Drivetrain m7 heat shield installed
Old Sep 22, 2008 | 09:39 AM
  #101
drno's Avatar
drno
adamsaltamini,
considering how long ago you promised a test and evaluation and still have not done so, i don't think any comment on someones speed is appropriate
Old Sep 22, 2008 | 11:13 AM
  #102
Nimcosi's Avatar
Nimcosi
Originally Posted by morbius
The two holes that you are referring to are the ones on the ali heads. Honestly, I would not use those for the possibly the same reason M7 decided not to, vibration and stress and can crack. The heat shield will vibrate somewhat in the direction that has the weakest points on those holes in the ali. When it does crack (and it will, just a matter of time), then possible warrenty issues can pop up .....
You would be better off replacing the bolts with threaded studs of the equal length, running a stainless washer and nut all the way down to secure the heat shield to the stud/bolt and then placing the shield on and capping it with a stainless acorn nut. Now you have the stock shield secure and the new just as secure without having to drill new holes or worry about other problems.
Hope that helps.
Now that is an idea. Thanks!
Old Sep 22, 2008 | 12:32 PM
  #103
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Originally Posted by drno
adamsaltamini,
It was meant as a joke! Sheesh. You people take things FAR too seriously.
PLUS: I still haven't had one to try. Thankfully, the NAM public and others have bought everything I had even before I could try one.
The one I did try before I sent it back didn't fit the 09 JCW car, and I mentioned how it could with some changes. Peter agreed, made some new ones, shipped them to clients with existing issues first on previous shipments and I should have one to try in earnest this week.
If I sell the stuff, why would I be jumping seriously on his crap here? PLEASE read the entire thread prior to posting!
Old Sep 23, 2008 | 11:47 AM
  #104
myminirox's Avatar
myminirox
I spoke with Shelley at M7 the other day, and she told me that the delay on my order was to re-shape the aerogel blanket. It was worth it, IMHO. The fit is perfect.
Old Sep 23, 2008 | 11:51 AM
  #105
ADAMSALTAMINI
RIGHT ON! That is excellent news!
Old Sep 23, 2008 | 12:22 PM
  #106
hdvato's Avatar
hdvato
Good to hear - When I received my shield, the aerogel blanket fitment looked like 'socks on a rooster'.
I sent mine back, awaiting the new design.
Old Sep 24, 2008 | 09:15 AM
  #107
myminirox's Avatar
myminirox
This rooster....
has some pretty good fitting socks.
Attached Thumbnails m7 heat shield installed-dscn0011.jpg   m7 heat shield installed-dscn0010.jpg
Old Sep 25, 2008 | 01:44 PM
  #108
hdvato's Avatar
hdvato
Here's what I'm talk'n about:
Old Sep 25, 2008 | 01:59 PM
  #109
myminirox's Avatar
myminirox
Yikes!
Attachment 37268 Attachment 37269
I see what you mean. If your replacement is anything like mine it should be a vast improvement.
Old Sep 25, 2008 | 02:29 PM
  #110
dtsoccer6's Avatar
dtsoccer6
jeeze i hope the one they sent to me isnt like that. good to know the replacements are looking great though.
Old Sep 26, 2008 | 01:40 PM
  #111
myminirox's Avatar
myminirox
here's what mine looks like installed
The fit is very nice.
Old Sep 26, 2008 | 03:11 PM
  #112
ADAMSALTAMINI
Looks MUCH better! Stephen in our purchasing dept, claims m7 is sending out 20 of the units today or monday. So we should be well stocked in the latest version early next week!
Thanks folks for the patience!
Old Sep 26, 2008 | 10:52 PM
  #113
dtsoccer6's Avatar
dtsoccer6
clean, tidy, and looks great! Can't go wrong with that thing. Awesome, thanks for the pics!
Old Sep 27, 2008 | 04:14 AM
  #114
hdvato's Avatar
hdvato
Old Sep 27, 2008 | 07:43 AM
  #115
dtsoccer6's Avatar
dtsoccer6
for the AGS-R connection! The intake that m7 makes bolts up to that section of the HS. Not a noob question at all, I thought the same when I was looking at it the first time and I even knew about the AGS-R.
Old Sep 28, 2008 | 10:23 AM
  #116
myminirox's Avatar
myminirox
I've now mounted the AGS-R onto those posts (will post pix soon!).
Old Sep 28, 2008 | 10:32 AM
  #117
morbius's Avatar
morbius
Dr. Morbius
Those posts are for either the M7 AGS scoop or for a future item that will mount there for folks with the Super AGS ....
Old Sep 29, 2008 | 06:18 PM
  #118
hdvato's Avatar
hdvato
Received my replacement shield today. The aerogel blankee fits perfect!
Old Sep 29, 2008 | 07:19 PM
  #119
futuremini's Avatar
futuremini
I guess I need to send mine back and try to get the new upgraded version. The one I have now has the slotted holes but not the new cut out sections.
Old Sep 29, 2008 | 10:01 PM
  #120
dtsoccer6's Avatar
dtsoccer6
you mean that little section on the bottom left of the HS?
Old Sep 30, 2008 | 05:12 AM
  #121
futuremini's Avatar
futuremini
Is that the only section they removed? Why did I think there was more modifications than that?
Old Oct 3, 2008 | 12:47 PM
  #122
drno's Avatar
drno
installed the new, new, shield. a number or places have recieved cuts- the old shield was a ***** to get unstuck from the double stick tape. didn't have the 2 threaded posts as i dont have an ags-r. one again the service from m7 was great
Old Oct 3, 2008 | 07:30 PM
  #123
morbius's Avatar
morbius
Dr. Morbius
Installed mine. I removed the double stick tape and replaced it with OEM felt strip so it can be removed for service without issues. Added a little detail to mine
Old Oct 3, 2008 | 08:01 PM
  #124
hdvato's Avatar
hdvato
Looks good!
Can you expand on the OEM felt strip?
Thanx!
Old Oct 3, 2008 | 08:26 PM
  #125
morbius's Avatar
morbius
Dr. Morbius
Findtape has rolls of various felt tape materials that are the same as the various makers use.
I always have stock on hand of felt materials in various thicknesses and widths to fix the issues. Some of the materials can be used exterior also.
Here is the link to one of the materials on findtape:
http://www.findtape.com/product412/J...tyne+Felt+Tape
So ... I removed the double stick tape since it will make it nearly impossible to get to some parts on the engine with the shield stuck down hard. I got a 2 mil roll of exterior grade felt in black out and put it in place of the tape (cut around the openings) and installed the shield.
This way I can remove the shield to get some of the wiring in the area and the MINI shop can remove it if they have to service the ignition wires without issues.
Hope that helps.
