Drivetrain Redline products for Manual Gearbox...
I have always used Redline products in my manual gearboxes. I use the MT90 in my 88 M3 and have been happy with it. My question is, what are you using and why? I have seen heard MTL, seen MT90 and also was recommended D4 ATF. I am leaning toward MT90 but would like some real life/world input. Thanks.
I use D4 ATF. But MTL and D6 ATF are also recommended by Redline. I think the direct replacement oil is D6 ATF. The main difference is viscosity,with MTL being the thickest and D6 the thinnest.
As far as Iknow, MT90 is not recommended by Redline for Mini manuals.
Interesting. Any reason to use the D4 ATF over the MTL?
MTL is the thickest oil. Can be a little difficult to shift in the winter as a dd.
D4 ATF is in the middle in terms of viscosity so it provides decent protection for the track as well as dd during the winter.
Thanks! I may drive it through a winter first to see how it shifts and then decide on what to use.
Ah i see, good to know... How often would you recommend changing it? Because i'm already at 36k miles and im pretty certain the gearbox oil hasn't been changed yet
I think how often you change it also depends on whether you track your car or not. I track my car a lot and as such, I change my gearbox oil yearly with MTL. I can't honestly say whether this is necessary or not, but it's pretty easy and the MTL is cheap compared to a new transmission.
I changed the manual tran fluid at 1,800 miles and replaced it with Red Line MTL fluid. Shifting was good before but even better with the MTL. I plan on changing ever 30k miles.
It is not like the tranny is going to fail with their "lifetime" lubes but I am convinced that the shifting and synchrno engagement will not be as easy at 70,000 miles without the fluid changes. Mike Miller is the technical guru that writes for Roundel - the BMWCCA magazine. He strongly recommends 30k miles on manual trans fluid and engine oil changes at every 7,500 miles or so.
If you live in a cold climate MTL is a little thicker than stock but is fine if you are careful on the first couple of shifts (don't jam it in gear). If this is a bother Mike recommends going with the lighter Red Line that is the equivalent of the stock oil. Red Line is also very helpful when you call.
Slinger,
Yes...very important to do that as you will be SOL if you can't get your fill plug loose. The car only has 600 miles on it though. I have done the MT-90 in my M3 a bunch of times and always open the fill plug first.
I am planning on doing first oil change and gearbox fluid change this weekend.
Guys,
It's driving me crazy...I had the torque specs for the fill and drain plug(s) and cannot find the piece of paper. I think it was 33 ft-lbs for these plugs? Can anybody confirm and/or correct? Thanks!
That's the torque spec for the oil drain plug but could also be the torque for the transmission plug. I thought it was a little higher though.
I found a mention of 32ft# here but not sure what generation MINI it is.
Check out post # 20 https://www.northamericanmotoring.co...il-how-to.html
I have a couple of questions for those who are changing their transmission fluid. How much oil do you need to change the oil? My car has a limited slip differential, do I have to use a different oil because of the LSD? I've used Redline D4 ATF in other manual transmissions but am concerned with messing up the LSD. Thanks for your help in advance.
