Drivetrain intercooler bellows/couplers sliding
Old May 23, 2010 | 01:30 PM
O.C.abrio's Avatar
O.C.abrio
my driver's side intercooler bellows slides on the horn. doesn't seem to pop entirely off when observed while someone else revs the car. i've cleaned up oil on the mating surfaces and torqued the clamp screws to spec. is this normal? boost still hits 15-16 psi and seems to drive fine.
i'm thinking it's normal and that's why the stock intercooler cover hides the driver's side connection (to avoid concern in this area). my passenger side bellows doesn't move.
also, Mini Mania describes for their intercooler bellows upgrade:
Eliminate the chance of a boost leak from your factory intercooler bellows.
The stock bellows connects the intercooler to the plenums and works well under stock boost. Increasing the boost with a pulley upgrade greatly increases the stress on the bellows. Just have your partner blip the throttle while you watch your stock bellows and you will see. Under spirited driving conditions, it is possible for the stock bellows to work loose causing a leak - creating havoc with the computer trying to maintain equilibrium.
anyone else notice sliding of their intercooler bellows/couplers? looking for feedback before buying a replacement.
FYI: '05 MCS cabrio 50K mi, 15% pulley
pics below. also found a similar picture on an aftermarket silicone coupler mounted on the passenger side.
Attached Thumbnails intercooler bellows/couplers sliding-alta-ic-coupler2.jpg   intercooler bellows/couplers sliding-driverside.jpg   intercooler bellows/couplers sliding-driverside2.jpg
Old May 23, 2010 | 08:54 PM
O.C.abrio's Avatar
O.C.abrio
bump
Anyone have knowlege of above? Seems like if I tighten the bolt clamps the bellows/coupler slide also.
Old May 23, 2010 | 10:03 PM
plasticknives's Avatar
plasticknives
Yep. Was losing about 3-4 psi from that happening too!
What you need to do is take a file and grind down the clamps (where the arrows are) about a 1/16" each. This will make them clamp tighter. What I also did was scuff up the surface on the IC horns with some 220 grit. Worked like a charm. Also be sure to wipe off all oil prior to installing.
intercooler bellows/couplers sliding-hzrfs.jpg
Old May 23, 2010 | 10:16 PM
D-MAN's Avatar
D-MAN
I grinded mine down years ago - and have had no problems
Old May 24, 2010 | 07:10 AM
O.C.abrio's Avatar
O.C.abrio
thanks!
appreciate the help, plasticknives and D-MAN!
Old Aug 13, 2010 | 06:56 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep - thought I didn't have any visible boot slippage, I have been losing a few PSI of boost lately and just ground down my clamps last night. Early testing seems to show improvement.
My bench belt sander made QUICK and clean work of the clamp mod.
Old Aug 13, 2010 | 09:51 AM
Professor's Avatar
Professor
I need to give this a go I think.
Old Aug 13, 2010 | 10:39 AM
ZippyNH's Avatar
ZippyNH
you might want to consider getting a new set of boots....about $50 I think...the rubber might have shrunk...and that is why you cannot get the clamps on tight enough....they might be ready to split.
Old Aug 13, 2010 | 01:16 PM
BlimeyCabrio
My boots are about a year old. And are not split.
Someone mentioned that the later manufactured boots appeared to be thinner rubber than the early ones... perhaps leading to some clamping/sealing issues?
Old Aug 13, 2010 | 08:20 PM
minimarks's Avatar
minimarks
Put a set of Sneed's boots on mine and no problems sense! Is it just the pics or me but in every above pic the boots are not position correctly, fully seated against the flange on the IC horn?
Old Aug 13, 2010 | 08:21 PM
minimarks's Avatar
minimarks
Edit , double post.
Old Aug 14, 2010 | 06:08 AM
jhiggs26's Avatar
jhiggs26
No need to file/sand the clamps. If you take too much off you run the risk of slicing the bellows if you over torque them.
Minimarks has it right-the clamp is not positioned correctly on the horn. Center the intercooler then clamp away making sure your clamps are clamping the intercooler and the horns, not voids.
Jeremy
Old Aug 14, 2010 | 08:31 AM
Professor's Avatar
Professor
Guess you guys missed the point of the post?
That are all saying they have clamped the boots all the way against the horns, but they have slipped tot he position that are in the pics.
It does not seem to be an issue of them not placing the boot int he wrong position, rather over time its moving to the wrong position.
Old Aug 14, 2010 | 08:56 AM
minimarks's Avatar
minimarks
If it has slid that much to the left, the IC should be stuffed up against the other side. Given the direction the air flows it didn't blow the IC that way but pressure pushed it back. Best to position the boots against the horns and center the IC to those, then clamp both sides down. If its still slipping then maybe new rubber and/or some sanding is in order. 2 cents
Old Aug 14, 2010 | 10:42 PM
luseboy's Avatar
luseboy
i noticed this on mine, but i also realized that my couplers are cracking, and need replacing. Should have some alta couplers in the mail on monday!
Old Aug 16, 2010 | 09:15 PM
O.C.abrio's Avatar
O.C.abrio
it worked for me
Post#3 was the solution for me!
I had tried "stuffing" the intercooler and bellows toward the driver's side, but you can see how shiny/smooth the intercooler horn looks at the clamping surface. It kept sliding! My passenger side intercooler horn clamping surface was much more dull/rough looking and never slipped.
I've had no more sliding since the fix above.
Old Aug 17, 2010 | 09:34 PM
luseboy's Avatar
luseboy
I just installed the alta couplers earlier tonight. It was a bit of a PITA, but it was worth it. I noticed that my exhaust is quite a bit louder, my car starts up quicker, and my car has a bit more go now. kinda wierd. any thoughts as to the first 2?
Old Aug 25, 2010 | 05:05 AM
jwaller's Avatar
jwaller
I took my stock clamps off and went with T bolt clamps. way more surface clamping area and no leaking. gained about 2psi.
Old Aug 25, 2010 | 01:35 PM
dutch2081's Avatar
dutch2081
what are t bolt clamps?
Old Aug 25, 2010 | 07:02 PM
jwaller's Avatar
jwaller
it's like a hose clamp but wayyyy better. uses a bolt and nut to tension and the clamping part is wider. google it and you can see thousands of them.
IQRaceworks
53
Jun 28, 2024 07:29 AM
gar56
Nov 15, 2016 06:41 AM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
