Drivetrain PLX dm-200
Old Jun 3, 2008 | 11:05 PM
Malcon's Avatar
Malcon
PLX dm-200
This seems like a really cool device! I havent really seen or herd much about it. Does anyone have this in their car??
Any input would really be apreciated!
thanks!
http://www.plxdevices.com/products/dm200obd/
Old Jun 4, 2008 | 02:31 AM
grillhands's Avatar
grillhands
Ooooo i want one now!!!
Old Jun 4, 2008 | 05:32 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Wow, I'm impressed...that would be pretty sweet instead of the classic OBDII Scan Gauge
Old Jun 4, 2008 | 06:29 AM
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
My PLX order is shipping today for receipt tomorrow at Custom Mini Shop. I'm getting: DM-100 + SM-AFR combo, SM-EGT, SM-AIT & an extra DM-100. I'm going to have one DM-100 be the full-time a/f display & AIT & EGT on the other. Since I already have the Promini NAV bracket for boost & oil pressure, Dr.Steve (CMS) will be mounting the gauges in Cravenspeed's dual 52mm pods. I'm hoping to have this done in the next two weeks & I'll take picture's for y'all when I'm/we're done.
Old Jun 4, 2008 | 06:38 AM
PGT's Avatar
PGT
I put a DM-100 system in an R56 for Mach V - they sell them.
Old Jun 4, 2008 | 06:42 AM
thulchatt's Avatar
thulchatt
Well, having a SGII, I did not see much to make me want this.
The graphic display is great if you want that, but I like the 4 readouts with the SGII, and the SGII only cost about $150 if you get it from Way Motor Works (shameless plug).
Just my $.02
Old Jun 4, 2008 | 06:54 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
^That is a good point...I just liked how it was a gauge instead of a "box"...but either are worth looking into...IMO
Old Jun 4, 2008 | 07:16 AM
Bahamabart's Avatar
Bahamabart
I'm running the DM5-AFR unit and its nice piece.
Old Jun 4, 2008 | 10:39 AM
grillhands's Avatar
grillhands
Can you show us your setup?
Old Jun 4, 2008 | 11:02 AM
Bahamabart's Avatar
Bahamabart
here is the PXL A/F gauge that comes w/ the combo.
The box or brain is mounted here along w/ a bunch of other stuff.
If you search in the interior / exterior section for PXL - i did post an install thread
Old Jun 4, 2008 | 11:29 AM
Guest's Avatar
Guest
Just so everyone knows, while this may have Wideband AF capacity built in, it WILL NOT work for an R53 MINI. Our cars only have a narrow band AF sensor built in, so OBD2 doesn't provide any Wideband data.
Other than that it looks like an interesting device. Similar to the ScanGaugeII in functionality, with real gauges, and in a form factor that makes more sense for those that don't want little boxes stuck all over their car.
Old Jun 4, 2008 | 02:02 PM
Mach V Dan's Avatar
Mach V Dan
No modern car (that I know of) has wideband data; to get real wideband information on ANY vehicle requires a purpose-built wideband sensor and control circuitry. Some recent cars have five-volt semi-wideband sensors, but they're usually not good beyond about 11.5:1 in the rich direction, or 15.5:1 in the lean direction. A stand-alone wideband will be able to read between 10.0:1 and 17:1 or so.
--Dan
Mach V
Old Jun 4, 2008 | 02:57 PM
Guest's Avatar
Guest
--Dan
Mach V
I was just saying because it seemed that some people were making a comparison to a wideband AF (Looks like it has some of that capability). It doesn't work like that on an R53, though I think the R56 does have some semi-wideband capability as you said.
Old Jun 5, 2008 | 09:42 AM
zmanrz's Avatar
zmanrz
so will this not read A/F ratios correctly since it is not a wideband? or will it still give an accurate reading??
Old Jun 5, 2008 | 09:54 AM
Guest's Avatar
Guest
On the R53 this will not display proper AF's no. You need to buy a separate wideband AF gauge for that. Our cars have no onboard capability for wideband AF.
Old Jun 5, 2008 | 10:15 AM
JIMINNI's Avatar
JIMINNI
I'm not quite understanding you? The kit comes with a, new wideband sensor, a new sensor module that connects the AFR sensor to the new gauge. So why won't it work, or read wideband?
Old Jun 5, 2008 | 10:21 AM
Guest's Avatar
Guest
Where does it say that?
This is all I saw on the site
DM-200 OBDII/CAN
Intelligent Multi-Functional Display (iMFD)
Universal 2 3/8" (60mm) OLED Color Display for all Sensor Modules
Winner of 20 SEMA Awards for Best New Product
Displays up to 50+ sensors
Plug and play to 1996+ vehicles and up
Compatible with all obd2 protocols
Installs in seconds
iMFD sensor modules compatible
Fully customizable
Interfaces with your PC
Looks like a generic OBDII interface... I saw no mentioning of a wideband.
Edit:
Further research shows that they do OFFER a wideband that will integrate, but it's an additional $149.00. The gauge that comes is just OBDII. It DOES NOT include wideband AF capabilities.
Includes:
DM-200 OBDII Module
HDD-200 60mm Universal OLED Display
6ft 4 button remote
4ft power wire with 2.1mm connector
1ft Serial Cable
6ft USB Cable
CD includes User Guide, DM-100/200 Utility, USB Device Driver
Comprehensice User Guide
Old Jun 5, 2008 | 11:03 AM
JIMINNI's Avatar
JIMINNI
I think thats just the guage. Here is one of their combo products, looks like it won't copy well:
[SIZE=5]DM-100 + SM-AFR [/SIZE]
[SIZE=5][/SIZE][SIZE=3]Universal Digital Display Module and Wideband Air/Fuel Sensor Module Combo [/SIZE]
[SIZE=3][/SIZE]Universal 2 1/16" (52mm) Gauge and Air/Fuel Sensor Module
  • <LI class=style3>SEMA Award Winning Gauge <LI class=style3>Measures wideband air/fuel ratio <LI class=style3>Works with other iMFD sensor modules <LI class=style3>52mm Standard Size
  • Digital Accuracy
Old Jun 5, 2008 | 03:47 PM
Guest's Avatar
Guest
  • Digital Accuracy
*shrug*
I was just commenting on the link the OP posted. They touted wideband AF functionality out of the box and I was making it clear that OBDII doesn't allow for wideband capability.
Looks like an interesting unit, nice if you want to have a few gauges at once on the same gauge cup. I'm fine with my multiple $30 gauges though instead of one big $600 one, .
Old Jun 5, 2008 | 06:34 PM
JIMINNI's Avatar
JIMINNI
*shrug*
OMGosh you shruged Actually you can get just the 52 mm. gauge for $209. Not to bad for what it does And the AFR combo is $399. What I thought was really cool is the way the gauge will show a line type graph, that will be nice for watching AFR's.
Old Jun 5, 2008 | 11:55 PM
MINICHEF's Avatar
MINICHEF
... and when will you be able to watch an pay attention to these graphs... while driving????
Old Jun 6, 2008 | 07:24 AM
Malcon's Avatar
Malcon
just mounted at the top of the steering wheels and your good to go haha
co0p3r
Apr 8, 2015 09:57 AM
bearcat245
Jan 9, 2014 03:28 PM
kukaepe
Electrical
Nov 18, 2010 08:28 AM
Clubminator
Jun 29, 2009 02:04 PM
Dr Obnxs
Electrical
31
May 16, 2006 05:20 AM
