Drivetrain Alta Intercooler Couplings
Old May 21, 2009 | 04:43 PM
ea6b607's Avatar
ea6b607
Maybe it is just me, but I bought a Alta v1 Intercooler with couplings off the marketplace recently. Anyway though I'm finding it near impossible to get the silicon coupling over the small outlet flange of the intercooler. Anyone else have trouble with this? Any hints to get it on easier. I tried for about half an hour just to fit it on today, but it just doesn't want to fit.
Old May 21, 2009 | 04:49 PM
jhiggs26's Avatar
jhiggs26
Use some engine oil sparingly on IC output and inner edge of coupler. Lube does work!
Jeremy
Old May 21, 2009 | 05:01 PM
M3NTAL's Avatar
M3NTAL
some people boil up some water and dip them in the water to soften them a bit.
Use caution with got water and silicone couplers
Old May 21, 2009 | 05:06 PM
bean's Avatar
bean
it's a tough install, but worth the pain. i used to split oem boots at the track on a regular basis. no problems w/ the alta boots! hot water or a heat gun/hair dryer to make it more flexible.
Old May 21, 2009 | 06:55 PM
ea6b607's Avatar
ea6b607
Glad to here that it isn't just me at least. I'll try a couple of these and see what happens. At least I'm sure there will be a good seal
Old May 21, 2009 | 09:29 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
What I did was to turn them while they were on to help slide the last of it over the lip. It is easier the second time after they have been on for a long time.
Old May 22, 2009 | 01:13 AM
Mike S's Avatar
Mike S
You just need to be patient, it was a real PITA for me to install as well.
Old May 22, 2009 | 07:27 AM
Bigshot's Avatar
Bigshot
Heat them up in some hot water, use a little lube on the horns, and loosen the front IC bolt brackets.
Works everytime.
Old May 22, 2009 | 01:35 PM
ea6b607's Avatar
ea6b607
Well, after both myself and a friend of mine spent about an hour trying to get these things on we finally just went and used the stock couplers on the new IC. Oh well, I did manage to get them on with some boiling water, but I just did not have enough space to squeeze in onto the manifold input pipe thing.
Old May 22, 2009 | 02:57 PM
Bigshot's Avatar
Bigshot
Did you try loosening the front IC brackets so the ic can be moved around a bit more?
Old May 22, 2009 | 07:39 PM
Mike S's Avatar
Mike S
I used a round edge of a wrench and pushed the underside of the couplers around the right horn from the top.
Old May 24, 2009 | 08:53 AM
Vernon29RW's Avatar
Vernon29RW
why not just use what Alta recommends: a bent awl???.......just be careful That's what I used. Took the brackets off completely from the IC. Put the IC into the pass side boot first. Then slid the driver side boot onto the horn and lowered the IC into the boot. I slipped the boot on as far as I could and the bottom of the boot ended up folding over on me, so I carefully stuck the tip of the awl in between the IC and the boot and slowly pulled and the boot unfolded as I pulled and straightened out perfectly. Took about 3-4 minutes.....
Old May 27, 2009 | 04:33 AM
CrazyIvan's Avatar
CrazyIvan
I had to trim mine to get them to fit. Major Pita instal but my stock couplers were dry rotted and about to split.
Old May 27, 2009 | 03:35 PM
Hippie's Avatar
Hippie
Now why would you go and follow the directions/recomendations of the manufacturer
Old May 27, 2009 | 05:43 PM
bean's Avatar
bean
....because we are men and men don't read directions (or follow them)
Old May 27, 2009 | 05:49 PM
ea6b607's Avatar
ea6b607
... or have them.... Maybe if I have a free weekend I'll give it another shot, unfortunately i had to get to work and had to put something on my car
Old May 27, 2009 | 05:53 PM
Capt_bj's Avatar
Capt_bj
had the opportunity to deal with a set of these recently
4 hands are better than 2 .... we had absolutely no problem once we worked together to do both sides at once. take the IC completely off. set the new couplings in place and press everything down evenly..... a one minute job that simply took 4 hands
Old May 27, 2009 | 10:25 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
My intercooler boots aren't actually from Alta. I forget who made them, but they didn't come with instructions.
Old Dec 26, 2021 | 05:46 PM
cooperwiththemini's Avatar
cooperwiththemini
Do I use the stock brackets?
I am looking towards buying some new bellows from Alta but I was wondering if I should use the stock hinges/brackets from the old bellows.
W0TM8
Dec 19, 2019 07:50 AM
rtk90
Aug 29, 2019 09:08 AM
Witsticka
Sep 15, 2015 01:33 PM
Hippiehobbit267
Sep 1, 2015 06:13 PM
Sep 1, 2015 04:39 PM
