Drivetrain aftermarket clutch
Old Jan 8, 2010 | 07:59 PM
JamesHunt's Avatar
JamesHunt
aftermarket clutch
The OS Giken makes way too much noise for my taste,anyone have a suggestion?
Jan mentioned needing a flywheel to send to a clutch manufacture.
Old Jan 9, 2010 | 12:39 AM
etalj's Avatar
etalj
SPEC?
http://www.jscspeed.com/mini_r56/clutch/spec_R56.htm
Old Jan 9, 2010 | 06:49 AM
JamesHunt's Avatar
JamesHunt
spec = junk
Old Jan 9, 2010 | 07:23 AM
countryboyshane's Avatar
countryboyshane
Could you elaborate on what type of noise is makes? OS Giken seems like the only choice if you want an aftermarket flywheel and clutch right now...
Old Jan 9, 2010 | 07:34 AM
JamesHunt's Avatar
JamesHunt
it rattles when in neutral
Old Jan 9, 2010 | 08:46 AM
Helix13mini's Avatar
Helix13mini
It's rattling in neutral if a) you have an un-sprung flywheel with an un-sprung clutch or b) your stock flywheel is jammed, and needs replacing. The factory flywheel is dual-mass: meaning that it has an internal spring which 'gives' a little on clutch uptake (or when idling in neutral with the clutch out). The clutch disc is solid. When people go to a single-mass lighter flywheel, they often don't use a sprung clutch disc, and therefore get the rattle and hum (on uptake).
the Clutchmasters products have provisions for this. They have setups with solid flywheels and sprung clutches (more like Porsches). I have to second the opinion of Spec--at least insofar as how their durability. They do wear out in a hurry. But people have to remember that when they buy aftermarket 'heavy duty clutches', they often think that it means that they will last for a billion miles, which is a misconception. It means that the pressure plates are sprung more heavily, and the discs have more aggressive friction material for aggressive launching and shifting. Especially with heavy use, they will not last longer than a stock setup.
Old Jan 9, 2010 | 10:18 AM
Gilboyto's Avatar
Gilboyto
^^ Just to attest to that, I ran a SPEC Stage III+ clutch in my 93 Corrado VR6 turbo with around 400whp and never had a single issue.
Old Jan 9, 2010 | 04:36 PM
ZippyNH's Avatar
ZippyNH
The one you heard...was it the Super Single or the OS GIKEN TWIN PLATE CLUTCH?
Old Jan 9, 2010 | 04:39 PM
JamesHunt's Avatar
JamesHunt
was the one on the gt28 clubman.Have no idea what model.
Old Jan 10, 2010 | 12:21 AM
etalj's Avatar
etalj
I have no experience with aftermarket clutches. I just searched quickly. Does Jan have any opinion on the matter?
Old Jan 10, 2010 | 05:53 AM
JamesHunt's Avatar
JamesHunt
The OS clutch is pretty hardcore,rmw is in talks with clutchmasters for a less expensive and more streetable setup.
The perfect setup would be a clutchmasters clutch rated for 350 tq and a os giken diff.
Old Jan 10, 2010 | 10:52 AM
skippydog's Avatar
skippydog
I have also run spec in a few large hp projects. Never had a single problem and their tech support was top notch.
Old Jan 10, 2010 | 11:20 AM
JamesHunt's Avatar
JamesHunt
spec would not work,spec only list a clutch for cooper s.from what i understand is that a jcw uses a different flwheel and clutch than a cooper s.
Old Jan 11, 2010 | 04:36 AM
Gilboyto's Avatar
Gilboyto
from my understanding the factory JCW uses a beefed up version of both
Old Jan 11, 2010 | 06:18 AM
JamesHunt's Avatar
JamesHunt
Would that not make them different?
Old Jan 11, 2010 | 08:22 AM
Gilboyto's Avatar
Gilboyto
If youre interested in getting a high rated HP/TQ clutch thats higher than the JCWs capacity, shouldnt it work just fine?
Im pretty sure they wouldnt change the spline size of the clutch itself, but then again it is a MINI...
Old Jan 11, 2010 | 08:58 AM
Helix13mini
Nope. Clutch is the same. The pressure plate and flywheel are different.
Old Feb 23, 2010 | 07:25 PM
Revolution Mini Works's Avatar
I have the OS Giken clutch and I don't have ANY rattles.
Old Feb 23, 2010 | 07:51 PM
ZippyNH's Avatar
ZippyNH
More info!! How do you like it...how does it feel....worth the extra $$?
Bestow upon us you knowledge!!
Old Feb 23, 2010 | 08:27 PM
a twin plate is overkill for most applications , but for high horsepower cars you can still drive this on the street
their single plate is more than adequate
the quality is there but you pay for it. The dollar to yen is not in our favor
Old Feb 24, 2010 | 06:29 AM
btwdriver's Avatar
btwdriver
I have both the OS Giken diff and clutch. The clutch for the R56's is the super single. The clutch is not for the faint of heart. It is super grabby and will chatter when you slip it in first gear if you don't give it a fair amount of gas. In my opinion if your car is mostly a street car (mine is not) you might not be that happy with the Giken clutch.
The spring plate is not that stiff and is pretty close to stock, maybe 66% stiffer. My comments about it being streetable are limited to slipping the clutch in first gear, other than that it is not too bad. There is some flywheel rattle when you have the clutch engaged, but I think that is par for the course with a single piece flywheel.
The diff totally kicks ***! I do around 30 or so track days a year, and came from the stock LSD. The Giken is MUCH better than the stock diff. With the stock diff on tight turns the inside wheel would just spin and I would have to come out of the throttle to keep from trashing the tire. With the Giken the car just pulls, it's crazy, you can just keep your foot in it and the car launches out of the corners.
Old Feb 24, 2010 | 07:29 AM
Originally Posted by btwdriver
I have both the OS Giken diff and clutch. The clutch for the R56's is the super single. The clutch is not for the faint of heard. It is super grabby and will chatter when you slip it in first gear if you don't give it a fair amount of gas. In my opinion if your car is mostly a street car (mine is not) you might not be that happy with the Giken clutch.
The diff totally kicks ***! I do around 30 or so track days a year, and came from the stock LSD. The Giken is MUCH better than the stock diff. With the stock diff on tight turns the inside wheel would just spin and I would have to come out of the throttle to keep from trashing the tire. With the Giken the car just pulls, it's crazy, you can just keep your foot in it and the car launches our of the corners.
it all depends what clutch setup you have from OS, Ian and I have worked with them to make a more "friendly" street setup.
the differential is definitely a "point and shoot" style LSD
Old Feb 24, 2010 | 07:56 AM
Porthos's Avatar
Porthos
Man I want to do a FW/CL/Upgraded diff but man that is a lot of money that I don't have right now. One day one day.
Old Feb 24, 2010 | 11:07 AM
akng's Avatar
akng
So OS Giken makes 2 clutches for R56? Cuz for some reason, I thought they only make one...
From your other comment about working with them for a more street friendly clutch, are you guys going to release that new clutch under RMW then? Or will it be marketted under OS as well?
Old Feb 24, 2010 | 11:39 AM
dunphyj's Avatar
dunphyj
