Drivetrain gatorback belt part #
The OP has a 15% pulley-Is he looking for a Napa belt?
I have a 15% pulley.....and the Gatorback belt #which I put on my car is #4060537...repeat #4060537......If there is a Gatorback belt out there with the number 060535 attached to it,then I stand corrected.....I have'nt seen it.
The 4060535 Napa belt will work fine....it's what Mini service will try to put on If you have an aftermarket pulley,however it aint no Gatorback.
No I put a link to the exact same question. In that thread there was a link to the approprite size belts.
This was very easy to find, the 2nd page of this forum held all the information he needed. I quick search would have netted TONS of info on the subject. This doesnt just have napa belts it had them all, here I will quote it for you sense it was oviously so damn hard to find.
He is looking for a 19% pulley belt. you would just up the size to the next belt for the 15% pulley. But sense most use the same belt for both 15% and 19% I am sure either would work just fine. took all of two clicks of the mouse to find this wealth of information on belt sizes. with that same results ie: Gatorback 4060537
If I were you, I'd try to measure those two belts...out of curiosity...to see which one is actually longer.
Here are some common 6 rib belt sizes for our applications. I use the NAPA 60535. There may be some confusion between these different belts is the way that manufacturers measure them??:
NAPA 60535=54 1/8"/1375mm
NAPA 60539=54 1/2"/1385mm
Gatorback 4060537=53.74"/1365mm
Gatorback 4060539=54"/1371.6mm
Gates K60532=53 7/8"/1367mm (1368.4 per Google)
Gates K60535=54 1/4"/1379mm
Gates K60539=54 1/2"/1385mm
The Gates and the NAPA (I think made by the same company...) are close to the same for measurements vs. numbering system whereas the Goodyear belt is a little different.
For the 19% pulley, if it were me, I try the gates 60532 or the Gatorback 4060537.
platform i cant tell if your losing patience with me or griton but im just making sure because i went out and bought the 4060537 and everytime i search for threads i either get gates or napa belt numbers and that really doesnt help me with the gatorback.. not to mention when i search a thread that is titled to have information on the belt it get high jacked by 17%ers and totally loses focus..
i got a 4060537, ive been told it works.
Its me......and yes you got the right belt.
-I was just trying to save you from a long,dizzying slide into thread search hell
-I have experienced the same as you.I was emphatic because I know what I bought and how it worked-cheersThread
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
