Drivetrain Wiseco piston issues?
Old May 20, 2009 | 12:56 PM
  #26
alexmini08's Avatar
alexmini08
Any pics of the cp's?!?!?!
What is the compression in the CP pistons??
Old May 20, 2009 | 10:58 PM
  #27
Longboard Mini's Avatar
Longboard Mini
Here some pis of the CP Rotrex pistons.
CP3.jpg?t=1242885492
CP2.jpg?t=1242885419
CP1.jpg?t=1242885373
Old May 20, 2009 | 11:13 PM
  #28
Cali44redrocket's Avatar
Cali44redrocket
Mmmmmm....CP Pistons..... Some day Santa will bring those for me under the tree! Then life will be good! hahaha
Old May 22, 2009 | 01:35 PM
  #29
alexmini08's Avatar
alexmini08
THANKS!!!!!!!!!!! +1 for santa!!!!
Old May 22, 2009 | 07:31 PM
  #30
002's Avatar
002
Longboard,
Those dishes look pretty deep. Are they lower compression or higher perimeter to reduce quench area, maybe just chicago style.
Old May 24, 2009 | 06:01 PM
  #31
Cali44redrocket
Correct me if I am wrong but yes, they are higher compression.....but someone else will have to give you all the details. Not something I have dug too far into as of yet since it's not on my horizon.
Old May 25, 2009 | 08:34 AM
  #32
Revolution Mini Works's Avatar
Originally Posted by 002
Longboard,
these were custom ordered from a client in Thailand
these are made for a 1.8L stroker and are higher compression than stock
Old May 25, 2009 | 10:18 AM
  #33
Cali44redrocket
Thanks for confirming that Jan.....So any word on the Seattle area trip yet???
Old May 25, 2009 | 07:56 PM
  #34
the_rc_bandit's Avatar
the_rc_bandit
How long ago did you install these? this is a little discerning because i just got a set of the Wiseco 77.5mm. Havent finished assembly of the block. Had to wait for new block bolts. Dont know if I should disassemble these and try to return or take my chances.
Old May 25, 2009 | 10:57 PM
  #35
002's Avatar
002
I installed these about a year and a half ago. They broke last winter, I just didn't have time to look at it for awhile. They lasted about 15k miles of commuting. If it were one piston I may be able to undertand, but all of them were cracked in the exact same way and in the exact same place.
After looking at other designs, I don't think the wisecos have a chance. Compare these to stock and you'll see the difference in skirt support. The majority of aftermarket pistons have a similar or increased skirt strutting compared to stock. Why wiseco decided to reduce the strutting is beyond me. Actuallly, they said "they are forged and strong enough".
Obviously, I can't recommend them. A couple tuners have contacted me and confirmed that this failure is odd and consistant with the skirt design. At least one other user has reported piston slap and claims other failures. Is it possible that the pistons are of sound design and my car just had some unusual issue... Based on feed back, I doubt it. I wouldn'tbe able to trust them again.
I wouldn't use these unless you are in a position to tear it down at the first sign of piston slap.
Old May 26, 2009 | 06:26 AM
  #36
Thumper460's Avatar
Thumper460
Mic the cylinder and the piston at the skirt!! All this can be prevented IF the tolerances are correct!! IF the pistons are too small.. then get a hold of the manufacture.. and advise them...
Loose pistons are the responsibility of the engine builder.. However I do agree with all the above posts. Some times the Mic needs to be used when building an engine to make sure the clearances and tolerances are correct!!
Piston slap is the result of TOO much clearances.. ( either thru assembly.. or skirt failure) cool??
Just me........................
Thumper
Old May 26, 2009 | 02:48 PM
  #37
002's Avatar
002
Thumper
There isn't an issue with the tolerance. (from memory) Bores measured at 76.99mm, Piston skirt 76.88mm This puts the tolerance dead center of the recommended specs .004"
The piston slap I refered to is what will be heard as the skirts crack, reduce thier size (increasing the tolerance) and finally breaking apart.
Old Jun 19, 2009 | 11:55 AM
  #38
not-so-rednwhitecooper
I contacted a good friend of mine who works for Wiseco here in Mentor. He gave this thread to one of the engineers to read over. He says send the pistons back to them, they will examine the pistons, so a stress test and such and determine what happened. He also said, as long as it was an issue on their end, they will pay for all of the machining to repair the damages.
He also said out of all of the MINI pistons they have made (3,000 or so sets according to him) this is the first set he has heard issues with.
PM me if you, or anyone else who may have had issues with a set of Wiseco pistons, would like the necessary contact info at Wiseco.
Old Jun 19, 2009 | 12:56 PM
  #39
I'm having a hard time believing 3000 sets of Mini pistons
Old Jun 19, 2009 | 01:05 PM
  #40
fullcollapse40's Avatar
fullcollapse40
[quote=Revolution Mini Works;2799986]I'm having a hard time believing 3000 sets of Mini pistons[/quot
nobody said they SOLD 3000 sets of MINI pistons. must be a warehouse full of them somewhere.
Old Jun 19, 2009 | 01:51 PM
  #41
Thanks, but i'll believe the info from the horses mouth.
Old Jun 19, 2009 | 02:17 PM
  #42
checkmate2006's Avatar
checkmate2006
I feel like doing a little math they have 750 sets of 4 which is 3000 individual pistons. If I am wrong that is because I suck at math
Old Jun 19, 2009 | 03:47 PM
  #43
Look, i'm not here to start another war. I'm sick of that **** on this site, and its the main reason I don't visit this site anymore.
He didn't clarify if it was 3,000 individual or 3,000 sets. He said they have been running them for 3 seasons now. Thats alot of time to make alot of pistons. I have a few friends in different parts for the company, and they are still up and running 3 shifts, 24/7.
I came here to offer to help everyone, others running these pistons, the OP 002 and any potential future Wiseco customers.
The person that looked over this thread said that either I could take my time to contact the OP or he would have to contact Wiseco directly, they aren't going to take the time to help someone that wont help themselves. They need to see these pistons in order to help determine who is at fault here.
Old Jun 19, 2009 | 05:55 PM
  #44
[quote=fullcollapse40;2799990]
I think you hit the proverbial head of the piston here
Old Jun 20, 2009 | 02:28 AM
  #45
scolburn79's Avatar
scolburn79
Are these CP pistons just a straight swap out for the stock ones and what benefits would I see from them?
Old Jun 23, 2009 | 10:53 PM
  #46
002's Avatar
002
Not so red and white cooper,
Thanks for the info. As originally posted, I did contact wiseco myself before starting this thread. They weren't very helpful. Basically the phone operator told me that it was my fault and I most likely caused the problem myself because "wiseco pistons are forged and they have sold thousands of sets". He gave me the number of someone that could "test" my pistons, but that person never returned my call.
I have not taken it any further with wiseco because the tone from them was to get lost. I will make one more attempt to contact them. Mostly to prevent it fom happening to others and to give wiseco a chance clear thier name in this thread.
I do not want this to become a product bashing thread. My goal was to get feedback from other customers. Also, to provide a result for other members that use the search function as there is very little info about pistons available.
I'll update this thread soon with a summary of how the project turns out.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
brother i
Aug 23, 2015 01:15 PM
Emnotek
Aug 13, 2015 05:47 PM
StealthR53
Aug 8, 2015 10:59 AM
