Drivetrain A/F ratio via hack or via hardware?
Old Jun 5, 2008 | 11:56 AM
flyboy2160's Avatar
flyboy2160
Is there a way to get this by somehow hacking the ecu and getting the A/F ratio out the OBDII port or is the only way to install a wide band 02 sensor?
Thanks.
Old Jun 5, 2008 | 01:56 PM
SumWon's Avatar
SumWon
For tuning, you are best off using a quality wideband O2 sensor installled pre-cat. There are some AF numbers you can get from the ECU; however time intervals and the fact the factory O2 sensors are narrow bands make the info of limited use during tuning.
Old Jun 5, 2008 | 02:55 PM
Guest's Avatar
Guest
Thanks.
There are no numbers to "Hack and get". Our cars do not monitor wideband AF ratios. Your car knows when it's rich, and when it's lean, that's about it.
Buy a wideband AF gauge.
vetsvette
Oct 11, 2015 06:05 PM
pglgp1292
Oct 5, 2015 09:34 PM
GAT
Oct 4, 2015 07:27 PM
micromini234
Sep 30, 2015 07:36 PM
Sep 14, 2015 12:48 PM
