Drivetrain About cold air intake
#26
#27
6. We also kept servicing the engine in mind. The filter element can be cleaned and re-oiled by opening up the filter compartment at the rear of the intake box. Oil can be changed without removing the AGS-R. For spark plug service, just remove the AGS-R (two M6 button head screws) and loosen the rubber downtube. This is a simple process that takes no longer than a couple minutes.
Having installed and removed it twice, I didn't find it a big hassle, but there is some.
Regarding heat, M7 says this:
1. Composite construction minimizing heat soak of the intake box.
9. Heat is enemy numero uno under the hood of the R56. Since part of the AGS-R sits above the turbo, a simple but very effective heatshield is included with the intake. For those wanting a step above, we offer an aerogel insert to futher defend against the heat. This will essentially be the same as the Turbo Heatshield we sell separately.
The heatshield is not shown in the photo, so I had the same concern. I called M7 to discuss this specifically. I found the heatshield a snap to install, and it basically covers the same area covered by the stock heatshield. It sits above the stock one, so there is an air space to help with heat dissipation. I also wnet for the optional liner, and find the heatshield to be quite effective.
The opening if the intake lines up nicely with the hood scoop, which I have opened completely. To me this seems the best way of getting cold outside air into the system without radical modifications. The other "CAI" systems I've seen draw in air from near the rear side of the engine, which I suspect is warmer than the outside air.
Anyway, I like it and it looks spectacular!
#28
^ thanks for the info. One last question tho! I was also looking at the DDMWorks RIS, then I started thinking that if the RIS is taking all of the scoops air supply none would be left to cool other engine componets, is the AGS-R lined up in a way that some of the incoming air is used for engine cooling? Or is this not an issue since the scoops come closed from factory?
#29
Great question!
#32
#33
I run a dry filter made by AEM on my diy intake.
-can you tell me what you used ...do you have a link to the AEM filter? ..what about hose attachments? -did you use a 90degree elbow hose? ...is the filter mounted anywhere? -or does it sit pretty snug in place?
would love more description of what you did,
thanks,
#34
NICE!
thanks,]
thanks,]
#36
In my directions for the ALTA Intake, if you have to much oil on the filter and it contaminates the Mass Air Flow thing, all you need to do it spray it with non-chlorinated brake cleaner, let it dry, and you're set.
Just make sure there isn't oil residue on the filter. Sop it up with a paper towel and rag.
chrisx18240
R60 :: Countryman Talk (2010-2015)
26
03-16-2022 09:56 AM
