Drivetrain modify wastegate acuator
Old Oct 14, 2009 | 04:36 PM
feche's Avatar
feche
hi, I read elsewhere that 2 turns the wastegate actuator you gets more boost peaks and more boost as well in low regimes, someone modified it? turned the screw ?
greetings
Old Oct 14, 2009 | 07:11 PM
ThumperMCS's Avatar
ThumperMCS
here we go again....
Old Oct 14, 2009 | 07:15 PM
feche's Avatar
feche
I read every post about it and always marred, so I want to know about this clearly
Oxybluecoop's Avatar
Oxybluecoop
Old Oct 14, 2009 | 08:33 PM
slinger688's Avatar
slinger688
Won't do it on mine.
Old Oct 14, 2009 | 09:45 PM
MotorMouth's Avatar
MotorMouth
Just say "NO"
Old Oct 14, 2009 | 11:18 PM
chakraj's Avatar
chakraj
Ahahahah,hahahahahha,ahahah
Turn it a few extra times, just to see what happens
P.S. No really dont
Old Oct 15, 2009 | 02:48 AM
eg0911's Avatar
eg0911
DONT DO THIS! in theory it would work, with other cars it works and gives more boost but your not adding fuel in those cars, the mini ecu is very temperamental, your car will NOT run right, if it will even get down the street
Old Oct 20, 2009 | 12:27 PM
feche's Avatar
feche
Estoy waing recive my boost and air/fuel gauges, later i will move this ****... i took with a lot of people the result is a more stable boost
here is a link showing how to do it
http://www.youtube.com/watch?v=RhsGjSFUhTw
bye, any information is useful!!!
Old Oct 20, 2009 | 02:24 PM
slinger688's Avatar
slinger688
Feche, I think you should try it, test it for a few months and put the results on this forum.
Old Oct 20, 2009 | 02:29 PM
feche's Avatar
feche
yes, i need the gauges to see if i am short of fuel with more boost
Old Oct 20, 2009 | 03:15 PM
slinger688's Avatar
slinger688
Do keep the NAM community in the loop as you progress, good or bad. Thanks.
Old Nov 3, 2009 | 06:52 PM
feche's Avatar
feche
well,I just finished playing the WG, I gave it two laps and the car really feels more awake, especially at low revolutions and in the use of city, I am more than happy, I recommend it totally!! tomorow i wil give it 2 or 3 more....
Old Nov 3, 2009 | 08:58 PM
eg0911's Avatar
eg0911
still good on af ratios? after 2 turns?
Old Nov 4, 2009 | 08:16 AM
feche's Avatar
feche
2 turns is nothing, my wideband shows the some numbers aprox, today i will give it 4 more turns... the peak was 20.5PSI, now is 21PSI but the car have more reaccion at low RPM and is better in hi speed, the time to pass from 170 to 210 is shorter. i recommended!
Old Nov 4, 2009 | 09:29 AM
pilotart's Avatar
pilotart
Better get some Ultra-High Octane (100+) fuel to burn, you are depending on Anti_detonation ECU to protect from blowing pistons with a modified waste-gate!
It can back the timing, but may not be able to limit the boost.
Old Nov 4, 2009 | 09:36 AM
feche's Avatar
feche
i dont have too much boost, only 21psi in peak in 4th and 5th.... someones have 23psi peak and dont have problems of detonation
Old Nov 4, 2009 | 12:02 PM
ThumperMCS's Avatar
ThumperMCS
That's a lot my friend....I'd enjoy your fun while it lasts.
Old Nov 4, 2009 | 01:14 PM
slinger688's Avatar
slinger688
I hope I am wrong but I am waiting for the aftermath.
Old Nov 4, 2009 | 03:14 PM
MotorMouth's Avatar
MotorMouth
how are you getting to the rod? are you taking the turbo off??
While I don't recommend doing this I'm just waiting to learn from someone elses mistakes.
Old Nov 6, 2009 | 06:38 PM
Noegel's Avatar
Noegel
23psi.... that is a ridiculous amount of boost for the MINI motor without seriously modified internals..
richardsperry
Jul 30, 2018 04:48 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
krohm
Sep 28, 2015 12:16 PM
Vaderm34
Chicago MINI Motoring Club
Sep 28, 2015 05:03 AM
miniuy
Sep 21, 2015 02:00 PM
