Drivetrain LSD Options for R56
Old Feb 10, 2010 | 04:43 PM
zerosixtwofour's Avatar
zerosixtwofour
LSD Options for R56
I saw it before on the internet; Does Quaife make a LSD for R56? I have a 2010 MINI S, looking to put one it soon... I know mini-maddness has the OS Giken.. is that any good?
Thanks in Advance!
John
Old Feb 10, 2010 | 05:00 PM
JamesHunt's Avatar
JamesHunt
OS Giken FTW
Old Feb 10, 2010 | 05:19 PM
etalj's Avatar
etalj
Thanks in Advance!
John
Quaife doesn't make an ATB for the R56 Cooper S unfortunately. They said they would need 10+ orders and a test mule before they would.
OS Giken looks brilliant however, and James (^^^^) runs one on his car.
Old Feb 10, 2010 | 07:09 PM
dunphyj's Avatar
dunphyj
case closed... NEXT!
Old Feb 11, 2010 | 02:42 AM
Kev_KB's Avatar
Kev_KB
Quaife make one for the UK spec car:
http://www.lohen.co.uk/shop/products.php?cat=97
Not sure if fits the US model...
Old Feb 11, 2010 | 06:45 AM
btwdriver's Avatar
btwdriver
I have the OS Giken and it is superior to the Quaife. The Giken is 100% lock on acceleration and 50% on braking. I have run 2 track weekend so far with it and have been VERY happy.
Old Feb 11, 2010 | 07:34 AM
Revolution Mini Works's Avatar
this is all we use in our race cars
Old Feb 11, 2010 | 07:59 AM
Blainestang's Avatar
Blainestang
Presumably, with 100% lock on acceleration, the EDLC that is programmed into DTC-equipped MINIs would rarely, if ever, intercede.
I would figure the option to disable DSC/DTC is still an advantage however, as it was my understanding that some part of these systems reacted not just to differential wheel speed, but also to the car's slip angle.
Can anyone with a DTC-equipped MINI and the OS Giken confirm/deny/expound?
Also, btwdriver (or anyone else with similar experience), in what circumstances, if any, do the car's stability-type systems still intercede on track?
Old Feb 11, 2010 | 08:07 AM
btwdriver's Avatar
btwdriver
I heavily recommend turning off all nannies while on the track. I for one, don't want an electronic system affecting the vehicles handling. When you are driving the car at it's limit you are continually managing slip and over rotation, the car's electronics will not allow for this.
Also, with the new EDiff, the car is selectively applying the brakes which will cause overheating of your braking system. A mechanical diff like the Giken is heavily preferred over an electronic system.
That is my opinion, YMMV.
Old Feb 11, 2010 | 10:28 AM
Blainestang
Right... Maybe I was unclear, but I don't WANT the electronic nannies or EDLC kicking in, especially if I had an aftermarket mechanical LSD.
I was just asking if people who had DTC+OSG LSD ever experienced the EDLC kicking in in track (it is still on, even with all stability control off).
Also, for people who have the OSG LSD, but not DTC (I was under the impression that stability control cannot be completely defeated w/o DTC), do you ever have stability control kick in while on track? How about before the OSG LSD?
Old Feb 11, 2010 | 11:00 AM
btwdriver's Avatar
btwdriver
Sorry, misunderstood. I have a 2007 so I don't have all that fancy Estuff. I do have DSC and when I turn it off, it is completely off. You can slide/spin the car as much as you would like and the computer doesn't do anything to prevent it.
Old Feb 11, 2010 | 11:23 AM
Blainestang
Sorry, misunderstood. I have a 2007 so I don't have all that fancy Estuff. I do have DTC and when I turn it off, it is completely off. You can slide/spin the car as much as you would like and the computer doesn't do anything to prevent it.
Interesting...
I was under the impression that the pre-DTC (DSC equipped) cars were unable to completely disable stability control.
Good to know, though.
Now, the question that remains is if the EDLC ever intercedes on a DTC-equipped car with the OS Giken diff installed?
Old Feb 11, 2010 | 12:12 PM
STi2Mini's Avatar
STi2Mini
This may be a dumb question, but I have a 2007 MCS that does NOT have an LSD. Can I add an LSD to it without major mods or even having MINI reprogram anything? From what I understand I can add a mechanical LSD without too many problems, is that right?? I really want a LSD for Auto-X!!
Old Feb 11, 2010 | 12:14 PM
btwdriver's Avatar
btwdriver
When you add a mechanical diff, like the OS Giken, you remove whatever stock diff you have. Whether that be a stock limited slip or open diff. So short answer yes you can. It is a fair amount of labor to install the diff, probably 1000-1300 depending on the shop.
Old Feb 11, 2010 | 02:50 PM
etalj's Avatar
etalj
Originally Posted by Blainestang
Interesting...
I'm very curious to know the answer to this question. There is at least one person running the OSG diff on a factory JCW. JamesHunt. Hopefully he'll pipe up with an answer
Old Feb 11, 2010 | 03:08 PM
We have one in the Challenge car
works as advertised
Old Mar 22, 2010 | 02:51 PM
Monito Efervescente's Avatar
Monito Efervescente
Originally Posted by JamesHunt
OS Giken FTW
Interesting...
I'm very interested too, i'm about to decide between a factory JCW or the new 184bhp Cooper S with or without the eDLC(in case it does intercede with a mechanical LSD)
Old Mar 22, 2010 | 04:09 PM
JamesHunt's Avatar
JamesHunt
Etalj
Had a death in the family that has set my build back a few months.I should be able to give a review of the lsd by mid april/may.
JD
Old Mar 22, 2010 | 04:18 PM
etalj's Avatar
etalj
Etalj
JD
No rush at all mate. All the best for you and your family.
Monito: Avoid the EDLC like the plague. It is by far the worst thing about my JCW. Don't get me started on how many ways it manages to ruin the driving experience
Old Mar 22, 2010 | 05:08 PM
Monito Efervescente
So, is it that bad? I guess i should go for the Cooper S with no EDLC nor LSD(since it's no longer available) and throw in a mechanical LSD later...
Old Mar 22, 2010 | 05:10 PM
JamesHunt's Avatar
JamesHunt
wish someone could defeat the edlc
Old Mar 22, 2010 | 05:25 PM
Dr Obnxs's Avatar
Dr Obnxs
Easy...
unplug a wheel speed sensor. The system goes blind. But you give up ABS and get some dash lights as well.
No free lunch here!
Matt
Old Mar 22, 2010 | 05:37 PM
JamesHunt's Avatar
JamesHunt
Thanks Matt
Who needs ABS anyway
Old Mar 22, 2010 | 06:55 PM
etalj's Avatar
etalj
very interesting idea
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:19 PM
Aug 11, 2015 12:18 PM
