Drivetrain Desperate HELP
Old Feb 12, 2009 | 05:06 PM
mbronsell's Avatar
mbronsell
Desperate HELP
Hi new member from England, where to start. I thought i was being clever buying some else's problem. I have a 2005 Cooper S 4500miles that has been converted to a single Turbo.
The main problem i have is it keeps triggering the MIL lamp and going to limp mode, it does this NOT when accelerating hard, but when you follow another car waiting to overtake so maybe 3rd Gear Light throttle holding boost about 7psi around 4000 rpm within a couple of seconds it will trigger Limp mode. Codes are P1241 P1688. I relocated the TMAP sensor before the compressor to get its air from the air filter housing, the main TMAP sensor is in the inlet manifold location. It is running NGK Iridium Plugs heat grade 9.
Please remember in the UK we have a lot of Roundabouts so the above situation happens alot.
The car appears to be running a standard ECU but has Larger injectors and a rising rate fuel pressure regulator
Any Help or pointers please.
Old Feb 12, 2009 | 06:48 PM
MrCooperS's Avatar
MrCooperS
Moderator
I would think RMW or Jan could help you with this as not much people convert their R53's to a single turbo...
Old Feb 12, 2009 | 07:46 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
PM this guy, trust me you will be very glad you did...He is responsible for most of the Minis in the United States that have converted to single turbo
https://www.northamericanmotoring.co...-megamini.html
Good Luck
Old Feb 12, 2009 | 07:52 PM
AZblackOUT's Avatar
AZblackOUT
Good Luck
+1
My roommate has a single turbo conversion on an R53...it used to do almost the same thing in terms of limp mode... we took it to hubie, aka MegaMini.
Old Feb 12, 2009 | 08:00 PM
M!N!-ME's Avatar
M!N!-ME
Hubie is an alright guy. I spoke with about twincharge options and he had no issues answering questions, just being all out helpful without the "I don't need your business" smugness (Disclaimer: I am not targeting anyone in particular with that statement, I'm just saying.....). When I get the bread together I will call upon him again. Go ABF performance!!
Old Feb 12, 2009 | 08:07 PM
AZblackOUT's Avatar
AZblackOUT
disclaimer understood...
also understand....
This guy builds custom manifolds that make THE BIG power... I treasure the seconds I get to pick his brain...
Old Feb 12, 2009 | 08:13 PM
M!N!-ME's Avatar
M!N!-ME
also understand....
Who you tellin? 10 sec. MINI/ ABF performance http://www.youtube.com/watch?v=i33lTY-AH4g
He can get you on the right track homes
Old Feb 12, 2009 | 08:25 PM
AZblackOUT's Avatar
AZblackOUT
imagine if that stuff was market... ::drool::
Old Feb 12, 2009 | 08:31 PM
M!N!-ME's Avatar
M!N!-ME
That's exactly what I did...lol
Old Feb 12, 2009 | 11:12 PM
DR FUH's Avatar
DR FUH
If you can list all the components/specifications of your conversion I am sure that I can help you get things sorted....
Feel free to contact me directly if you rather discuss in private.
Old Feb 13, 2009 | 06:04 PM
soccerbummer1104's Avatar
soccerbummer1104
you forgot, the suspension wasn't tweaked, and they have upgraded it now projected to run 8's this year
nother vid
http://www.youtube.com/watch?v=o1S-yIcIKhg
Old Feb 18, 2009 | 01:45 PM
minioneandrew's Avatar
minioneandrew
Mbronsell. Hello from the UK! Who did the conversion on the car in the uk?
You should join up on www.minitorque.com and let us know how the problem works out. There are a few planning single turbo conversions.
mni928
Oct 11, 2015 07:37 PM
mini-licious!
Jun 21, 2006 03:15 PM
paulmon
Tires, Wheels, & Brakes
22
Apr 27, 2006 07:06 PM
