Drivetrain Radiator Hoses
Old Aug 9, 2008 | 11:44 AM
  #26
kapps's Avatar
kapps
But why is Detroit the motor city? Outboard motor? Motoring?
Old Aug 9, 2008 | 12:32 PM
  #27
Nitrominis's Avatar
Nitrominis
hmm ? to ponder for sure?
Back on topic:
if you want to dress up the hoses these are a good alternative to the conventional clamps.
http://store.summitracing.com/egnsea...se+clamps&x=29
Old Aug 9, 2008 | 12:35 PM
  #28
gnatster's Avatar
gnatster
Hose Clamps
Want a quality reusable hose clamp. ABA brand.
http://www.bakerprecision.com/hoseclmp.htm
100% Stainless Steel, even the hardware.
Rolled edges that will not cut into the hose
Stamped threads to provide even force over the entire face of the clamp.
Old Aug 9, 2008 | 12:46 PM
  #29
Nitrominis's Avatar
Nitrominis
Originally Posted by gnatster
Hose Clamps
I forgot about these. I
use these on all my smaller stuff like heater hoses and Fuel lines.
Off topic. looks like the Motor in the name Detroit Motor City has more to do with entertainment rather then a power unit.
http://en.wikipedia.org/wiki/Motor_City
Old Aug 9, 2008 | 04:57 PM
  #30
yellowbritishrocket's Avatar
yellowbritishrocket
i like the ones gnat suggested or the t-bolt ones
Old Aug 9, 2008 | 10:45 PM
  #31
yellowbritishrocket
does anyone know the radiator hose size...i wanna order a t-bolt or aba clamp set but i dont know the hose OD or ID....much appreciated for any help
Old Aug 9, 2008 | 10:54 PM
  #32
Nitrominis's Avatar
Nitrominis
I have been using 1 1/4 id for my hose projects on the mini
Old Aug 9, 2008 | 10:56 PM
  #33
yellowbritishrocket
so the OD is 1 1/2?
Old Aug 9, 2008 | 11:07 PM
  #34
Nitrominis's Avatar
Nitrominis
sorry not sure right now. I changed what ever it was to the 1 1/4 id because of a project. I am pretty sure that at the radiator upper hose the od is around 47 mm which is about 2.
Old Aug 9, 2008 | 11:23 PM
  #35
yellowbritishrocket
okedoke...im trying to make sure i get the right size since i dont have a large amount of time to mess around with these
Old Aug 9, 2008 | 11:26 PM
  #36
Nitrominis's Avatar
Nitrominis
Saturday at 11:30 pm and you are working on the mini. dedication
Old Aug 9, 2008 | 11:31 PM
  #37
yellowbritishrocket
lol actually im at work....im going home on leave to indiana soon (from san diego its about 2k miles) and im checking and double checking everything and i have all the stuff needed to do the coolant upgrade(t-stat,housing,hoses,fluid,distilled water,water wetter) ....all i need are the t-bolt clamps and im ready to install...id like to do it all in one shot instead of having to do this particular install in stages
Old Aug 10, 2008 | 10:25 PM
  #38
yellowbritishrocket
hey nitro will the 1.50" work with these
http://cgi.ebay.com/ebaymotors/10-T-...mZ180273627632
Old Aug 10, 2008 | 10:48 PM
  #39
Nitrominis's Avatar
Nitrominis
yuper !
Old Aug 14, 2008 | 12:34 AM
  #40
yellowbritishrocket
the radiator hoses are in....i thought they would be wider but i guess comparing them to the old hoses is a bit of a miss match since the old ones are rubber and have expanded with time.....i like that the top hose is one piece....i think im gonna get a new expansion tank while im at it....anybody have a write up on the install....i have a bentley manual though id like to see how everyone else did it
Old Aug 14, 2008 | 01:17 AM
  #41
Bhozar's Avatar
Bhozar
Just remember not to tighten the bleed screw with a spanner. Its finger tight only! If you tighten it with a spanner, after a while it will split.
Old Aug 14, 2008 | 05:06 AM
  #42
chadtoolio's Avatar
chadtoolio
Originally Posted by Ancient Mariner
Nabeshin; not to stick my oar in the water where it doesn't need to go, but from a technical/electrical/engineering point of view, it's "electric motors" and "gasoline engines". At least that's what was beaten into my head by my teachers. Although, the two are used so interchangeably that I don't think it really matters anymore. My inner geek just twinges a little when it hears the terms used incorrectly.
I'll tell my inner geek to shut up now.
Yep, when I was a kid, a neighbor told that one to me....How come it's not called engine oil instead of motor oil?
Old Aug 18, 2008 | 12:05 AM
  #43
yellowbritishrocket
only one more part to go(t-bolt clamps)....so if i got this right its 5 quarts Coolant/ 5 quarts distilled water and 10oz water wetter...
Old Aug 18, 2008 | 08:09 PM
  #44
Nitrominis's Avatar
Nitrominis
I thought I read that you are using a water wetter? If so you will use less antifreeze to make it work properly. You may want to read the recommendations. Also look at the temperature region you will be operating your Mini in. You may not need a 50/50 mix, which is the maximum mixture between water and antifreeze. If you read the back on the antifreeze it is scaled for mixture. The more the antifreeze the hotter the coolant will run. Antifreeze raises the boiling point and lowers the freezing point. Coolant is a bad descriptive word for antifreeze. Less is better in hotter climates.
I like how you get everything ready for the project instead of finding things you need in the middle of it.
Old Aug 18, 2008 | 08:12 PM
  #45
Nitrominis's Avatar
Nitrominis
duh! I see it I just need to read. What kind of wetter is that?
Old Aug 18, 2008 | 08:30 PM
  #46
yellowbritishrocket
its the RedLine Water Wetter....it says a 50/50 mix + 10 oz of water wetter
Old Aug 18, 2008 | 08:42 PM
  #47
Nitrominis's Avatar
Nitrominis
I use REDLINE does it not say that to get the maximum bennifit lowering temperature to reduce the antifreeze?? I can't remember would have to go look at a bottle. But if thats what it recomends 50/50/ 10
Old Aug 18, 2008 | 08:46 PM
  #48
yellowbritishrocket
so what is a good year round mix
Old Aug 18, 2008 | 08:54 PM
  #49
Nitrominis's Avatar
Nitrominis
You are at work again
If you want to be smarter then most, seriously read the back of the antifreeze container. Use the bare minimum required for the environment you will most drive your MINI. If you get into colder area's ad straight coolant to increase freeze point protection.
You would be surprised if you read about coolants what you can learn to lower the operating temperatures of an engine.
Old Aug 18, 2008 | 09:00 PM
  #50
kapps's Avatar
kapps
It all depends on how cold it gets in your area. Normally, 30% antifreeze is considered a minimum to maintain its lubricating properties to the pump. This is the mix I use with Water Wetter on my classic Lotus. As Nitro said, look at the antifreeze container. They should list the freezing points at various mixtures. If it isn't on the container, look on their site. Water Wetter should help at any mixture level.
Also, I'm not sure if you get more coolant out when you change all the hoses (compared to a normal drain where you disconnect the lower radiator hose) but a normal drain shouldn't take more than 1 gallon total of coolant.
