Drivetrain Is clutch going
Old Aug 18, 2008 | 07:09 PM
markp's Avatar
markp
Rush "Roll the Bones"
Is clutch going
I replaced my clutch last Nov. with a Stage 1 aftermarket and lightend Flywheel. In the last few weeks it seems to be slipping .. It engages and disengages fine but if I try to take off fast it slips until it finally catches up.. It will do the same thing if I'm in a gear and really punch it, it slips with the revs going up until it seems to engage. Is it the clutch or can there be an adjustment that can be done...if it's the clutch should I go straight to the stage 3...
Old Aug 18, 2008 | 07:51 PM
jhiggs26's Avatar
jhiggs26
Sounds like it's going on you. Are you running an organic disc then? What flywheel and pressure plate are you running?
Jeremy
Old Aug 19, 2008 | 03:32 PM
markp's Avatar
markp
I'm running a Spec 1 with a fidnaza flywheel. All the usual mods including a head and Jan tune.. It only has around 10k since installed.
Old Aug 19, 2008 | 03:40 PM
COR BLMY's Avatar
COR BLMY
you may have glazed it...
try just driving normaly (no heavy loads ...like spinning tires or hi RPM shifts) and see if it gets better.
10 k aint long ....
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
unxpectederror
Oct 22, 2015 12:16 PM
Oct 1, 2015 12:13 PM
Sep 28, 2015 09:13 AM
