Drivetrain Working on intercooler piping today
Old Jun 25, 2008 | 09:17 AM
Exhaust Depot's Avatar
Exhaust Depot
From: Orlando, my house is in fortlauderdale and im originally from da bronx
IM going to attempt to make some intercooler pipes today.
It will have provisions for mounting a BOV on it. I will be bypassing the noise generator too. If its not needed, "off with his head!"
The factory hoses are made of rubber. WHen the car goes into boost the hose swell up causing you to loose boost. When the hoses are warm it swells even more! Just by replacing the hoses on the Neon srt4 we got 1.5psi increase, on the EVO x we got 2psi, on the STI 2psi. The more rubber usually the more boost you get from it. Its not always the case but for 1 PSI of boost you get 1ohp (crank).
We will be installing a BOV on the pipe too for those who want it.
A a bov is NOT for making sound, those 99.9%of the people get it for that.
When you install a bov you will noticed the following:
Quicker recovery after a shift. WHat does that mean? IM sure you have heard the text book 101 reason for a bov. It prevents compressor surge. Yes thats one thing it does. A larger BOV can vent out more volume so you will noticed the following.
When your racing the engine, when you shift the boost does not go back up to 12psi etc right away. There is a slight delay before it does. Lets just say that it takes 300rpm before you hit full boost again right after a shift.
With an upgraded BOV, you will noticed that right after the shift, you will hit full boost at about 100rpm after the shift. This brings your power back online sooner, and thats what your suppose to notice with a BOV if your looking for it instead of looking for the sound.
I personally prefer to leave the factory surge valve in place and use it in conjunction with an upgraded bov. It works better being that you have two valves unloading the system. The only issue i have with stock surge valves of today is that its controlled by a solenoid. This causes added lag so i will be bypassing the stock surge valve today and will show you how its done when i have pix etc.
Old Jun 25, 2008 | 09:39 AM
ThumperMCS's Avatar
ThumperMCS
Hector, you sir are a busy man!
Excited to see them
Old Jun 25, 2008 | 09:48 AM
Exhaust Depot
you wouldnt have a clue how true that is! I bend pipe during the day and while your sleeping i tune this during the night (7 day work week FTL!) :
Old Jun 25, 2008 | 10:29 AM
Mozza's Avatar
Mozza
Hector, when exactly do you sleep? Can't wait to see this pipe.
Old Jun 25, 2008 | 12:57 PM
Bigjoeski08's Avatar
Bigjoeski08
Good luck with the pipes.
Old Jun 25, 2008 | 01:31 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Can't wait to see this Your exhaust is very nice
Get some rest
Old Jun 25, 2008 | 01:47 PM
got.pho?'s Avatar
got.pho?
cant wait! i got a question tho... is inter.pipe mount for a bov a good spot on a mini? due to the position of maf. would it not cause it to be rich? just a thought. i might be wrong. but o well, no harm asking
Old Jun 25, 2008 | 01:53 PM
Exhaust Depot
"Sleep is for the useless and weak."
I should put together a compulation of quotes that ive come across these years and publish a book with them.
Old Jun 25, 2008 | 02:10 PM
Mozza's Avatar
Mozza
Hector any chance you can answer my question in the 'Custom 3" Magnaflow' thread?
Old Jun 25, 2008 | 02:11 PM
Exhaust Depot
On a car thats a full MAF setup you have issues of it stumbling because there are no map sensors in the system. The mini has both so yes it will run a tad rich when you lt off the gas and stop at light etc. HOwever when your going through the gears and shift its not a big issue because that added fuel helps keep the turbo spooling when it lights in the manifold. Its not like you will be cruising on teh highway and running rich to where your fuel milage will go down. YOur fuel milage will go down because you will get on it more to hear it vent .
My local custoemrs ask me if their fuel will go upw ith an exhaust mod. i tell them yes and then no. I tell them that the added music will cause them to get on the gas a little more when they leave a light. I know till this day im guilty of that.
Old Jun 25, 2008 | 02:29 PM
Exhaust Depot
I just looked over the factory bov and noticed that its it has 0 vaccum line going to it. :( IM going to see if i can disconnect it and trick it so it wont cause a CEL issue and ill have the aftermarket control boost on its own. Ill see what i come up with.
Old Jun 25, 2008 | 06:12 PM
Exhaust Depot
HELP!!!!!
Dudes the pipes are NIGHT AND DAY!!!!!!!!!!! I did both the hot and the cold side pipe. THe great news is that the thing is pulling like a monster. YOu feel it really good in 3rd.
The bad news:
The hose popped on me for rushin and trying tog et out of here. 9pm. : (
The stock piping is 2" in some spots. Im giogn to use those resonators for an exhaust im workign on. I went 2.25" on the plumbing and on the cold side i opened it up to 2.75" right before teh throttle body. I could not beleive how big the stock throttle body is for having such a small turbo system on this car!
Old Jun 25, 2008 | 06:42 PM
SlowB00st's Avatar
SlowB00st
Originally Posted by Exhaust Depot
HELP!!!!!
The bad news:
T-bolt clamps and/or beed the ends
PICS
Old Jun 25, 2008 | 06:48 PM
Exhaust Depot
PICS
I did both, the problem is that i cut one of the elbows a tad to short so i had to hold the silicon against the turbo while tightening the clamps.
Old Jun 25, 2008 | 07:01 PM
Mozza's Avatar
Mozza
Keep on keeping on Hector, if you know the problem was one of the elbows was cut short then you can rectify it right? Really excited to see the finished products, no CEL issues on your short run?
Old Jun 25, 2008 | 07:15 PM
lxjose9xl's Avatar
lxjose9xl
Very Very nice. I know that it will be extra, but for mine I like SS. Gotta have that bling!!!!!
Old Jun 25, 2008 | 07:42 PM
krim's Avatar
krim
hector, your VIN is showing!
j/k
Any idea on what price point we're talking about here?
Old Jun 25, 2008 | 10:26 PM
Exhaust Depot
j/k
Less than $270 and its $50 more with an HKS flange welded on the pipe. The setups will be powdercoated though .
Old Jun 25, 2008 | 10:27 PM
Exhaust Depot
The first always has room for improvement, especially when you finishing at 930pm!
Old Jun 28, 2008 | 06:52 PM
zach999's Avatar
zach999
any progress on this, Exhaust Depot?
all of your current projects look very promising. keep up the good work
Old Jun 28, 2008 | 08:24 PM
scruffylooking's Avatar
scruffylooking
Hector, never ever sleep. Keep pumping this stuff out. Thanks!
Old Jun 28, 2008 | 09:39 PM
Exhaust Depot
Well i managed to bang that one set out I have to get some different couplers to make my life easier.
Ive to much to chew right now so I was just showing you some things ill be banging out for you peeps in the future. Maybe a month or so or less?
Old Jul 1, 2008 | 09:48 AM
pillar's Avatar
pillar
how much did all this cost?
Old Jul 1, 2008 | 09:51 AM
Exhaust Depot
I have not come up with a price yet on it. I need to get different silicon pieces plus i might have the pipes powdercoated also in black.
Old Jul 1, 2008 | 03:47 PM
ENGINE 58's Avatar
ENGINE 58
yes i will be watching. anyway to make a bigger cold side tube , the one that comes out of the intercooler into the funky plastic tube. i was looking into getting the plastic tube from pelican parts and butchering it and making my own pipe but i havent yet. or can a whole new tube be made? it would be nice but i know it would be a ton of fab work. also will the tubes be powdercoated inside and out? thank you sir and please keep going the stuff your making is stuff we need.
