Drivetrain Help installing JCW exhaust
Old 05-16-2010, 04:13 PM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Just picked up a used JCW exhaust to replace my one-balled stock exhaust. I may be going over to use someones lift so I need to make sure I take the right tools (he doesn't have metric tools or I'd borrow his).
Is there any trick to swapping out the exhaust? What tools do I need? I've looked for a how-to but all I could find was a removal and replacement with non-MINI parts that required some modding to the support brackets. I assume none of that is required with a JCW exhaust?
Any advice would be welcome...
Old 05-17-2010, 08:57 AM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Question. I was looking at RealOEM and noticed that there is a gasket where the exhaust bolts onto the downpipe/cat. I have 30K miles. Does it make sense to replace the gasket when I swap the hardware? They cost $15 at the dealer. I figure it can't hurt but was just curious what folks thought...
Old 05-17-2010, 10:47 AM
gear-head's Avatar
gear-head
gear-head is offline
here's a link to the how-to https://www.northamericanmotoring.co...ll-how-to.html
FWIW, I bought a new gasket because I always figure if you're going to do that much work, you might as well replace the small parts
Old 05-17-2010, 03:02 PM
Sin MINI's Avatar
Sin MINI
Sin MINI is offline
Thanks for the link but I already found that one (in fact, that's the one I was referring to in my original post that removes the stock exhaust but replaced it with a non-MINI exhaust). I have to assume that the bracket removal it discussed is not required (hence my question to be sure).
Old 05-17-2010, 03:21 PM
gear-head's Avatar
gear-head
The JCW exhaust is/should be designed for the Mini, by Mini Engineers (little tiny ones) so I would assume no bracket mods are required.
I actually used a British Scorpion exhaust, and also no bracket mod was required.
Old 05-17-2010, 03:31 PM
Crashton's Avatar
Crashton
Crashton is offline
It is a straight swap for the oem exhaust. Should take you less than an hour laying on your back in the driveway. FWIW I would buy a new gasket. If you don't you'll need it.
Old 05-26-2010, 02:15 PM
IanF's Avatar
IanF
IanF is offline
Check that you still have all of the rubber hangers you may need.
Make sure you still have the OE resonator side body brackets as well.
Sometimes, the nuts that attach the cat-back section to the header pipe can be corroded and hard to get off, but with that many mile and the LV location, you should be good there.
Consider a resonator eliminator pipe. Really makes the JCW exhaust come alive (sound-wise), IMHO.
minicoclub
11-11-2015 07:25 AM
dyeLucky
09-11-2015 10:41 AM
Pyrs
R55 :: Clubman Talk (2008+)
19
09-08-2015 01:43 PM
ASRman
08-13-2015 09:33 AM
papawhiskey
08-10-2015 09:31 PM
Quick Reply: Drivetrain Help installing JCW exhaust
