Drivetrain pulley on a 2007?
Old Jan 19, 2010 | 11:48 PM
mikemc's Avatar
mikemc
pulley on a 2007?
still gettin my posts out here... so i read a lot about cooper owners replacing the pulley? what does that do exactly? does it save gas or increase speed?
I was looking to do a few more mods and make it a little quicker and was wonder if this pulley would do that...
thanks for your help..
mikemc
Old Jan 20, 2010 | 04:05 AM
Poppa Bear's Avatar
Poppa Bear
Most likely, they are referring to replacing the stock supercharger pulley with a reduced diameter pulley, like this one. The newer, smaller pulley increases the speed of the supercharger and increases the HP. Unfortunately, the R56 went from a supercharged to a turbocharged engine in 2007, so this is not an available upgrade path. Hope this helps.
Cheers!!
Old Jan 20, 2010 | 04:14 AM
GP0256's Avatar
GP0256
Cheers!!
+1, only works on 02-06 MCS or 07,08 MCS Verts. No go on the 07+ turbo models.
Old Jan 20, 2010 | 06:08 AM
iwashmycar's Avatar
iwashmycar
On ours the equivalant mod might be a tune?...which is a lot more $$$
Old Jan 20, 2010 | 08:20 AM
JamesHunt's Avatar
JamesHunt
I have a lite weight pulley installed on a 2009 jcw
Old Jan 20, 2010 | 08:45 AM
schatzy62's Avatar
schatzy62
How? What? Where? When? as there is no PULLEY to replace I do not see how you have this done. Unless of course you changed the engine to a supercharged one, or you are talking about something completely different to what the OP is asking about.
Old Jan 20, 2010 | 08:49 AM
SlowGSX98's Avatar
SlowGSX98
he has a lightweight crank pulley
Old Jan 20, 2010 | 10:08 AM
mikemc's Avatar
mikemc
Cheers!!
Yes this is very helpful! thank you!
are you reffering to the JCW tune kit from mini? because i was fortunite to have got that already...any other suggestions to increase speed?
Old Jan 20, 2010 | 10:27 AM
JamesHunt's Avatar
JamesHunt
Downpipe,meth injection and 25hp shot of nitrous
Old Jan 20, 2010 | 01:14 PM
drewstermalloy's Avatar
drewstermalloy
You can get ALTA's or CravenSpeed's lightened crank pulley. Supposedly supposed to add a few HP.
Old Jan 20, 2010 | 02:49 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Our crank pulleys are three pounds lighter than the stock. The reduction in weight is effectively the same power increase as removing 75 pounds of weight from your vehicle. You will feel increased throttle response and acceleration!
BernieCoop
Sep 10, 2021 03:15 AM
gzaos
Sep 14, 2015 04:21 AM
Emnotek
Sep 11, 2015 04:16 PM
sirfrank
Sep 11, 2015 01:36 PM
PSU 98
Sep 11, 2015 11:20 AM
