Drivetrain Anyone have their exhaust crack before??
Old May 11, 2009 | 04:18 PM
davisflyer's Avatar
davisflyer
While I was attending MOTD this year, my JCW exhaust cracked between the two center hangars. I had it welded back, but I was wondering if anyone else had seen their exhaust crack there or if anyone has an idea of what would cause this.
Old May 11, 2009 | 06:52 PM
fullcollapse40's Avatar
fullcollapse40
the hangers right near the resonator break off and take a chunk of the mid-pipe with them. I have had 2 of them do the same thing.
Old May 11, 2009 | 08:49 PM
davisflyer's Avatar
davisflyer
I wonder how long my weld will last
Old May 11, 2009 | 08:59 PM
fullcollapse40
the one I am running now was un-expertly welded about a year and a half ago. So far no problems to speak of. If yours ends up being a problem you can buy just the mid-pipe section of a JCW exhuast instead of having to replace the whole thing.
Old May 12, 2009 | 02:28 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
My rear section had a crack once where it meets the mid pipe...sucked! Very loud lol
Old May 12, 2009 | 04:11 PM
Longboard Mini's Avatar
Longboard Mini
My old Milltek cracked in a couple places and the bar welded between the tips on my new Magnaflow cracked and snapped off. I had them all fixed for cheap.
I think your going to find this happens a lot to both stock and aftermarket.
Longboard
Old May 12, 2009 | 08:46 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Only seen this happen on 2 JCW exhaust, but happens all the time on the Borlas
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old May 12, 2009 | 09:32 PM
D-MAN's Avatar
D-MAN
My JCW exhaust cracked in the same spot - just got it welded and so far it seems ok...
Old May 12, 2009 | 09:34 PM
davisflyer's Avatar
davisflyer
Good thing it only cost $10 to weld back up. Interesting that this would be a problem on a car with only about 20k miles.
Old May 12, 2009 | 09:42 PM
D-MAN's Avatar
D-MAN
Mine went around 30K km's
Old May 13, 2009 | 09:16 AM
2mD's Avatar
2mD
a friend of mine had the same problem ( jcw )
the weld had a pretty big end crater ( welding error ) -> thats where the crack startet
weldet it back together and no issues since
Old May 13, 2009 | 05:03 PM
Mezspeed's Avatar
Mezspeed
I have about 66,000 miles on my 05 S and about 50,000 on my JCW exhaust.
This might come into play with those that have cracked....for those of you who did not shed the ten or twelve pounds of resonator aft of the cat with a straight pipe, perhaps that additional weight along with the typically flexing of a sidewinder motor just might have been enough to exacerbate a crack in the pipe. Especially for those with a aftermarket header. Just a thought.
Old Jun 4, 2009 | 06:28 PM
huie's Avatar
huie
Why has no one had this problem fixed by MINI under warranty?
Old Jun 20, 2009 | 08:48 AM
Redcoat's Avatar
Redcoat
You can add me to the list of people that had their JCW Exhaust crack. Its right at the weld in the hanger right after the resonator. I have 65000mi on the car. I can weld it up myself but I think I will take it off the car to do it. On my 2006 the exhaust is all one piece from the cat back, so no replacing just the part with the resonator. What a bummer.
Old Jul 7, 2009 | 06:18 PM
CARdiac's Avatar
CARdiac
Add my wifes 06 to the list, 64K on the odo... wonder when mine will crack
Old Jul 7, 2009 | 09:10 PM
pat.hillyer's Avatar
pat.hillyer
I had my JCW pipe break at about 20K near the rear hanger on my '06. Bad initial weld, exacerbated by the brittle stainless. Dealer would not weld it as it would "void the warranty". When the new pipe came in (3 weeks), they replaced it and shipped the broken one back (Works wanted to examine the broken part). My thinking is just fix the weld!
Old Jul 7, 2009 | 10:49 PM
davisflyer's Avatar
davisflyer
In my case, I could drive 6 hours round trip to a dealership, or spend $10 and get it fixed locally.
Old Jul 8, 2009 | 06:08 PM
CARdiac's Avatar
CARdiac
$40 fix for me... I was looking at the hangers... bad design IMHO. If you have a hanger on both sides, why not just use a single hanger that sticks out on both sides and just weld that piece-go figure
Old Jul 9, 2009 | 04:20 AM
Crashton's Avatar
Crashton
What is the symptom of a cracked hanger? My JCW exhaust has started making a noise when I hit a sharp bump. Sounds like it is coming from the area of the hangers, toward the front of the pipe.
Old Jul 9, 2009 | 06:22 AM
CARdiac's Avatar
CARdiac
Sounds like a hole in the exhaust.... loud buzzing while driving.
Old Jul 9, 2009 | 06:36 AM
PrplPplEtr's Avatar
PrplPplEtr
i have.
twice so far.
44k miles and it's buzzing again, may just have to go for three before the warranty expires.
Old Jul 9, 2009 | 07:12 AM
Crashton's Avatar
Crashton
Thanks for the reply.
Maybe I'm lucky so far. Mine is a metallic clank, but only when hitting sharp bumps in the road, otherwise it is quiet. Guess it is off to the local exhaust shop for a bit of welding.
Edit.... I'm at 58,000 miles with maybe 45,000 on the JCW pipes. Way out of warranty
Old Jul 9, 2009 | 07:37 AM
chad1140's Avatar
chad1140
Add me to the list, it happened at about 18K on the odometer. I have a 2006 JCW car. It was covered under warranty.
Old Jul 9, 2009 | 12:10 PM
Minipitt's Avatar
Minipitt
i had mine crack in a few different places but its cause i have the Borla exhaust that sticks out an inch or so past my bumper. there are a few blind people in my neighborhood that park by braile...really affected throttle response
Old Jul 26, 2010 | 06:43 PM
minintrigue's Avatar
minintrigue
Just found out that mine is cracked up between the front hangers. Only 40K on the odometer so going to call MINI tomorrow and find out if they'll take care of me even though I'm 7 mos out of warranty. If not, probably will just have it welded.
