Drivetrain intercooler spray
Old Apr 26, 2010 | 06:14 PM
gbmini03's Avatar
gbmini03
intercooler spray
i was looking into doing some weekend track days this summer and wanted to get my 03 mcs ready. has anyone used a intercooler spray setup? it would just be a simple water spray set-up due to my budget. just wondering if its worth the money or not really
Old Apr 28, 2010 | 07:31 AM
GB1's Avatar
GB1
Bump
I am curious as well
Old Apr 28, 2010 | 08:31 AM
GumbyLara's Avatar
GumbyLara
Here is one I did. Used the rear window wiper pump.
https://www.northamericanmotoring.co...injection.html
I live in Houston and it gets really hot out here in the summer, works great!
Old Apr 28, 2010 | 09:58 AM
gbmini03's Avatar
gbmini03
you got the mister jets at lowes as well? i found a universal kit for about $75 that comes with its own bottle and pump n all i think im gonna order it n try it out. it doesnt come with spray jets tho
Old Apr 28, 2010 | 10:02 AM
gbmini03's Avatar
gbmini03
gumbylra did you paint the grill and headlights and all yourself? what kind of paint did u use and what kind of prep work?
Old Apr 28, 2010 | 05:07 PM
GumbyLara's Avatar
GumbyLara
Yep, got them at Lowe's. They were in the sprinkler accessory area.
And yes I painted everything myself. It's a paint called "Plastic Dip" that you can get at most Home Depots, Lowe's, or Walmarts. You can check out a lot of threads on here about people using the paint. Holds up great and is very easy to get off as well. Prep work just required cleaning and then spraying! That's it! And the headlights I got on eBay!
Old May 10, 2010 | 09:00 PM
BruceWarne's Avatar
BruceWarne
I have one, but use it mostly when waiting at traffic light to alleviate some heat soak.
I'm not sure it will be very helpful on a track - not a manual setup anyway...Most "new" trackday drivers will have too much occupying their mind when on track to remember to activate the water spray. ...I know MRT in Aus had an automatic setup for Subaru's long ago (they even hooked up to the ECU to monitor temperature and boost).
The spray helps a little bit I have to admit (if you remember to use it) - but even better (and safer than it sounds) is water/methanol injection.
Old May 10, 2010 | 09:16 PM
GreenR53's Avatar
GreenR53
You could use a MSD RPM activated switch to spray automatically at a preselected RPM that corresponds with boost pressure. Just set it to a switch so you can turn it off or set it high enough that you can drive around it with out spraying
One other thing to keep in mind where is the water that doesnt evaporate going to go? theres going to be some run off you wouldnt want water pooling some where it shouldnt. Just my .02
Have you looked into Co2?
Old May 10, 2010 | 09:19 PM
BruceWarne's Avatar
BruceWarne
Oh, yeah, good point...on the Mini the water will definitely be pooling where you don't want it...I try to spray very short bursts - flooding the IC doesn't really serve a purpose - you want most of the water to evaporate, not run off somewhere else.
IQRaceworks
53
Jun 28, 2024 07:29 AM
gar56
Nov 15, 2016 06:41 AM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Adam Bradbury
Sep 28, 2015 04:15 PM
