Drivetrain OBX LSD call out.
Old Mar 16, 2010 | 10:26 PM
  #26
OctaneGuy's Avatar
OctaneGuy
Thanks Jeremy. I never even thought about doing the work myself. I do have a rack I could use here at the shop and I do have another car I'm driving. Hmmm, and we did just a hire a new mechanic that probably could do the work too....hmmmm.....you got me thinking again, lol.
Originally Posted by jhiggs26
Sorry to hear you're at your wits end with this. If you've got access to another car and shop space you can do the work yourself for free though. It's not too hard to lower the subframe and split the gearbox from the motor.
There are no rebuild kits available for our 6 speed boxes pre or facelift that I've found.
Jeremy
Old Mar 17, 2010 | 12:50 PM
  #27
Trickle X's Avatar
Trickle X
its not too hard to pull the tranny.....I'm lazy and work alone 99% of the time, so I just pull the engine and tranny out together. It is 100x easier taking the tranny off and putting it back on by yourself. Of course I dont have half the crap on my motor like the SC motors, but i have a heck of a lot of IC piping and turbo lines....lol
Old Mar 19, 2010 | 12:51 AM
  #28
OctaneGuy's Avatar
OctaneGuy
Sorry to go off topic here, but to finish up my OBX story..here are a couple pix of my problem. Seems there was a hidden problem...look at my tranny mounting points....2 are gone of the 3. One is stripped and the other is missing.
Old Mar 19, 2010 | 08:00 AM
  #29
jhiggs26's Avatar
jhiggs26
OK that CV is scrap! Unless you're good with an ARC welder and grinder. That's why it was sliding all around in your OBX. How did the c-clip look like?
And woh your motor was either hard mounted everywhere and gave out on the trans mount or it was soft mounted everywhere and gave out on the trans mount. Time for a new inner CV and captive nut welding on your frame rail. Good luck!
Jeremy
Old Mar 19, 2010 | 08:12 AM
  #30
OctaneGuy's Avatar
OctaneGuy
The c-clip was brand new...the old one was a bit worn. The motor has poly bushings but otherwise uses stock motor mounts. I'm getting a new CV, and the frame is being rewelded as we speak. The tranny is coming apart this weekend for inspection and possibly LSD replacement.
Jeremy
Old Mar 19, 2010 | 08:17 AM
  #31
newbs49's Avatar
newbs49
Hope all goes well. Do you know a good welder?
Sorry to hear about your problems.
Good Luck!!!!!!!!!!!!!!!!!
Old Apr 1, 2010 | 04:56 PM
  #32
OctaneGuy's Avatar
OctaneGuy
Just wanted to post a followup on my story as the saga continues. The tranny was pulled and a MINI friend of mine offered to inspect it and take it apart if necessary. A week later, I find out that he didn't do anything but clean it up and had another friend look at it who said it "looked fine". Sigh.
I took the tranny back to the shop, they put it back in place with the new welded mounts. Using a new axle, new c-clip, they find that the axle is even looser than before the tranny was pulled out. They can actually pull the axle out by hand after snapping it in.
Not a good sign at all, and I'm just really pissed at the time I've wasted. At this point it's either crack the tranny open and replace the diff or drop in a replacement tranny with factory LSD...I'm doing the latter. I'll keep the old tranny and OBX Diff and upgrade it at a later time when I have more time and money.
Thanks for everyones suggestion...maybe I'll be back and running next week on a factory tranny and LSD....I'm already at the breaking point...if this doesn't fix it...I'm scrapping this MINI and getting a clubbie.
Old Apr 1, 2010 | 05:37 PM
  #33
newbs49's Avatar
newbs49
Good Luck!!!!!!!!!!!!!!! Sad to hear your tranny laid around for a week with nothing done. Are you getting a used tranny or one from MINI.
Hope your back on the road soon.
Old Apr 1, 2010 | 05:40 PM
  #34
OctaneGuy's Avatar
OctaneGuy
My shop found a 2005 MCS Tranny with LSD from a MINI that was rearended with 30,000 miles on it. Thanks!
Old Apr 1, 2010 | 05:50 PM
  #35
newbs49's Avatar
newbs49
Old Apr 2, 2010 | 06:55 AM
  #36
jhiggs26's Avatar
jhiggs26
Oh Richard I feel for you.
Really though why the eff didn't they try the inner CV/whole axle in the diff before they reinstalled the trans and diff to the motor!!! The OBX output is scrap if a new inner CV is sloppy in there. Good luck with your new trans and diff.
Jeremy
Old Apr 2, 2010 | 07:15 AM
  #37
OctaneGuy's Avatar
OctaneGuy
Probably cause they took my word that the tranny and diff was checked out and didn't have any issues with it. I dunno. Thanks so much for your support and advice.
Jeremy
Old Apr 2, 2010 | 10:35 AM
  #38
Some Guy's Avatar
Some Guy
Seeing this, I have to agree with J-higgs, the outputs from the OBX are probably bad, no need to replace the whole transmission.
Old Apr 2, 2010 | 10:39 AM
  #39
OctaneGuy's Avatar
OctaneGuy
It's just a cost and time issue now. The cost to open the tranny, and replace the OBX will be more than replacing with a used tranny and I really need the car back in the next week for a show.
I do plan to keep my old tranny with the OBX and will work at my leisure to fix what's needed down the road. I enjoyed the performance of it, so since so many of you had good luck with the OBX, I'd probably get another one or get the parts to fix what I have and do it myself since it will be out of the car already.
Richard
Old Nov 18, 2010 | 10:30 AM
  #40
SteveS's Avatar
SteveS
There is a video on Youtube somewhere of splitting the trans and replacing the dif. Seems easy.
Old Nov 18, 2010 | 11:01 AM
  #41
JumpingJackFlash's Avatar
JumpingJackFlash
Well, I learned a good piece of info reading this article. Turns out the SVT Focus used the same Getrag 6-speed manual transmission. Ford part number is M-4204-SVTF . Here's a link for the SVT Focus differential: http://www.tousleyfordparts.com/part...catalogid=5684. I'm sure there are other sites that carry it. Retail is $779; this site charges $632.50. I think this is what I'm going with whenever I change out my clutch.
Old Nov 18, 2010 | 03:34 PM
  #42
Some Guy's Avatar
Some Guy
See my sig. That is where I got mine from.
Old Nov 20, 2010 | 03:02 PM
  #43
newbs49's Avatar
newbs49
How does the SVT LSD compare to the Cusco or Giken units?
Old Nov 20, 2010 | 08:42 PM
  #44
R53Warrior's Avatar
R53Warrior
Its not exactly a "SVT Focus" LSD. Its a Torsen built LSD that Ford Racing supplied/stocked. The focus didn't come with one or had one as a factory option.
Its different from Cusco and OS Giken in that it is gear driven as opposed to clutch driven. A clutch LSD is more aggressive, requiring you to adjust your driving lines under certain conditions. But it will distribute more power to the wheel with traction than a geared one. Also a geared LSD will act like an open diff when a tire leaves the ground and sometimes on ice where as the clutch preload in the clutch LSD will allow it to still distribute power to the wheel with traction.
Old Nov 21, 2010 | 01:21 PM
  #45
CrazyIvan's Avatar
CrazyIvan
A trick to use on ice with the gear type lsd would be to able the brake pedal.
Old Nov 21, 2010 | 09:32 PM
  #46
R53Warrior's Avatar
R53Warrior
True but if the difference in price isn't a huge point for you the OS Giken LSD is definitely more "ultimate driving machine" lol
Old Nov 23, 2010 | 10:44 PM
  #47
Some Guy's Avatar
Some Guy
I can attest the the fact that torsen does have traction issues at times, but really only when it is cold, wet and you are on the wrong tires ("hey it's 40 degrees and I am on summer tires, in the rain"!) if I had the money would have done the cusco, but that is much more expensive. I've beaten the **** out of it and no issues so far.
patsum
26
May 29, 2021 06:29 PM
battlehawk_mini
Mar 5, 2021 06:15 AM
minimofo
Sep 30, 2015 12:26 AM
Anakist
Australia
Sep 8, 2015 03:32 AM
