some pics.
Old May 26, 2010 | 04:22 AM
Porthos's Avatar
Porthos
Pics of install when you get it on please.
Old May 26, 2010 | 06:11 AM
Fatherdeth's Avatar
Fatherdeth
Thanks!!!
Old May 26, 2010 | 01:37 PM
hoonpv's Avatar
hoonpv
all aluminum.
you can see the filter element inside the can.
I know this isn't perfect but i am suprised at how strong the velcro is holding up the can. it's literally rock solid.
but i am going to find some L brackets and so on in the future if it fails to secure it.
how I route it.
Old May 26, 2010 | 01:59 PM
Mini Mee's Avatar
Mini Mee
why did you need the extra nipple? can you show a pic of the drain? and a pic of it in it's final installed place
Old May 26, 2010 | 02:40 PM
hoonpv's Avatar
hoonpv
and to answer your questions, I lost one of the nipples while i was checking things out.
and the drain is at the bottom center of the can. you have to use a hex screw to unbolt it and drain it out
Old May 26, 2010 | 02:48 PM
Mini Mee's Avatar
Mini Mee
well, it looks like it belongs there....
Old May 26, 2010 | 03:10 PM
Mini Mee's Avatar
Mini Mee
Did it not come with the mounting brackets shown on their site or did they just not work out where you mounted it.
Old May 26, 2010 | 03:44 PM
hoonpv's Avatar
hoonpv
it came with all the mounting hardware and the blue hose but I just got lazy with figuring out how to mount it using the hardware. as you know this is a universal oil catch can so there is no instruction on how and where to mount it.
Old May 28, 2010 | 10:56 PM
jonasandezekiel's Avatar
jonasandezekiel
It even comes in a very cool looking carbon fiber for only 79.00-- although I don't know how you could ever SEE the difference from the aluminum version once its installed.
Old May 28, 2010 | 11:00 PM
hoonpv's Avatar
hoonpv
yep, they have a CF version too
i just went with the red one because i have red strut mount guards.
Old May 29, 2010 | 09:08 AM
GumbyLara's Avatar
GumbyLara
Looks great! And it seems like a steal! I was going to do the Home Depot OCC but I went to Lowe's and they had one twice the size! It was like 20 bucks and it has a metal casing on it. Works great but I like the one you hav a lot! I would make that bracket asap! There is a lot of vibration under that bonnet! I originally had a turn valve on it to let the oil drip out but I put a cap on it since the metal casing screws into the top so it's very easy to change! I might check out the one you have, how is it holding up? Catching a good amount of oil? Do you have to take it out to drain the oil? (figured that's why you used velcro?) thanks for the reccomendation!
Here's mine!
https://www.northamericanmotoring.co...p-img_0882.jpg
https://www.northamericanmotoring.co...p-img_0883.jpg
https://www.northamericanmotoring.co...p-img_0884.jpg
Old Jun 14, 2010 | 02:21 PM
hoonpv's Avatar
hoonpv
It's been about 1000 miles and it's catching oil really good.
I think it works even better than the diy-ed occ. I wasn't catching this amount w/ previous one.
Also the mount is holding up nicely. no problem here!
Drew-
Old Jun 14, 2010 | 02:58 PM
jonasandezekiel
Drew-
I have to get one ASAP. I have 13k on my '05....would you recommend cleaning out the intercooler and intake?
Old Jun 14, 2010 | 04:16 PM
hoonpv's Avatar
hoonpv
I would definitely clean the intercooler to give it a good fresh start.
And it's really easy to do: just put the intercooler vertically over a bucket and spray bunch of brake cleaner inside and let it drain and dry for 30 mins or so.
I clean the intake filter every 15-20k miles or so
Old Jun 14, 2010 | 04:35 PM
jonasandezekiel
Dumb question...Do you mean the air filter? Is there anywhere else that gets gummed up with oil other than the intercooler?
Old Jun 14, 2010 | 04:40 PM
hoonpv's Avatar
hoonpv
Not really. Only place I can think of is the intercooler and the rubber couplers on both sides.
Old Jun 14, 2010 | 04:43 PM
jonasandezekiel
Maybe the horns on both sides too.....Ok cool, thanks.
Old Jun 19, 2010 | 09:24 AM
coopselt's Avatar
coopselt
From: Camano Island, WA, but wish was still Oahu, Hawaii
Anyone out there use the Steeda oil separator?
http://www.steeda.com/products/steeda_oil_separator.php
Or, even using a stock BMW part?
http://www.realoem.com/bmw/showparts...91&hg=11&fg=15
or
http://www.realoem.com/bmw/showparts...94&hg=11&fg=15
Old Jun 19, 2010 | 09:33 AM
jonasandezekiel
Originally Posted by coopselt
The Steeda looks pretty cool. It looks like they have a mesh type filter on it to catch oil vapor that might get drawn back into the engine. It looks tiny though, and pricey for what it is.
Old Jun 19, 2010 | 11:31 AM
hoonpv's Avatar
hoonpv
that steeda one looks exactly like the ones that home depot sells. which sells for 20-30 dollars. I'm not sure why steeda doubled their price.
Old Jun 19, 2010 | 02:33 PM
jonasandezekiel
Home Depot? Never saw it....
Old Jun 19, 2010 | 03:38 PM
hoonpv's Avatar
hoonpv
go ask for air/oil separator and they will lead you to that one.
hell, print out the picture and show 'em
Old Jun 19, 2010 | 07:10 PM
KC Jr 54's Avatar
KC Jr 54
Replace the fuel line you used w/ the blue line supplied. The fuel line, especially once soaked w/ oil, will collapse under suction. That Simota is good looking piece, especially considering the price.
