Drivetrain RMW Water/Meth kit
Old Jan 16, 2009 | 08:10 AM
  #76
newbs49's Avatar
newbs49
Jan
What mix do you use on your setup? Or what would be best.
Old Jan 16, 2009 | 10:01 AM
  #77
BlimeyCabrio's Avatar
BlimeyCabrio
Also anything more than 50/50 is flammable...
And always be careful when working with chemicals... we had a guy I knew here about 20 years ago that put his Ferrari 308 in a ditch. He decided to fix it himself. Got fiberglass resin on his hands... used octane booster to try to clean it off... and it killed him DEAD. Quickly.
Old Jan 16, 2009 | 10:40 AM
  #78
Revolution Mini Works's Avatar
Originally Posted by newbs49
Jan
All depends on the setup and tank
Old Jan 16, 2009 | 01:14 PM
  #79
NOTDULL's Avatar
NOTDULL
I read today Methanol is reactive with aluminum (acts as an acid). Are there any issues with running 100% on the Mini?
  #80
Thumper460's Avatar
Thumper460
Great stuff ... is there any results on the HP gains on a MCS?? befor and after tune?? and sheets ?? Got to admit this w/m is the key to a lot of power.. what did you get from a few of your cars?? I suspect the tuning is a big key ..yes??
Just me.................................
Thumper
Old Jan 16, 2009 | 03:03 PM
  #81
//MZero's Avatar
//MZero
Jan, any plans to set this up to use the headlight washer tank. I understand the need for many to have a separate tank, but I'm sure a lot of us that prefer the sleeper/hidden look would be happy using the headlight tank. Less lines, no lines in the cabin to potentially break inside, no pump sound from inside the cabin...only loss is you cant use those oh so cool windshield washers any longer
Eric - The oil cooler caller
Old Jan 16, 2009 | 03:47 PM
  #82
big howe's Avatar
big howe
I did it a long time ago to my car. There are positives and negatives. If someone is interested I can forward details.
Old Jan 16, 2009 | 04:41 PM
  #83
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
How much can your washer fluid tanks hold?
Old Jan 16, 2009 | 05:07 PM
  #84
big howe's Avatar
big howe
I think the windshield is a little over two quarts. The headlight is almost 3 quarts. But I'm not sure of exact numbers. Like I said, filling almost daily(or sooner) if driven hard. You could always carry a sealed jug in the trunk I suppose. 50/50 isn't directly flammable so.... Or for the really ambitious, you could tie both tanks together for about 1.25 gallons.
Old Jan 16, 2009 | 05:30 PM
  #85
D-MAN's Avatar
D-MAN
Any before and after dynos of the power gains with this system?
Old Jan 16, 2009 | 07:21 PM
  #86
scolburn79's Avatar
scolburn79
Maybe if you looked at the start you wouldn't have to ask
Old Jan 16, 2009 | 09:34 PM
  #87
Thumper
are you asking what a good tune looks like ?
Old Jan 16, 2009 | 09:52 PM
  #88
Longboard Mini's Avatar
Longboard Mini
So Jan, (AKA Donky boy)
For anyone who has an old style W/M system can it be updated to the new system?
Longboard
Old Jan 16, 2009 | 09:55 PM
  #89
Longboard
if you have the right style of pump........yes
Old Jan 16, 2009 | 10:15 PM
  #90
silversmoke06's Avatar
silversmoke06
Looks like Longboards watercooled check book is gonna get another run....LOL
Old Jan 16, 2009 | 11:06 PM
  #91
//MZero's Avatar
//MZero
After you get my first question, answer this one. Danny's car...over 300whp on M45 with Meth?!?
Old Jan 17, 2009 | 12:31 AM
  #92
D-MAN's Avatar
D-MAN
Found it
So a 12 hp gain
Is that with the meth and a tune for the meth
or
Just the meth on a standard map?
Old Jan 17, 2009 | 12:39 AM
  #93
D-MAN's Avatar
D-MAN
How's the car going?
Any dynos yet Stephen?
I am looking forward to see how much hp you put down with all your RMW goodies on an Aussie dyno...
Old Jan 17, 2009 | 03:50 AM
  #94
scolburn79's Avatar
scolburn79
No Rush for me, it is just a work in progress. Will let you know though when it happens
Old Jan 17, 2009 | 07:53 AM
  #95
sure it can be done
Just don't think the blower is big enough
Found it
So a 12 hp gain
or
this was on a highly tuned car already, the gains would be even bigger on an untuned or improperly tune one
the beauty of the system is the repeatability. It will run those numbers over and over unlike what a normal car will do because of the heat soak
Old Jan 17, 2009 | 07:54 AM
  #96
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Wow, this is a great looking setup & has some serious promise. The sheer bling factor of the red tank is solid. What's the capacity of the red tank & how often could you be expected to fill it?
Old Jan 17, 2009 | 08:08 AM
  #97
I believe it's 3gal
It all depends upon how you set the controller. Probably around 3-4 tanks of gas if set on the half way mark
Of course on the track it would be more often
Old Jan 17, 2009 | 08:30 AM
  #98
//MZero's Avatar
//MZero
Thanks for the info Jan! Poor little M45
Old Jan 17, 2009 | 08:56 AM
  #99
2mD's Avatar
2mD
Found it
So a 12 hp gain
or
i think what he wanted to know was: were both dyno runs on the same tune ? or did you modifie it to run with water/meth ?
and something i want to know: what mixture did you use ? 50:50 ? ( it kinda sounded like u used 100% )
Old Jan 17, 2009 | 01:24 PM
  #100
D-MAN's Avatar
D-MAN
So a 12 hp gain without a specific "meth" tune.
What gains could you expect if you specifically tuned for the meth using this system?
