Drivetrain New intake, oil buildup on back window?
Old Oct 11, 2009 | 09:52 AM
pixlpush's Avatar
pixlpush
I installed a new alta 2.0 intake in my 2006 MCS last weekend, along with a 15% pulley, MSD ignition coil, cooler plugs and Alta Exhaust. Over the week I've notice a fine oily mist building up on the rear window and rear of the car. Seems like it's coming from the exhuast. I'm hoping it's just oil on the air filter that came with the intake and not something worse? The car is running fine this is the only issue. Anyone else notice a oily mist building up on the rear of the car after similar additions?
Old Oct 11, 2009 | 10:45 AM
firenewt's Avatar
firenewt
Running overly rich? Have you reset the ecu? When I did my lastest round of upgrades, I ran richer than normal until the ecu caught up with the mods.
Kevin
Old Oct 11, 2009 | 01:41 PM
pixlpush's Avatar
pixlpush
Well I had the battery disconnect while I did the work, that should reset the ECU correct? I've only put about 100 miles on it since the addition of all the new bits so I guess I'll have to wait and see if it gets better.
Old Oct 11, 2009 | 04:53 PM
MINICHEF's Avatar
MINICHEF
It is most likely from the "stuff" inside the new exhaust. Once that blows and burns out it should go away. The ECU is a slow learner and it might take a couple of tanks before it fully adjusts. Might want to think about a "tune" from RMW or Mynes
Old Oct 11, 2009 | 10:20 PM
Jazzop's Avatar
Jazzop
Don't let the "likely" culprits distract you from an unlikely but possible situation such as an oil leak. Check the dipstick regularly!
Old Oct 11, 2009 | 10:35 PM
pixlpush's Avatar
pixlpush
I think Minichef got it right . I got together with some of my car buddies tonight and they all had a look. it's a weird oily powdery build up. suspiciously like dust from fiberglass that might be packed in the exhaust? the consensus was keep checking the oil and wait for the exhaust to burn in a bit more and it will likely go away. One of the guys thought it looked like stripper glitter, unfortunately that's not it.
Thanks everyone for your input.
Old Oct 11, 2009 | 11:08 PM
Jazzop's Avatar
Jazzop
Yes, that is unfortunate. Stripper glitter is properly found all over the seats, shift ****, and driver's apparel. It is out of place on the exterior of the car.
Old Oct 12, 2009 | 04:50 AM
mbcoops's Avatar
mbcoops
Keep an open mind...
Old Oct 17, 2009 | 04:11 PM
Silkworm's Avatar
Silkworm
Hood glitter is acceptable . But I had the same thing minus the glitter from an oil leak. It was actually because they forgot to take out the old O-Ring when they did my oil change and it caused this.
surfblue
Oct 24, 2018 01:20 AM
wkp1219
Nov 13, 2015 07:52 AM
clintmeister
Aug 12, 2015 11:11 AM
atenzany62
Aug 9, 2015 05:54 PM
