Drivetrain Lsd
Old Dec 27, 2021 | 05:41 PM
RIPPER's Avatar
RIPPER
Lsd
Does anyone know the average time it should take an experienced shop to install a LSD? I'm picking up an 06 r53 with 73k miles and want to have one installed. I wil probably have a new clutch installed at the same time but in case I don't, I'd like to get an idea of how long it takes so I can figure out how much it's going to cost.
Old Dec 27, 2021 | 10:12 PM
Mini_Crazy's Avatar
Mini_Crazy
For an experienced shop (that's installed a couple LSDs previously and has their own bearing press), it will probably add 1.5 hours to a clutch job.
FYI: ModMini has an excellent video on a Quaife install that will show you what's required.
Old Dec 28, 2021 | 03:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Having done the job, for an estimate, this is probably reasonable. Also, I wouldn’t considering paying to have the job done WITHOUT replacing the clutch.
Old Dec 28, 2021 | 04:41 AM
cmt52663's Avatar
cmt52663
F56 Quaife, OEM Clutch, including all relevent bits, and missing no chances.
$1,800 for labor at Mini of Peabody.
Cheers,
Charlie
Old Dec 28, 2021 | 06:31 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
that's what I would expect, honestly that's cheap for a dealer
Old Dec 28, 2021 | 08:53 AM
Soul Coughing's Avatar
Soul Coughing
That's a great price for a dealer! When I swapped out my open diff on my '03, it only took me a couple hours to get it apart, and press on the new bearings. It's so much easier than working on a RWD pumpkin as you're not setting any backlash etc.. I will say though, that while it's apart, make sure you change out the slave rod bushing on the fork that opens and closes the pressure plate, as well as changing the snout of the input shaft. These wear out, even if you have low miles, and the pedal feel was so much better afterwards. Check your output seals on the axles to see if they're seeping oil. Best time to change them while it's all apart!
Old Dec 28, 2021 | 12:54 PM
cooper48's Avatar
cooper48
$61 for Locktite? Please.
Old Dec 28, 2021 | 04:50 PM
deepgrey's Avatar
deepgrey
To be fair, Loctite 518 isn’t exactly cheap, and it probably required a fair amount to reseal the tranny.
Old Dec 28, 2021 | 05:30 PM
OCR's Avatar
OCR
Post deleted by moderator.
Last edited by 2017All4; Dec 29, 2021 at 06:12 PM. Reason: We received complaints. Some found this offensive.
Old Dec 28, 2021 | 06:33 PM
RIPPER's Avatar
RIPPER
thanks for all the replies . is there a consensus on which lsd is better, a quaife or a wavetrac. from the prices i've seen, the quaife is 899.00 and the wavetrac is 1065.00. ive been away from modding cars since 2011 and ive never heard of wavetrac before.
Old Dec 28, 2021 | 07:55 PM
deepgrey's Avatar
deepgrey
Originally Posted by OCR
Mike
Edited out by moderator as this was a response to content deemed offensive.
Last edited by 2017All4; Dec 29, 2021 at 06:19 PM. Reason: Responded to complaints that post was offensive
Old Dec 29, 2021 | 05:21 PM
Husky44's Avatar
Husky44
Mike
Your post is using an offensive slur to refer to gender orientation. It's not funny, it's hateful and rude. I'd encourage you to take it down and try to be more kind and respectful.
Old Dec 29, 2021 | 06:17 PM
2017All4's Avatar
2017All4
Super Moderator
Posts that were found to be offensive were edited out.
I think we all need to remember that these forums speak to a diverse audience.
Old Dec 29, 2021 | 09:50 PM
Mini_Crazy's Avatar
Mini_Crazy
Let's get back to putting a LSD in a Mini. . .
Yep, that's for two of Mini's overpriced 1.6ml tubes of 518 Loctite.
You can buy the 2ml version of 518 Loctite for $6/ea via Amazon Prime. That will be more than enough anaerobic to seal up the "tranny" (common shorthand for transmission for more than 60 years in the performance industry).
Ripper, please define "better" . I have seen no side-by-side performance testing that indicates Wavetrac is any better than Quaife. Both are gear-type LSD's. Wavetrac claims "newer-better" technology than Quaife, but I'd like to see the measured results. Anybody else?
For serious track cars with aggressive drivers, OS Giken has some measurable performance advantages, but it's also reportedly noisy, pricey and may require occasional tuning, so maybe not in a daily driver.
Old Dec 29, 2021 | 10:37 PM
RIPPER's Avatar
RIPPER
[QUOTE Wavetrac claims "newer-better" technology than Quaife, .[/QUOTE]
that’s what I ment. Does anyone know the difference between the two?
Old Dec 30, 2021 | 01:54 AM
cmt52663's Avatar
cmt52663
Here is some information on that point.
This article does a good job I think.
Cheers,
Charlie
Old Dec 30, 2021 | 03:05 AM
deepgrey's Avatar
deepgrey
Huh. I thought that p/n was the 50 ml tube. 1.6 ml doesn’t seem like very much, but I don’t claim to be an expert on diff replacement.
Old Dec 30, 2021 | 07:58 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
Just to clarify because I'll be doing this job soonish.
Are the bushings you're talking about #5 and #6?
23117509744
23110530904
And,
what do you mean by the 'snout of the input shaft'?
Thanks.
Old Dec 30, 2021 | 08:53 AM
MrBlah's Avatar
MrBlah
replace #2 at a minimum also #1 #5 and #6. I have seen leaking input (#2) and axle shaft seals, have not seen the other parts wear out but they are cheap and you are right there anyway...
Old Dec 30, 2021 | 12:58 PM
RIPPER's Avatar
RIPPER
Cheers,
Charlie
thank you!!!!
Old Dec 30, 2021 | 01:37 PM
adriancl's Avatar
adriancl
Will need also to recode ABS module for LSD.
Old Jan 2, 2022 | 09:23 AM
r53racer's Avatar
r53racer
I'm curious, what would happen if ABS is not coded?
Old Jan 7, 2022 | 07:15 AM
RIPPER's Avatar
RIPPER
23117509744
23110530904
And,
Thanks.
wouldn't these parts be changed out by shop if I was having lsd and clutch replaced at the same time?
Old Jan 7, 2022 | 07:41 AM
adriancl's Avatar
adriancl
I don't know, but i worked on few R50 conversion for 6-speed gearbox , without recoding in EMS for Getrag transmission and in ABS -MK60 module- for 6 speed transmission, the car was not driving properly.
Old Jan 14, 2022 | 09:03 AM
Soul Coughing
Great info and probably something worth doing to be 100%! I will give my anecdotal experience with throwing in a Quaife LSD on my old '03 that had an open diff; I had no drivability or issues (throwing codes) with the car.
MiniMio
Oct 19, 2016 11:16 AM
richardsperry
Feb 27, 2012 06:16 AM
AkFarina
Apr 23, 2009 08:01 AM
pyugala
Apr 3, 2006 12:57 PM
