Drivetrain Anyone running a Riss catch can with an Alta CAI and hard pipe?
in hind sight i actually answered my own question... it wouldn't stall if it blocked it off... however in figuring this out, would blocking off the intake manifold/cam vent, would that make all the vapors go to the intake turbo inlet side.
That is exactly correct. This way all blowby gets filtered in our catch can (which is baffled unlike others we have seen here) and than the pressure is allowed to travel to the intake pre turbo keeping emissions compliance in check.
I like the stealth looks of the BSH can, but neither of the two install points will work with the DoS intake. The can won't fit on the bracket on the driver's side of the plastic bulkhead because that is too close to where the DoS intake goes through the bulkhead. The other location requires removing the stock snorkle tube that the DoS Intake also uses. You should be able to use the clip that Clint (Mini'mon) showed in an earlier post and put the can on another location on the bulkhead. This picture shows my install with the 42 Draft Design catch can (which has a really cool baffling technique) using the clip that Clint showed.
I like BSH's solution to tapping into the lines (I'm into neat engineering solutions) and their can has a baffle (unlike m7, alta, or RR). So I might get their can and install it in the turbo inlet side tube.
Cheers,
Greg
figured as much, and also why vacuum would pull oil vapors into the intake manifold.
last question pending ordering... there is a two wired sensor/valve (not sure which it is but it seems to be some on/off switch cuz of the two rather than three wires), if you block off the other side of the crank case with your blockoff/boost piece, will that disrupt the flow of pressure in the crank case? after all i understand under boost, but will it function when normally there's a vacuum? and as a secondary concern, would the turbo/intake be sucking enough air to still equalize the system when it's not under boost?
JP,
Cheers,
Greg
Cheers,
Greg
Cheers,
Greg
D'oh! That would be post 13. Not firing on all cylinders tonight. Your idea sounds good. Putting the adapter in would mean that you only need one can and that would be in the other line. Much cheaper than buying two cans (so I'm a little slow on the uptake, but I finally get it).
Cheers,
Greg
Cheers,
Greg
Please let me know if this needs further clarification.
So what's the price on this little piece?
The boost taps are $59 with free freight right now. Here is a link to the product on our website BSH Direct Dual Boost Tap
This product, as well as our complete line, is also available from popular vendors such as Detroit Tuned, Helix Performance, Mini Mania, North American Motorsports, and Way Motor Works so if you have an existing relationship with any of these shops we would be honored if you would support our dealers.
