Drivetrain Boost? After a lot of goodies?
Old Mar 10, 2009 | 05:27 PM
mariomllr's Avatar
mariomllr
i just installed the full alta set up , boost tubes ,big intercooler,air intake no exaust yet but its coming on friday, now how musch boost you guys get, i see only 10 to 11 psi is that correct? even with sport mode ingage if thats make differance,i just want to make sure that there is no leaks thanks guys
Old Mar 10, 2009 | 05:30 PM
AkFarina's Avatar
AkFarina
i have there cold air intake and a custom exhaust but i still have both my cats mine is a 09 build month is september i think and i peak out at 15
Old Mar 11, 2009 | 01:01 PM
got.pho?'s Avatar
got.pho?
i peak @ 15
Old Mar 11, 2009 | 03:34 PM
richi0207's Avatar
richi0207
Hit 21 psi last night
Old Mar 11, 2009 | 04:19 PM
iwashmycar's Avatar
iwashmycar
lol i see 12 w just...well....nothing
Old Mar 11, 2009 | 05:11 PM
scottab36's Avatar
scottab36
Don't forget to mention that you are running the ALTA PnP ECU set up. Most folks will not get near 21 PSI...
I so far have seen a peak of 15.1 PSI with the JCW Stage One tuning kit.
Old Mar 11, 2009 | 05:47 PM
mariomllr's Avatar
mariomllr
well i only see 11psi max no ecu upgrade
Old Mar 11, 2009 | 07:06 PM
Noegel's Avatar
Noegel
You won't see any more boost. The computer just won't let you. Without a tune, you will NOT see the full effects of your modifications. The ECU cuts timing and other things...
In fact, at least with my automatic, it is extremely obvious in first gear. I will have terrific acceleration until about 5000rpm and then the car just seems to slow tremendously, and you can hear the blow-off activate early.... ugh... we need tuning!
You can see the effects on ALTA's website, under the boost tubes.
Old Mar 12, 2009 | 11:11 AM
mariomllr's Avatar
mariomllr
so how much boost do you see?
Old Mar 12, 2009 | 01:56 PM
chakraj's Avatar
chakraj
You should also be sure to turn off the traction controle, that will make sure you are making the most boost you can.
Old Mar 12, 2009 | 03:17 PM
mariomllr's Avatar
mariomllr
ok guys that doesnt tell me how mush boost you guy s are running without any software
Old Mar 12, 2009 | 04:24 PM
scott48's Avatar
scott48
i can hit 15psi with no tune
Old Mar 12, 2009 | 05:24 PM
AkFarina's Avatar
AkFarina
i have no tune and i got 15
Old Mar 12, 2009 | 05:30 PM
richi0207's Avatar
richi0207
Without the pnp ECU, I was getting 15 PSI
Old Mar 12, 2009 | 08:37 PM
mariomllr's Avatar
mariomllr
what years are your minis? mine is an 09 and 11 psi, i guess they make less power then that the early ones
Old Mar 12, 2009 | 11:03 PM
AkFarina's Avatar
AkFarina
mine is 09
Old Mar 13, 2009 | 03:05 AM
JAceMin's Avatar
JAceMin
Keep in mind if you are reading a boost gauge it is not a calibrated device so accuracy is not there.
Old Mar 13, 2009 | 05:21 PM
mariomllr's Avatar
mariomllr
so now what is that overboost you guys are talking about?
Old Mar 13, 2009 | 08:37 PM
Noegel's Avatar
Noegel
Scangauge reports about 26psi, and I'm at sea level = 12 +- psi. Stock ECU.
Old Mar 13, 2009 | 08:46 PM
alittletoored's Avatar
alittletoored
Does anyone out there have an 08' with a stock tune? If so what are you seeing?
Old Mar 13, 2009 | 08:48 PM
alittletoored
Do you mean +-14.7 psi at sea level?
Old Mar 14, 2009 | 05:06 AM
scottab36's Avatar
scottab36
Subtract about 14.7 PSIg at sea level.
Old Mar 14, 2009 | 10:37 AM
PureWorks's Avatar
PureWorks
15... w/JCW on a 04
Old Mar 14, 2009 | 03:41 PM
mariomllr's Avatar
mariomllr
what rpm do you guys see full boost ? im getting 11 12 psi not before 3600rpm
Old Mar 15, 2009 | 07:43 PM
Noegel's Avatar
Noegel
That is exactly what I meant... I said I'm getting 26psi which is equal to about plus or minus 12psi, since it is impossible almost to be directly at sea level, unless I'm driving on the beach.
26 - 14.7 = 11.3 plus or minus. This is just a scangauge... I work with what I got!
