Drivetrain vote for alta bov or forge
im wanting to install bov but dont no which to get alta or forge if u have installed either plzz post comments about them wat u think about sound quality and ease of instalation
Forge, very sweet looking, simple part, becomes part of existing pressure relieve system. One of the bolts is a bit of a PIA, but then alot of the bolts and nuts on this motor are a PIA to get at.
Plus $65, nice well written clear instructions. Can actually see the parts in the photos.
thanx 4 the input but i c like 30 other people view this thread and only one person to give their oppinion if u view this plzz leave a oppinion even if u dont have a bov
this is tru but plzz stay on topic and i changed it thanx i didnt think of that
There was just a thread on this ..
https://www.northamericanmotoring.co...d.php?t=138018
Check that out; I imagine you'll find most of your answers/opinions there (which is also likely why you are getting little response here).
Cheers..
Cheers..
What's wrong with the factory plumb-back valve? Not obnoxious-sounding enough?
Don't forget it does not get activated in the usual blow-off valve way. It is servo-controlled by the ECU, not fed boost pressure from the compressor outlet. It's a big reason why the R56 MCS drives so smooth for a turbo car.
If you bypass the stock solenoid and run a like directly from the manifold, usually your turbo spool up time goes up. Ive had great success via the srt4 neon and the Solstic GXP. The old school days the cars had no solenoids on the surge valve, today they do. By holding teh solenoid open the ecu can bleed off extra boost if it sees an over boost condition by taking off "head pressure" from the surge valve. The surge valve is usually only about 4lbs or so, so thast all the car will boost with no head pressure on it.
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
