Drivetrain m7 heat shield installed
Old Oct 4, 2008 | 07:55 AM
  #126
drno's Avatar
drno
i assume that the perpose of the double sided tape is to keep the shield from moving , which the felt tape wont. also how will the felt hold up to the high temps aroung the turbo?
Old Oct 4, 2008 | 08:16 AM
  #127
morbius's Avatar
morbius
Dr. Morbius
The heat shield when properly installed can only move a max of 1/16 of an inch, I checked that and tested it. Mine has not moved from where I have set the scribe marks. The felt will hold up much better short and long term than the double stick tape will. Its a cloth material and already compressed and designed for temps. The tape is foam is not designed for high temps.
I have had the shield for nearly a week and placed several hundred miles on it with no issues. Nothing says you have to do this, I did it because parts on a engine should not be glued down for any reason besides gaskets.
Old Oct 4, 2008 | 02:11 PM
  #128
myminirox's Avatar
myminirox
Originally Posted by morbius
Installed mine. I removed the double stick tape and replaced it with OEM felt strip so it can be removed for service without issues. Added a little detail to mine
I was wondering about this as I was sticking mine down, but I just went ahead and stuck it. Now I wish I'd done something like this too. At some point I may remove the shield and replace the tape as well..........
The "detail" looks great! Is that just an M7 decal?
Old Oct 4, 2008 | 02:27 PM
  #129
morbius's Avatar
morbius
Dr. Morbius
Yup, can be best applied with the shield is hot since the finish prevents the decal from sticking otherwise.
Old Oct 6, 2008 | 03:52 PM
  #130
M7's Avatar
M7
Hi everyone...
I do believe we finally licked all the issues we encountered the last few months, and with that we also enhanced the look of the heat shield.
The first couple of shapes worked on some cars (mostly early high mileage)
cars were the engine had settled in a millimeter or so. This was a maddening process, as my car (early 07 model) had no issues at all, and some other cars
barely shaved the paint of the hood.....
The final units Aerogel blanket is also light years ahead look wise, even though you'll never really see the blanket in most situations.
I also believe in a modular approach to our product, so I'm working on something special for the heat shield that will add some more value and functionality very soon.
Peter
M7 tuning
562-608-8123
M7 Heat Shield and Super-AGS photo by Morbius
Old Oct 6, 2008 | 04:01 PM
  #131
myminirox's Avatar
myminirox
Originally Posted by M7
Hi everyone...
Peter
M7 tuning
562-608-8123
What are your thoughts about replacing the double stick tape with a felt strip so it can be removed for service without issues.
Old Oct 6, 2008 | 04:50 PM
  #132
morbius's Avatar
morbius
Dr. Morbius
Peter,
It was worth the wait and headaches. Its working out very well that I will have to get more for our other mini's ! Thanks a million and great work, fit and finish is excellent.
BTW, if you want some of the felt that I used, let me know and I will send it to you for testing. You know how to find me
Cheers.
Old Oct 6, 2008 | 06:33 PM
  #133
dtsoccer6's Avatar
dtsoccer6
MMR,
Why don't you use 3M velcro in place of the strip. I'm going to do it that way since it will still hold real tight and come off and on plenty of times without having to worry about the adhesive wearing off.
Old Oct 6, 2008 | 06:43 PM
  #134
morbius's Avatar
morbius
Dr. Morbius
Be careful, melting point on velcro is rather low compared to other materials. Velcro glue rather a pain to clean up when it runs all over the place.
Old Oct 6, 2008 | 06:48 PM
  #135
dtsoccer6's Avatar
dtsoccer6
good point, maybe a test with a heat gun before install. I'll let everyone know what the outcome is. Thanks Morbius!
Old Oct 6, 2008 | 07:01 PM
  #136
morbius's Avatar
morbius
Dr. Morbius
That is how I tested the felt
Old Oct 7, 2008 | 09:16 AM
  #137
myminirox's Avatar
myminirox
I'll wait for your test results. Thanks in advance for doing this.
Old Oct 7, 2008 | 01:07 PM
  #138
dtsoccer6's Avatar
dtsoccer6
Test Results:
Ok, so the heat gun at the high temp owned the glue on the strip of Velcro. On the mid temp, made it sticky, but not messy. So I said what the hell and I tried it.
To my surprise, it works very well. Leaves no nasty residue and it sticks better than the 3M stick tape it came with. It obviously has a much stronger hold on the heat shield and is as easy as plug and play when removing it. Hope it helps!
Old Dec 16, 2008 | 07:03 AM
  #139
Ian Venieri's Avatar
Ian Venieri
After reading the above 138 posts I still lack answers to basic questions:
1. What is the temperature delta measured on the outside of the scoop/hood after a timed hard run?
2. What is the temperature delta measured on the turbo's hot and cold side after a timed hard run and engine shutdown in 5 minute intervals for the next 30 minutes?
In case measurements to item 1 show a decline one may suspect that measurements to item 2 may show an increase.
The manufacturer and the dealers are silent on the issue so maybe a user may be interested to run these measurements.
The concern is that while no significant temperature drop is measured on the outside of the scoop/hood, a temperature increase may be measured on the turbocharger after engine shutdown.
Anybody interested to know if their $200 shield is a cosmetic only mod that has the negative effect of cooking their engine?
Old Dec 19, 2008 | 10:30 AM
  #140
Ian Venieri
I talked to both M7 and Alta and they both state that no temperature measurements have been done and that none are planned. I offered to buy the product with a return arrangement in case it shows no benefits but it was declined.
If anybody has this product installed and they are willing to perform some simple measurements please pm me with an Email address. I will provide the equipment and instructions.
Old Dec 19, 2008 | 12:35 PM
  #141
wongtonsup's Avatar
wongtonsup
Has anyone with a 2009 MCS had this problem? They have a turbocharger, not a supercharger now and maybe it doesn't get hot enough anymore?
Old Dec 19, 2008 | 01:22 PM
  #142
fdavid's Avatar
fdavid
I have a JCW 09 and the scoop did bend. Check here:
https://www.northamericanmotoring.co...new-jcw09.html
Sexual Chocolate
Mar 31, 2019 08:02 PM
devicemanager
Jun 17, 2016 06:18 PM
theunlimitedone
Aug 31, 2015 08:17 PM
Chasp
Aug 22, 2015 01:26 PM
