Drivetrain Radiator Hoses
Old Jul 16, 2008 | 01:47 AM
yellowbritishrocket's Avatar
yellowbritishrocket
Radiator Hoses
Okedoke at 73k miles i think its about time to replace the t-stat and radiator hoses so i have these questions:
Ive pretty much decided between the Alta and Samco hoses...any thoughts...pros/cons and what are people running and any problems...
my next question is this...anyone who is running the m7 t-stat...where do you live and have you had any problems with it
thanks much
Old Jul 16, 2008 | 09:16 AM
Bhozar's Avatar
Bhozar
I use the samco hoses. I have no idea what the Alta ones are like.
If you use the samco hoses make sure you DO NOT use a spanner on the flats on the bleed screw. Many people do this, and its fine to start with, but eventually the pipe will split. Do it tight by hand only. No need for anythign more.
Old Jul 16, 2008 | 01:02 PM
motorer03's Avatar
motorer03
ive got the m7 t-stat in Mass and the SES light turns on every now and again because of it. Other than that my temp. guage tells me its working perfectly
Old Jul 16, 2008 | 01:30 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Besides a color change, is there any real benifit to getting the non-rubber hoses? I realize they will not crack or bulge, but your stock ones did last 73,000 miles, they are still in good shape, right? Ok, so maybe longevity is the benifit, but still, does one hose type flow easier and improve efficiency over another? Are the Samco hoses any cheaper?
Old Jul 16, 2008 | 10:45 PM
markldriskill's Avatar
markldriskill
I went to the Alta's in red. Happy with them so far. They haven't leaked, budged or deformed at all. and I think they look sharp.
Old Jul 16, 2008 | 11:05 PM
billie_morini's Avatar
billie_morini
the thermostat is over rated
Old Jul 17, 2008 | 12:19 AM
silversmoke06's Avatar
silversmoke06
dont do the T-stat. Its bad for the motor.
Old Jul 17, 2008 | 03:00 PM
motorer03's Avatar
motorer03
not trying to hijack but im curious why you say cooler thermostat is bad for the motor?
Old Jul 17, 2008 | 03:06 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
A hotter engine runs more efficiently, and unless you live where it is above 100ºF all of the time, your engine will run too cold, thus inefficiently.
Old Jul 18, 2008 | 02:35 PM
motorer03's Avatar
motorer03
interesting.... i may have to switch back over sometime soon
Old Aug 8, 2008 | 02:05 PM
yellowbritishrocket
ok to revive this thread...i got a new stock t-stat and housing and fluid...just need to get the hoses...im leaning towards the samco ones...any other thoughts
Old Aug 8, 2008 | 02:47 PM
Nitrominis's Avatar
Nitrominis
Its not "bad for the motor" (term motor BTW is electric we have engines in most of are Minis that require the use of a thermostat )
There have been some Tuning companies that indicate there is a situation with the engine not getting to operating temperatures and hinders getting a good flash done? Also it has been posted that running a cooler T-stat may cause the engine light and to pull a code. Neither harm anything in the engine. M7 I believe uses a regular T-stant CNC cut to fit the MINI . Also to date BMW/Mini does not offer the seal/gasket separate. So be careful when changing the T-stant not to damage the seal/gasket.
The Alta Hoses or others that use silicone not only do they look great but there are many other benefits in using silicone over rubber hoses. To name a couple, higher heat rating, chemical protection higher pressure rating etc. Rubber hoses has always been a less expensive to use and will not last as long. You don't hear to many times of blowing a silicone hose out on a weekend run!
Old Aug 8, 2008 | 03:04 PM
Nitrominis's Avatar
Nitrominis
It is combustion temperatures not coolant? And even the combustion you want to control how hot it gets. See many posts on water/meth systems.
The biggest reason for higher degree thermostsats is for emissions.
So then when you say "a hotter engine runs more efficiently" it is the emission not performance. I suppose if you are looking for best gas mileage and lowest emissions then stay with the OEM T-stat.
I live in Ca on the coast the temp average about 70 and I have run an M7 for at least 3 years prior to changing to a highflow pressure balanced 160 thermostat for the last 2. Thats 5 years running a cooler then OEM t-stat with no harm to the engine.The ONLY issue I get is during the cooler months my creature comforts are not as cozy warm.
Old Aug 8, 2008 | 03:10 PM
Nitrominis's Avatar
Nitrominis
Anything other then rubber is an upgrade. You should mod away and pick a cool color hose for your MINI
Old Aug 8, 2008 | 04:58 PM
yellowbritishrocket
i went ahead and got the black samco hose kit....any samco users...did u use the original hose clamps or did you get a samco one and if so where
Old Aug 8, 2008 | 05:24 PM
Nitrominis's Avatar
Nitrominis
You might want to check these out. although new for MOSS they have been around for a few years. Work very well and look good also.
http://www.mossmini.com/Shop/ViewPro...eIndexID=65071
Gates' PowerGrip clamps are an idea long overdue. Unlike worm style metal clamps that have a tendency to loosen for no reason. Or worse yet, use their razor like edges to cut a gash in a radiator hose leaving you stranded. PowerGrip clamps are made from a heat shrinkable thermoplastic material that provides a strong and dynamic seal. What's more, they are completely resistant to all automotive fluids. For best performance, be sure to select the PowerGrip clamp that is closest to the OD of the hose once it is installed. Installation requires a heat gun (a 1000 watt hair dryer will work) to shrink the clamp to size. To remove an installed PowerGrip clamp, cut it with a soldering iron, or use the PowerGrip cutting tool. Use of any other cutting tool may damage the hose.
Old Aug 8, 2008 | 07:30 PM
yellowbritishrocket
anybody got the OD of the radiator hoses and anybody running these clamps?
Old Aug 8, 2008 | 07:34 PM
yellowbritishrocket
the only other issue i would have with these is they are not reusable
Old Aug 8, 2008 | 10:08 PM
Nitrominis's Avatar
Nitrominis
did you not say that you got 73k on the OEM?
yes that is a thought but ......how often did you have to remove the hoses in 72k? It is the best cheap insurance to both totally prevent any leaking at the hose end and they will not damage the hose in anyway like clamps can do.
I have had these on my other cars. but not yet on my mini. I am still working on the electric water pump and removing and installing the hoses to often. but they will be on soon enough.
Old Aug 8, 2008 | 10:44 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
...The biggest reason for higher degree thermostsats is for emissions.
That was what I ment by more efficiently.
Its not "bad for the motor" (term motor BTW is electric we have engines in most of our Minis, that requires the use of a thermostat )
What about motorcycles, or motorsports?
Old Aug 8, 2008 | 11:02 PM
Nitrominis's Avatar
Nitrominis
Ya I knew thats what you ment. I was just being me
As for motorcycles I run 100% water and Redline water wetter. Also drill extra relief holes in the thermostat flange to allow more flow when the thermostat valve is closed. This helps lower coolant temp and reduce high/low temperature fluctuation. This is also the standard on how I modify my minis thermostat.
Old Aug 8, 2008 | 11:34 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I was talking about your comment on Engine vs Motor. The two terms, although distinct, can be ambiguous.
Old Aug 8, 2008 | 11:52 PM
yellowbritishrocket
you do have a point...its just an old habit about things that once they are on thats it...but what the hell ill give em a shot...prolly keep some standard clamps as back up...i do alot of travelling so i like to keep stuff i might need with me....is it worth getting the redline water wetter or go with something like purple ice from RP
Old Aug 8, 2008 | 11:57 PM
Ancient Mariner's Avatar
Ancient Mariner
Nabeshin; not to stick my oar in the water where it doesn't need to go, but from a technical/electrical/engineering point of view, it's "electric motors" and "gasoline engines". At least that's what was beaten into my head by my teachers. Although, the two are used so interchangeably that I don't think it really matters anymore. My inner geek just twinges a little when it hears the terms used incorrectly.
I'll tell my inner geek to shut up now.
Old Aug 9, 2008 | 10:46 AM
Nitrominis's Avatar
Nitrominis
holy sh** that why I make the comments about it. Most never understand! In fact if we used the tern incorrectly written even if the content of the question was answered correctly it was marked as wrong.
nabeshinI was talking about your comment on Engine vs Motor. The two terms, although distinct, can be ambiguous
