Drivetrain RMW Tuned after AMVIV
Old Apr 5, 2009 | 05:04 PM
  #126
Revolution Mini Works's Avatar
Originally Posted by Wake|MCS
Learn to interpret things.. He's not saying to look at the numbers in lower portion of the RPM band. He's telling you to look at PEAK numbers, peak being up top on Jan's tune and peak being somewhere near 4k without the tune. You'll notice peak torque increased by about 20, not 40 like you may, or may not be, interpreting from the dyno graph...
Before you call my a Mynes cronie keep in mind I'm looking at products from BOTH vendors. Simply tired of your remarks which have no real backing or merit. I do hope you can make it out to the tune party in South Florida if it happens. Then we can compare cars and hell, you can even drive mine pre/post tune so you can experience firsthand the results of a Mynes tune.
the post was put up like to to show area "under the curve" which was greatly increased. This is what is incredibly important to driveability and acceleration. It's not just about peak numbers. As you can see its 20-23ft lbs peak but the whole graph is higher than what he had before. It's DRAMATIC..................... at high rpms that kind of difference is devasting
Old Apr 5, 2009 | 06:18 PM
  #127
Mike@Mynes's Avatar
Mike@Mynes
Before you call me a Mynes cronie keep in mind I'm looking at products from BOTH vendors. Simply tired of your remarks which have no real backing or merit. I do hope you can make it out to the tune party in South Florida if it happens. Then we can compare cars and hell, you can even drive mine pre/post tune so you can experience firsthand the results of a Mynes tune.
Finally, someone who can look at the graphs and INTERPRET the curves correctly. I posted that simple question and everyone thinks i'm bashing or hating....
The points i'm trying to get across are these:
1. Learn to observe data put forth and come up with your own conclusion.
2. If your conclusion does not match what's put forth, then ask the right questions to get a clarification.
3. For the car to nose-dive on the torque like that, it's a tell-tell sign that the car has mechanical issues.
And finally...If you're asking the honest questions on this board, prepare to be attacked.
CASE CLOSED...
Old Apr 5, 2009 | 06:26 PM
  #128
yellowbritishrocket's Avatar
yellowbritishrocket
oh was that a threat mike?
cuz to me that sounds like a open threat...ok clown game on
  #129
CASE CLOSED...
case closed?
typical answer from you mike
try looking at all dyno graphs of Mini's on a dynapack with the stock header
you might learn something
then again.......maybe not
you may understand Mustang dyno's but knowing what's normal on a dynapack you sure don't
really classy threatening people... real classy
Last edited by Revolution Mini Works; Apr 5, 2009 at 06:27 PM. Reason: why not... MIKE DOES
Old Apr 5, 2009 | 06:28 PM
  #130
Partsman's Avatar
Partsman
Legion_of_Doom
You have serious issues, man.
Old Apr 5, 2009 | 06:30 PM
  #131
yellowbritishrocket
no no...im sorry i have a serious problem with someone threatening me...call it a habit of spending time in a combat zone...
Old Apr 5, 2009 | 06:33 PM
  #132
Partsman's Avatar
Partsman
Legion_of_Doom
I think he's saying that if the people on here(including him) are asking honest questions...then they are the ones that should be prepared to be attacked.
Old Apr 5, 2009 | 06:34 PM
  #133
yellowbritishrocket
thats not how i read it....he had better make his point really crystal clear
  #134
Partsman's Avatar
Partsman
Legion_of_Doom
I don't think Mike was threatening you...see my post above.
Old Apr 5, 2009 | 06:36 PM
  #135
ninjlao's Avatar
ninjlao
Ninja Mini
Originally Posted by Intense
I Dyno'd my car on a mustang dyno with the following mods at COBB Racing: 17%, Invidia catback, DFIC, CAI no tune
Here is the BEST RUN out of three on COBB's mustang dyno ~ 160hp and 146trq
Rob, It looks like your base dyno numbers and the Mynes "Green Machine's Dyno" numbers are almost identical... both of our Mustang dyno read pretty close.
Your Base Numbers on Cobb's MD: 160whp/146wtqe with stock rev-limiter 6950rpm.
Mynes Base Numbers on our MD: 171whp/149wtqe with rev-limiter raised to 7300.
As i stated in my Post #2 of the Mynes Thread, we raised the rev-limiter to 7300rpm b/c that's where MINIs make the peak horsepower (you "ole tried and true experienced R53 tuner" should have told you that, no?). So if you raised your Rev-Limiter were to be raised to 7300rpm, and i'm sure your base dyno number would be around 170whp.
So bottomline is this: Your MINI and the MYNES Green MINI start at the SAME BASELINE numbers!!! You proved it right here... Even though you have the 17% pulley and the exhaust, the car does NOT take up all the adaptions and make power on its own... that's why a custom tune is really important to harness all the potential of these upgrades. By increasing the rev-limiter 350 rpm (from 6950 to 7300), any mini is going to make more power.
So your observations about the Mynes MD reading high is unfounded. So if you want to find out how much power your car is really making right now, just take your car back to Cobb's MD and you'll get the REAL Dyno number
Cheers.
mike
In my personal opinion, one of the biggest problems on this board is reading comprehension. Please read posts in its entirety before commenting.
On a side note: I have my parts on order and I'm giddy with excitement Can anyone guess who it is?
Old Apr 5, 2009 | 06:37 PM
  #136
yellowbritishrocket
oh i saw it...i said HE had better make his point crystal clear...i wanna hear it from him because if that was a open threat directed towards me....
  #137
Mike@Mynes's Avatar
Mike@Mynes
CASE CLOSED...
Clarification on this statement...
"And finally...If you're asking the honest questions on this board, prepare to be attacked."
I'm just saying, if someone were to ask the honest questions, prepare youself to get attack by other posters (i.e. what's happening in this case)...
Old Apr 5, 2009 | 06:38 PM
  #138
yellowbritishrocket
as i would expect
Old Apr 5, 2009 | 06:39 PM
  #139
Wake|MCS's Avatar
Wake|MCS
Seems like you have issues with comprehension lmao... Partsman is right, Mike@Mynes wasn't threatening you...
Old Apr 5, 2009 | 06:41 PM
  #140
ninjlao's Avatar
ninjlao
Ninja Mini
I asked an honest question on your Myne's tuning guide thread and I got attacked. So...really all this talk is just blowing smoke up each others @$$.
Old Apr 5, 2009 | 06:42 PM
  #141
yellowbritishrocket
that statement read if u post prepare to be attacked.....there are other ways he could have posted that without it sounding like an attack
Old Apr 5, 2009 | 06:44 PM
  #142
yellowbritishrocket
see it seems to me that there is flaws in mynes logic and business model...and if u poke hard enuf they get extremely defensive...what started all this was when i pointed out a few things and got pounced on by a few butthurt individuals
Old Apr 5, 2009 | 06:50 PM
  #143
Partsman's Avatar
Partsman
Legion_of_Doom
Yes you did(ask a honest question)...after you made the Mynes guys jump through hoops for you.
Old Apr 5, 2009 | 06:59 PM
  #144
+1
on the side note... did you order your onwhorizen intake?
Old Apr 5, 2009 | 07:02 PM
  #145
yellowbritishrocket
lol jump through hoops?nothing that i said couldnt be answered simply...that is if they had a legimate answer...
Old Apr 5, 2009 | 07:11 PM
  #146
Wake|MCS's Avatar
Wake|MCS
Lmao you realize he wasn't referring to you, right?
Old Apr 5, 2009 | 07:33 PM
  #147
ninjlao's Avatar
ninjlao
Ninja Mini
So that automatically makes my question null and void?
  #148
ninjlao's Avatar
ninjlao
Ninja Mini
+1
All information regarding my vehicle is top secret. But...I will take pleeeenty of pictures when they arrive in the coming months.
Old Apr 5, 2009 | 07:47 PM
  #149
mdbsat's Avatar
mdbsat
I was thinking the EXACT same thing earlier.
Old Apr 5, 2009 | 08:01 PM
  #150
davisflyer's Avatar
davisflyer
Originally Posted by RECOOP
Some people like and are satisfied with RMW products/service, and some people like and are satisfied with Mynes & ABF products/service. What's the big deal? Yes, customer loyalty is important , but, IMO, there's still plenty of room out there for different products and different approaches.
+1
